Divergence/Convergence of the series (ln(n))^3/n^3
  • Thread starter Thread starter beaubulldog
    Series
The series Σ(ln(n))^3/n^3 converges based on the direct comparison test (DCT). For large values of n, ln(n)^3 is less than n, which implies that (ln(n))^3/n^3 is less than 1/n^2, a known convergent series. The discussion highlights the importance of understanding the growth rates of logarithmic and polynomial functions, specifically that ln(n) grows slower than any power function, including n^(1/3). Therefore, the series converges as established by the comparison with 1/n^2.
  • Understanding of series convergence tests, particularly the Direct Comparison Test (DCT) and Limit Comparison Test (LCT).
  • Familiarity with logarithmic and polynomial growth rates.
  • Knowledge of basic calculus concepts, including limits and asymptotic behavior.
  • Ability to manipulate inequalities involving logarithmic and polynomial expressions.
  • Study the Direct Comparison Test (DCT) in detail to understand its application in series convergence.
  • Learn about the Limit Comparison Test (LCT) and how it differs from DCT.
  • Explore the growth rates of functions, particularly comparing logarithmic functions to polynomial functions.
  • Review convergence criteria for series, focusing on p-series and their convergence properties.
Students studying calculus, particularly those focusing on series and convergence tests, as well as educators teaching advanced mathematical concepts related to series analysis.
beaubulldog
Does the following series converge or diverge? give reasons for your answers.
\Sigma(ln(n))^3/n^3
Is the direct comparison test appropriate for this question? limit comparison? I have issues with the direct comparison when attempting to compare to the harmonic series, and limit comparison doesn't seem to yield a very simple solution either.
I attempted to show that the series above is greater than the series ln(n)/n, which is greater than 1/n, the harmonic series. this is apparently not the case, however, as made evident by my graphing calculator on window -1<x<10 & -2<y<2.
Compare ln(n) and n1/3
could you be a little more specific...? I am not sure how comparing ((ln(n))^3)/(n^3) to ln(n) or n^1/3 would help...you saying use DCT? LCT? thanks for the reply.
Which grows faster? ln(n) or n1/3?
ln(n) grows faster as n->inf...i'm still not seeing how this is pertinent to my problem however. Again, thanks.
You might want to double check that with a calculator. You probably went over in class how the exponential function grows faster than any power function, and the logarithm function grows slower; you might want to review your notes and check (I don't see how this problem is possible without making this observation)
I stand corrected. n^1/3 does indeed grow faster. How do I relate that fact to the sum of the sequence ((ln(n))^3)/n^3? Ohh...wait, so if i set up the inequality to use in the DCT, 1/n<(ln(n)/n)^3, then cube-root everything, multiply the n from the right side, I end up with n^(2/3)<ln(n)...Is that where you were going with this? in that case, it is a direct comparison with 1/n, proving that (ln(n))^3/n^3 diverges. Correct?
No, because your end result n2/3<ln(n) isn't true, so you can't conclude 1/n< ln(n)3/n3
If you know that ln(n)<n1/3 for big n, then ln(n)3<n.
So what is ln(n)3/n3 smaller than? Think of susbtituting something for ln(n)3
so since ln(n)^3 is less than n, that means that ln(n)^3/n^3 is less than n/n^3, so ln(n)^3/n^3 is less than 1/n^2, which is a convergent series...?
That's right. Keep in mind when you're wording your answer to be precise:
For large n, ln(n)3<n, so ln(n)3/n3<1/n2, so since convergence is not affected by the leading portions of the series (it doesn't matter what the values of ln(n)3/n3 when n is smaller) by the comparison test the series converges
