Dividing over zero while calculating center of gravity - Getting error
24 replies · 4K views
I'm not sure what that paper is showing. Since nothing is said about the density, I assume you are taking that to be constant and are actually trying to find the centroid. The coordinates of the centroid of a two dimensional figure are given by
[tex]x_c= \frac{\int x dA}{\int dA}= \frac{\int x dA}{A}[/tex]
[tex]y_c= \frac{\int y dA}{\int dA}= \frac{\int x dA}{A}[/tex]
The denominator is just the area of that figure which obviously is not 0! There should not be any subrtraction in your calculation.
Hi Fp! I was wondering if you'd be here today! :smile:
On the bottom line (the denominator) you have a sum of areas.
But you've taken some of those areas as being negative? :confused:
@HallsofIvy - We're not using calculus in our solutions
I meant to post 8 hours ago but I had internet disconnection issues!
The two triangles don't exist, so they're in minus, and the rectangle is at the minus part of the Y axis, hence it's negative. Doesn't that make sense?
Should the sign between 21x12 and 21x9 be a plus, not a minus?
Aw! That must have been hard to take! :frown:
Oh yes. My bad.
However, the rectangle at the left of the Y axis still has a positive contributing area.
It's only that the x coordinate of its center is negative.
You didn't really make that distinction in your nominator (the top line).Edit: So areas that belong to your body always have a positive contribution, while areas that are taken out of the body always have a negative contribution.
The coordinates of the centers are taken positive or negative just as they are.
True, that's why in my Yc I meant to do it in plus, but in Xc it's minus
I'm not sure what distincton. Can you elaborate?
I would have written your fraction (if I'd be very explicit) as:
[tex]x_c = \frac {((+21 \cdot 12) \cdot \frac {+12} 2) + ((+21 \cdot 9) \cdot \frac {-9} 2) + ...} {(+21 \cdot 12) + (+21 \cdot 9) + (-\frac {9 \cdot 6} 2) + (-\frac {12 \cdot 6} 2)}[/tex]
That is, the areas that are part of the body have a plus sign in front.
The areas that are taken out of the body have a minus sign in front.
The x coordinates of the centers have their sign as applicable.
But the 21x9 rectangle shape is at the negative side of the X axis, doesn't that mean that while calculating its distance to the Y axis I need to take a negative value?
For its distance to the Y axis - yes, take a negative value (-9/2).
For its contribution to the area - no, take a positive value (+21x9).
Sorry, out of ideas how to explain this better (for now).
For its contribution to the area - no, take a positive value (21x9).
But regardless minus times a plus is a minus, so wasn't I right in minusing it?
In the nominator (top line) - yes, you were right minusing it. I just wanted to point out the distinction between sign of area and sign of coordinate.
In the denominator (bottom line) - no, you were not right minusing it. The area contributes here in a positive manner.
Ohhhhhhhhhhhhhhhh! okay, give me a moment :)
Just to make sure, before you're going to start drawing flowers, and butterflies, and bees, you do have another mistake in the nominator (I wrote "..." before on purpose! :devil:).
The small triangle. It's a minus, since it doesn't exist, and since it's on the negaative side, it's arm is minus, therefor it's a plus. Is that right?
Edit: Am off back home. Talk later :) thanks!
Femme_physics said:
Could the answer be
Xc = 5.654
The manual says something else. I don't have a scanner (not for the next two hours), but this is what the manual says through my poor quality webcam:
Xc = 0.17
Sorry, both answers are wrong!
I think you have a faulty solution manual here! :devil:
Yes, that is right. (That's not your mistake. :P)
Edit: could you check the arm lengths?
Femme_physics said:
I used the wrong distances for the triangles
For the bigger triangle it's 8
For the smaller triangle it's 6
Very good! :smile:
Femme_physics said:
This is what I get after all the corrections
Hmm, are those areas in the denominator?
The numbers look the same as the ones in the nominator?! :confused:
All the signs are correct though! :smile:
Femme_physics said:
Oops! I'm getting too excited lately, heh.
:) Got it, right?
Right! :smile:
What is it you are you excited about?
To solve it! :) Thanksssssssssssssssssss!
I'll add it to the corrections manual!
You're welcome. :wink:
But what about Yc?
Femme_physics said:
Same as the solution manual :)
Yes. That is right! :smile:
Funny, because I expected the solution manual to be wrong, but I didn't check.
Turns out that they have been inconsistent in their calculations! :wink:
