Distance/Rate/Time word problem
  • Thread starter Thread starter acen_gr
    Word problem
The problem involves a Cessna 150 aircraft's travel times with varying wind conditions, specifically calculating the average wind speed based on given tailwind and headwind times. The subject area includes distance, rate, and time relationships in physics.
  • Participants discuss the setup of equations based on the relationship between distance, rate, and time, with attempts to express distance in terms of wind speed and travel times. There are questions about the correctness of the original poster's calculations and the need for clarity in the equations used.
Some participants are seeking clarification on the original poster's equations and calculations, while others are attempting to identify potential errors in reasoning. There is an ongoing exploration of the mathematical setup without a clear consensus on the solution.
Participants note the conversion of mixed numbers to improper fractions for clarity in calculations, indicating a focus on ensuring accurate mathematical representation.
acen_gr
A Cessna 150 averages 150 mph in still air. With a tailwind it is able to make a trip in 2 1/3 hours. Because of the headwind, it is only able to make the return trip in 3 1/2 hours. What is the average wind speed?
(1) If x = wind speed and y = still air speed
∴ resultant speed (tailwind) = x + y
∴ resultant speed (headwind) = x - y
(2) d = rt
let x = wind speed
still air speed = 150 mph
tailwind time = 2 1/3 hours
tailwind speed = 150 + x
headwind time = 3/12 hours
headwind speed = 150 - x
I used these as given for the problem, expressed distance in terms of tailwind/headwind time and rates, set distance as constant (equates), solves for x then gets 57.69 as answer.
but in the book, the answer is 30 mph. What is the problem with my solution?
Thanks in advance.
Well, your solution is wrong! And we can tell you what you did wrong because you do not say what you did. Please write out the equations exactly as you used them and how you solved.
let x = wind speed
headwind time = 3 1/2 hours
d = rt
tailwind:
d = (150 + x)(2 1/3)
d = 100 + 2 1/3 x
headwind:
d = (150 - x)(3 1/2)
d = 225 - 3 1/2 x
d = d
100 + 2x/3 = 225 - 3x/2
2x/3 + 3x/2 = 125
4x + 9x = 125(6)
13x = 750
x = 57.69
@HallsOfIvy, sorry..
acen_gr said:
let x = wind speed
d = rt
tailwind:
d = 100 + 2 1/3 x
headwind:
d = 225 - 3 1/2 x
d = d
2x/3 + 3x/2 = 125
4x + 9x = 125(6)
13x = 750
x = 57.69
Note that 3 1/2=3.5=7/2 and 2 1/3 =7/3.
ehild
  • · Replies 26 ·
