Distance, Acceleration, Time, and Power
The discussion revolves around calculating the time required for a 1500 kg car to accelerate from 55 km/h to 75 km/h, given that it accelerates from 35 km/h to 55 km/h in 4.0 seconds with constant power and neglecting frictional losses. The initial velocities were converted to meters per second, yielding V1=9.7 m/s, V2=15 m/s, and V3=21 m/s. The acceleration was calculated as 1.3 m/s² for the first segment, and using the power equation, the acceleration for the second segment was determined to be 1.13 m/s², leading to a calculated time of 6.8 seconds for the second acceleration phase. However, the calculations were confirmed to be incorrect due to misapplication of the power and average velocity concepts.
  • Understanding of basic physics concepts such as acceleration and power.
  • Familiarity with kinematic equations, specifically d = vt + (1/2)at².
  • Knowledge of kinetic energy equations, particularly E = (1/2)mv².
  • Ability to convert units, specifically from km/h to m/s.
  • Study the relationship between power, work, and energy in physics.
  • Learn how to apply integral calculus to motion problems involving constant power.
  • Explore the concept of average velocity and its calculation in kinematic equations.
  • Review differential equations as they apply to motion and energy transfer.
Students studying physics, particularly those focusing on mechanics, automotive engineers, and anyone interested in understanding the dynamics of acceleration and power in vehicles.
Norngpinky
If a 1500kg car can accelerate from 35 km/h to 55 km/h in 4.0 s, how long will it take to accelerate from 55 km/h to 75 km/h? Assume the power stays the same, and neglect frictional losses.
Converting the velocities to m/s, I got... V1=9.7m/s, V2=15m/s, V3=21m/s
Power = work/time = force*distance/time = mass*acceleration*distance/time
Acceleration1 = (V2-V1)/T1 (which is 4 sec) = 1.3 m/s^2
I'm using d = vt + (1/2)at^2 to find distance <----- This I am not totally sure off...
So...I did... P=mad/t=ma*(V1t+.5at^2) = 23985
P1 = P2 as the problem stated...
So... a2 = (v3-v2)/t...After substitution I have
a = P / (m*(v3-v2)) = 1.13 m/s^2
Using a = (v3-v2)/t...I solved for t... I got 6.8s
It says I got the wrong answers, but can't figure out there I did it wrong... :eek:
Hi Norngpinky
are you using integrals in this yet?
As noted P = mav is constant, (note v=d/t) so you could figure out how to include this in your differential equations & integrate
however you could also note that Power = Energy/time
do you know the equation for kinetic energy? If we assume all the power goes into creating kinetic energy & use the fact the power stays constant, this means the change in kinetic energy divided by time will be constant
lanedance said:
Hi Norngpinky
Oh yes... I don't know why I didn't think of that. I know I messed up on the P=mav since P can be Fv (average) as well. . . and didn't know how to get average v...Did the addition of velocities divided by two, but still got the wrong answer.
Thank you ^^ Your explanation makes a lot of sense.
yeah you will have a problem with as the way you are trying to do it really requires integral calculus
try the energy way
P = (E1-E2)/dt - we know this is constant
andthe energy is all going into kinetic energy
E1 = (1/2)*m*(v1)^2
So use this for your first case to find what P is
then as you know the starting velocity and time of acceleration you should be able to solve for final velocity using the P calculated previously
An airplan moves on the runway of the airport at aconstant acceleration,then it takes off after it travels 1.5 km on the runway at avelocity of 210 km/h . what is the acceleration of airplane?
using v squared = u squared + 2as, a = (v squared - u squared)/2s where v= final velocity u= initial velocity s= displacement a = accel
  • · Replies 20 ·
