What Causes a Shift in Cosmic Ray Distribution on Earth?
  • Context: Graduate
  • Thread starter Thread starter RyuuJin
    Cosmic rays Rays
The forum discussion centers on the unexpected distribution of cosmic ray particles simulated using Python, specifically with a dipole magnetic field model. The user anticipated maxima at the poles but observed them at approximately 70 degrees latitude. The simulation utilized the SciPy library for numerical integration and included functions for converting between spherical and Cartesian coordinates, as well as calculating particle trajectories under the influence of magnetic fields. The discussion highlights potential issues with the simulation setup, particularly regarding the representation of the magnetic field and the initial conditions of the particles.
  • Understanding of dipole magnetic fields in physics
  • Familiarity with Python programming and libraries such as SciPy
  • Knowledge of numerical integration techniques
  • Basic concepts of particle motion in magnetic fields
  • Explore advanced topics in magnetic field modeling, specifically the effects of polar cusps on particle trajectories
  • Learn about the implementation of relativistic effects in particle simulations
  • Investigate the use of Monte Carlo methods for simulating cosmic ray interactions
  • Study the principles of magnetohydrodynamics (MHD) for a deeper understanding of plasma behavior in magnetic fields
Researchers in astrophysics, computational physicists, and developers working on simulations of cosmic ray behavior in planetary environments.
RyuuJin
Hey guys!
I am trying to simulate distribution of cosmic ray particles, which change their trajectory due to planet's magnetic field (no atmosphere; dipole approximation). I tried considering protons with non-relativistic velocities, falling on an Earth-like planet, which has rotational axis aligned with the dipole axis. I was expecting a distribution maximum at the poles, but instead I got a result with maxima located at the latitudes of roughly 70 degrees (north and south). Do any of you know of an explanation for this occurrence? Or is just something wrong with my code?
Thanks!
Astronomy news on Phys.org
Can you please post the code you have written??
Here's the code (Python). I added comments for easier interpretation. I honestly have no idea, what could I be doing wrong...
Python:
# -*- coding: utf-8 -*-
from scipy import *
from scipy.integrate import ode, odeint
from math import *
from pylab import *
from mpl_toolkits.mplot3d import Axes3D
def dipole(x,y,z) :#cartesian dipole magnetic field
    xyz=[x,y,z]
    len_r = vec_len(xyz)
    dir_r = vec_dir(xyz)
    mi0=1e-7
    A = mi0/(len_r**3)*m_velikost
    return A * (3*((np.dot(m_smer,dir_r))*dir_r) - m_smer)
#direction and length of a vector
def vec_len(x) :
    return np.sqrt(x[0]**2+x[1]**2+x[2]**2)
def vec_dir(x) :
    return np.array([x[0]/vec_len(x), x[1]/vec_len(x), x[2]/vec_len(x)])
'''initial velocity -> from energy'''
def velocity_rel(E,mass,c):
    return np.sqrt(c**2-mass**2*c**6/E**2)
def velocity_class(E,masa):
    return np.sqrt(2*E/masa)
'''spherical - cartesian'''
def cart_to_spher(x,y,z):
    x += 10**(-10)
    y += 10**(-10)
    z += 10**(-10)
    r = np.sqrt(x**2+y**2+z**2)
    fi = (np.arctan(y/x))
    fi = (fi - 0.5*(np.abs(x)/x - 1) * np.pi) % (2*np.pi)#if x<0
    theta = (np.arctan(np.sqrt(x**2+y**2)/z))
    theta = (theta - 0.5*(np.abs(z)/z - 1) * np.pi)#if z<0
    return r,fi,theta
def spher_to_cart(r,fi,theta):
    return [r*np.cos(fi)*np.sin(theta), r*np.sin(fi)*np.sin(theta), r*np.cos(theta)]
def vec_len(x) :
'''gives trajectory of a particle'''
def SolveNewtonLorenz_2(x0, y0, z0, vx0, vy0, vz0, tend, dt, m, q,field=dipole):
    vsq = vx0**2 + vy0**2 + vz0**2
    gamma = 1.0/sqrt(1 - vsq/c**2)
    def f(Y, t=0):
        x,y,z,vx,vy,vz = Y
        Bx, By, Bz = field(x,y,z)
        fac = q/(m*gamma)
        return [ vx, vy, vz,
                 fac*(vy*Bz - vz*By),
                 fac*(vz*Bx - vx*Bz),
                 fac*(vx*By - vy*Bx) ]
    t = arange(0, tend, dt)
    y = odeint(f, [x0, y0, z0, vx0, vy0, vz0], t)
    coll_mat=[]
    for i in range(len(y)):
        vec=[y[i,0],y[i,1],y[i,2]]
        if vec_len(vec)<=Re:
            print("Aaay papi! It's a collision!")
            coll_mat=np.append(coll_mat,vec)
            break
    return y, coll_mat'''gives distribution of particles on the surface (theta, phi)'''
def distrib(N,r0, E0, e, mass, tend, dt):
    theta_tab=[]
    fi_tab=[]
    hits=0
    #I generate particles at distance r0 (theta, phi are random), with certain direction
    for i in range(N):
        #Gaussian velocity distribution
        E=normal(E0,scale=E0/10)
        #incoming direction
        x=rand(1)
        theta=acos(2*x-1)
        y=rand(1)
        fi=(2*np.pi*y)
        #position of particle
        fi0=uniform(0,2*np.pi)
        x1=rand(1)
        theta0=acos(2*x1-1)
        v0=velocity_class(E,mass)
        v_cart=spher_to_cart(v0,fi,theta)
        #if velocity too large -> general relativity
        if v0 >=0.1*c:
            v0=hitrost(E,masa,c)
            v_kart=spher_to_cart(v0,fi,theta)
        vx=v_kart[0]
        vy=v_kart[1]
        vz=v_kart[2]
        #I adjust direction of particles (all are flying towards or next to the planet - not from it!)
        if theta0>=0 and theta0<np.pi/2 and fi0 >=0 and fi0<np.pi/2:#1.octant
            vx=-np.abs(vx)
            vy=-np.abs(vy)
            vz=-np.abs(vz)
        elif theta0>=0 and theta0<np.pi/2 and fi0 >np.pi/2 and fi0<np.pi:#2. octant
            vx=np.abs(vx)
            vy=-np.abs(vy)
            vz=-np.abs(vz)
        elif theta0>=0 and theta0<np.pi/2 and fi0 >np.pi and fi0<np.pi*3/2:#3. octant
            vx=np.abs(vx)
            vy=np.abs(vy)
            vz=-np.abs(vz)
        elif theta0>=0 and theta0<np.pi/2 and fi0 >np.pi*3/2 and fi0<2*np.pi:#4. octant
            vx=-np.abs(vx)
            vy=np.abs(vy)
            vz=-np.abs(vz)
        elif theta0>=np.pi/2 and theta0<np.pi and fi0 >=0 and fi0<np.pi/2:#5. octant
            vx=-np.abs(vx)
            vy=-np.abs(vy)
            vz=np.abs(vz)
        elif theta0>=np.pi/2 and theta0<np.pi and fi0 >np.pi/2 and fi0<np.pi:#6. octant
            vx=np.abs(vx)
            vy=-np.abs(vy)
            vz=np.abs(vz)
        elif theta0>=np.pi/2 and theta0<np.pi and  fi0 >np.pi and fi0<np.pi*3/2:#7. octant
            vx=np.abs(vx)
            vy=np.abs(vy)
            vz=np.abs(vz)
        elif theta0>=np.pi/2 and theta0<np.pi and fi0 >np.pi*3/2 and fi0<2*np.pi:#8. octant
            vx=-np.abs(vx)
            vy=+np.abs(vy)
            vz=np.abs(vz)
        elif theta0==0:
            vz=-np.abs(vz)
        if theta0==np.pi:
            vz=np.abs(vz)
        if theta0==np.pi/2 and fi0==0 or fi0==2*np.pi:
            vx=-np.abs(vx)
        if theta0==np.pi/2 and fi0==np.pi:
            vx=np.abs(vx)
        if theta0==np.pi/2 and fi0==np.pi/2:
            vy=-np.abs(vx)
        if theta0==np.pi/2 and fi0==2*np.pi:
            vy=np.abs(vy)
        startVel=[float(vx),float(vy),float(vz)]
        startPos=spher_to_cart(r0,fi0,theta0)
        posMat,cPos= SolveNewtonLorenz_2(startPos[0],startPos[1],startPos[2], startVel[0],startVel[1],startVel[2], tend,dt, mass,e, field=dipole)
