How Do Two Divers' Speeds Compare When Jumping from a 3m Platform?
The problem involves two divers jumping from a 3-meter platform, with one diver jumping upward at a speed of 1.8 m/s and the other stepping off the platform as the first diver descends. The questions focus on determining their speeds upon hitting the water and which diver reaches the water first.
  • Mixed
  • Participants discuss calculations for the final speeds of both divers as they hit the water, using kinematic equations. There are attempts to clarify the sign conventions used in the calculations and the values of gravitational acceleration. Some participants suggest checking for rounding errors and the assumptions made regarding the timing of the divers' jumps.
Participants are actively engaging with the problem, sharing their calculations and questioning the assumptions made in the original attempts. There is recognition of potential discrepancies in the expected answers, and some guidance is offered regarding the use of consistent sign conventions and the correct interpretation of the problem setup.
There is mention of a possible difference in the value of gravitational acceleration used in calculations, as well as the need to clarify the definition of speed versus velocity in the context of the problem.
negation
Two divers jumped from a 3m platform. One jumps upward at 1.8ms^-1 and the second steps off the platform as the first passes it on the way down.
a) What are their speeds as they hit the water?
b) Which hits the water first and by how much?
Diver 1:
Calculate distance diver 1 travels as he jumps 1.8ms^-1 upwards off the platform.
vf^2 - vi^2 = 2g(yf - yi)
0 - (18ms^-1)^2 = 2(-9.8ms^-2)(yf - yi)
yf - yi = 0.165m
3 m + 0.165m = 3.165m
vf = 7.8ms^-1
diver 1 hits water at 7.8ms^-1
Diver 2:
vf^2 - 0 = 2(-9.8ms^-2)(-3m)
vf = 7.6ms^-1
Diver 2 hits water at 7.6ms^-1
Diver 1:
At the instant at which diver 1 is 3.165m off the ground, vi = 0
-3.165m = 0.5(0ms^-1 + (-7.8ms^-1))t
t = 0.8s
Diver 2:
-3 = 0.5(0ms^-1 + (-7.6ms^-1))t
t = 0.78s
My answers are wrong according to the book:
a) -7.67ms^-1
b) 0.162s
Diver 1:
yf - yi = 0.165m
vf = 7.8ms^-1
Diver 2:
vf = 7.6ms^-1
Diver 1:
t = 0.8s
Diver 2:
t = 0.78s
a) -7.67ms^-1
b) 0.162s
For the first part, I would check what value of g the textbook expects you to use, and whether you had round-off errors in intermediate steps. g = -9.81m/s^2 gives the expected answer to 3 s.f.
Your working in the first part looks OK, but I would be careful of your sign convention. Define up to be positive, and down to be negative. That may explain why the answer key has a negative sign (but they mentioned speed, which shouldn't have a sign - if they'd said velocity, they'd be correct).
Note that you don't actually have to calculate the point at which Diver 1 comes to momentary rest. Just use initial velocity = +1.8m/s and g = -9.81m/s^2 to get the final velocity in one step. Remember that the s term (or y term, as you're using it) is actually displacement and not total distance. Minimise the number of steps you take to get your answers, and there will be less chance of error.
As for the second part, I'm assuming you're using ##s = \frac{(u+v)t}{2}## (state the equation you're using - always!).
For diver 1, you seem to be working out the time taken to reach the water *from the time he is at maximum height and is momentarily at rest*. Is this really the time you want for diver 1? Remember that diver 2 steps off the platform only as diver 1 passes him.
I'm still getting -7.88ms^-1 after rounding off to 3SF
If the answer states -7.67ms^-1 then something is wrong
The question asks for speeds, plural. Diver 1's speed is 7.88m/s downward (so velocity = -7.88m/s). I'm getting that too, so I think you're right.
Diver 2's speed is 7.67m/s downward (v = -7.67m/s). Are you getting this?
I am.
I'll work on part (b) now
  • · Replies 24 ·
