Distance and time for a treadmill
  • Thread starter Thread starter Outblaze
    Time
This discussion focuses on accurately measuring force, distance, and time while using a treadmill, emphasizing the limitations of using simple devices like meter sticks, bathroom scales, and stopwatches. Key insights reveal that the energy expenditure on a treadmill differs significantly from outdoor running due to the lack of propulsion, as users primarily maintain pace with the machine. The conversation highlights the importance of understanding energy dynamics, including heat loss and energy expenditure, and suggests further research into professional methodologies for accurate assessment.
  • Understanding of basic physics concepts related to force and energy.
  • Familiarity with treadmill mechanics and types (self-propelled vs. motorized).
  • Knowledge of energy expenditure metrics in exercise physiology.
  • Experience with basic measurement tools like stopwatches and scales.
  • Research energy expenditure calculations in exercise physiology.
  • Learn about the differences between treadmill and outdoor running energy dynamics.
  • Explore methods for measuring oxygen uptake during exercise.
  • Investigate the effects of body temperature regulation during physical activity.
Fitness enthusiasts, exercise physiologists, and individuals interested in accurately measuring workout intensity and energy expenditure on treadmills.
Outblaze
Hello:
I'm trying to find "good" measurement for force, distance and time for a treadmill. I'm assuming the force will simply be the "weight" of my body but the distance..the distance is a different issue altogether.
Since we're contrained in not using the data from the machine, I must use simple devices in my disposal i.e. metre sticks, bathroom scales, stop-watches, etc.
How would I calculate good "distances" assuming I'm not setting the treadmill on an incline (that is, if I don't "have" to set it on an incline).
Can I just calculate the average distance between my legs and multiply that by the number of steps I take?
I must also calculate...
1). Energy conducted away by vaporizing sweat.
2).Energy that has been radiated away by my body during the workout.
3).heat energy stored in excess body temperature.
4). Amount of heat energy lost by convection
5). total food energy used
6). heat energy created during the work-out.
Also, what happens to the energy stored as excess body heat as my body cools down to normal temperature?
Any help would be appreciated. Thanks.
I guess this is going to depend on just how accurate you are really wanting to get...
I can see where this is going. I can tell you that your approach is very much idealized and won't be close to the actual energy spent. A lot of research in this area has been done. My wife is an exercise physiologist and I hear about it quite often.
The biggest source of error in your approach is to assume that the work done is simply F*d. In the case of a treadmill, one does not propel themselves like they do on a regular surface. Essentially, one is simply keeping up with the treadmill. Therefore the amount of energy expected to be spent is actually quite a bit lower. If you don't believe me, run 2 miles on a treadmill and then 2 miles outside. You'll see a huge difference in dificulty. Most research I have seen in this area uses a lot of connections between oxygen take up and energy expenditure.
I would suggest that you do some research into this area just to get a better idea of what is really done in the professional world.
When your body stops working as hard as it was, it stops producing heat at that increased rate. The heat you had simply dispurses to the surroundings.
Good work Fred, but...
We need to be careful about the type of treadmill. Some are self propelled (by a motor) as Fred explained, but others just offer friction/magnetic resistance and are actually powered by the user.
