Distance between two nucleons
1 reply · 3K views · last reply
crick
The potential energy associated to the interaction between nucleons has its minimum (point of equilibrium) at ##r\sim 0.7 fm##, as showed in the following graph:
Graph of potential energy in MeV against range in fm for the 1S0 nucleon-nucleon interaction: strongly repulsive below about 0.6 fm, a minimum near -100 MeV at about 0.85 fm, then a slow attractive tail approaching zero by 2.8 fm.
Nevertheless, there are two facts that are, apparently, in contrast with this:
- The average distance between nucleons is ##\sim 1-2 fm##
- The average nucleon density is ##\sim 0.17\,\,\ \mathrm{nucleons /fm^3}##
(These two are related because from the second follows a volume of ##\sim 6 fm^2## per nucleon which is in agreement with the average distance between nucleons)
So why is the average distance between nucleons usually greater that the ##0.7 fm## where the potential energy is minimum?
I'm aware that the "dimension" of nucleon is ##\sim 1 fm##. But is this the reason why the distance between two of them cannot be much less?
  • Graph of potential energy in MeV against range in fm for the 1S0 nucleon-nucleon interaction: strongly repulsive below about 0.6 fm, a minimum near -100 MeV at about 0.85 fm, then a slow attractive tail approaching zero by 2.8 fm.
The Coulomb potential has its minimum at ##r = 0##, this does not mean that the average distance of the electron in a hydrogen atom is zero. There is no a priori reason to believe that the potential minimum should be at the same location as the average distance. There are more things that affect this.