        if len(cPos)>1:#if collision occurred
            r_coll,fi_coll,theta_coll=cart_to_spher(cPos[0],cPos[1],cPos[2])
            theta_tab=np.append(theta_tab,theta_coll)
            fi_tab=np.append(fi_tab,fi_coll)
            hits+=1
    print(hits)
    return fi_tab,theta_tab, posMat,cPos
EDIT: fixed typing/naming error in line 113
Python:
from scipy import *
from math import *
from pylab import *
    xyz=[x,y,z]
    mi0=1e-7
def vec_len(x) :
def vec_dir(x) :
    x += 10**(-10)
    y += 10**(-10)
    z += 10**(-10)
    return r,fi,theta
def vec_len(x) :
    def f(Y, t=0):
        x,y,z,vx,vy,vz = Y
        fac = q/(m*gamma)
    coll_mat=[]
            break
    theta_tab=[]
    fi_tab=[]
    hits=0
    for i in range(N):
        #incoming direction
        x=rand(1)
        theta=acos(2*x-1)
        y=rand(1)
        fi=(2*np.pi*y)
        x1=rand(1)
        theta0=acos(2*x1-1)
        if v0 >=0.1*c:
            v0=velocity(E,mass,c)
        vx=v_kart[0]
        vy=v_kart[1]
        vz=v_kart[2]
            vx=-np.abs(vx)
            vy=-np.abs(vy)
            vz=-np.abs(vz)
            vx=np.abs(vx)
            vy=-np.abs(vy)
            vz=-np.abs(vz)
            vx=np.abs(vx)
            vy=np.abs(vy)
            vz=-np.abs(vz)
            vx=-np.abs(vx)
            vy=np.abs(vy)
            vz=-np.abs(vz)
            vx=-np.abs(vx)
            vy=-np.abs(vy)
            vz=np.abs(vz)
            vx=np.abs(vx)
            vy=-np.abs(vy)
            vz=np.abs(vz)
            vx=np.abs(vx)
            vy=np.abs(vy)
            vz=np.abs(vz)
            vx=-np.abs(vx)
            vy=+np.abs(vy)
            vz=np.abs(vz)
        elif theta0==0:
            vz=-np.abs(vz)
        if theta0==np.pi:
            vz=np.abs(vz)
            vx=-np.abs(vx)
            vx=np.abs(vx)
            vy=-np.abs(vx)
            vy=np.abs(vy)
            hits+=1
    print(hits)
May be the polar cusp.
Are polar cusps formed in simple dipole approximation? I didn't classify regions like magnetosheath or magnetopause in my simulation.
The magnetic field lines stretch further outward at higher latitude. Your density would stop increasing because the magnetic field is no longer deflecting. At 0 degrees (equator) the proton feels a force at 90 degrees. A proton at high latitudes does not feel much force so it continues closer to forward. If a proton is coming in from above northern Siberia moving toward Canada there is not much force to change the direction. It would cross the north pole.
There is also more kilometers at 70 degrees relative to 80 degrees. The 90 degree latitude line is 0 kilometers long. Is your "maximum" a count of protons hitting between degree x and degree y? If so you should expect 0 impacts in the 90+ category. Should get increasing impacts with increasing area until the magnetic defection becomes strong and the map geometry effect becomes weak.
  • · Replies 28 ·
9K
  • · Replies 21 ·
  • · Replies 25 ·
