How Far Is the Star Cluster with Apparent Magnitude 15 mag and B-V of 1.39 mag?
  • Thread starter Thread starter Taylor_1989
    Star
The discussion centers on calculating the distance to a star cluster with an apparent magnitude of 15 mag and a color index of B-V = 1.39 mag, using the spectral type A0V star Vega as a reference. The calculations involve determining the intrinsic brightness of Vega, applying the color excess equation, and using the distance modulus formula to arrive at a distance of approximately 2249 parsecs. Participants identified a critical error regarding the sign in the calculations, emphasizing the importance of correctly applying the intrinsic brightness of Vega in the context of the star cluster.
  • Understanding of stellar photometry, specifically apparent and absolute magnitudes.
  • Familiarity with the concept of color indices in stellar classification.
  • Knowledge of interstellar reddening and its mathematical representation.
  • Proficiency in using logarithmic functions in astrophysical calculations.
  • Study the principles of stellar photometry, focusing on the distance modulus formula.
  • Learn about interstellar reddening laws and their applications in astrophysics.
  • Explore the spectral classification of stars, particularly the A0V type.
  • Investigate common errors in astrophysical calculations and how to avoid them.
Astronomy students, astrophysicists, and anyone involved in stellar distance measurements and photometric analysis will benefit from this discussion.
Taylor_1989
Question: Vega is a star of spectral type A0V at a distance of 7.76pc and has by definition
##m V =m B =0.0\space mag.##
Observations of a star cluster show, that all stars in the cluster with a spectral type A0V have an apparent magnitude of ##m V =15 \space mag## and a colour index of ##B-V=1.39 \space mag ##. Assuming an interstellar reddening law of ##A V /E(B-V)=3.2##, calculate the distance of this star cluster.
$$m-M=5log(d/10) \space [1]$$
$$E(B-V)=(B-V)-(B-V)_0 \space [2]$$
$$m_v=M_v+5log(d)-5+A_v \space [3]$$
3. The Attempt at a Solution
Step 1: To calculate the intrinsic brightness which is ##(B-V)_0## so I used vega to do so.
I did this because according to wiki intrinsic brightness is a measure of absolute magnitude. So my reasoning is that if as the cluster and vega are in the same spectral band then they would sahre the same absolute magnitudes.
$$0-M_v=5log(7.76/10)=0.55$$
Step 2: Substituting this into my equation 2 as follows i.e colour excess equation.
$$E(B-V)=1.39-0.55=0.84$$
Step 3: Rearange the equation ##A V /E(B-V)=3.2## to calculate the extinction value ##A_v##
$$A_v=(3.2)(0.84)=2.69$$
Step 4: Using equation ##[3]## the modified distance modulus and rearanging to make ##d## the subject, I make ##d## the following:
$$10^{\frac{m_v -M_v+5-A_v}{5}}=d$$$$10^{\frac{15 -0.55+5-2.69}{5}}=2249pc$$
This to me seem quite far out, and in practical term I don't think it is possible. Have I made a wrong calculation or is my assumption in the first step completely wrong, or have I complete miss understood the question.
Any advice would be much appreciated thanks in advance.
Sign?
Taylor_1989 said:
@haruspex what do you mean by Sign?
I think you forgot a negative sign here:
log(0.776) is negative.
Sorry I automatically carred it though so, that my fault for missing the step, so it should read $$M_v=0.55$$
Ok.
But I am not a cosmologist, so I am snowed by the plethora of variables, none of which are defined.
Would you mind adding some clarification, or maybe a link?
mV
mB
B
V
E, or is it a function E()?
A, or is it a variable AV?
m
M
(B-V)0
mv
Mv
Av
I think for the step on finding E(B-V), you just need to sub (B-V) as 0 as the Stars in the cluster have the same spectral type as Vega. Hence you should get E(B-V) to be -1.39.
Take my point with a pinch of salt though, it's been a while since I last did stuff like this.
Okay first @haruspex sorry for not labelling the equations correctly, but after redoing the question and a bit of research through some books @Alloymouse is correct I should have set ##(B-V)_0=0##. I am new to the como stuff as it something I am not very intresed in but unfortunately a compulsory module.
But thank you all for the help
