Division with the rectangular form
The discussion revolves around solving the division of complex numbers without using polar transformation. The example provided is (2 + 2i) / (1 - i). The correct method involves multiplying both the numerator and denominator by the complex conjugate of the denominator, resulting in (2 + 2i)(1 + i) in the numerator and (1 - i)(1 + i) in the denominator. This leads to a final answer of 2i, confirming the calculation is correct. The participant expresses gratitude for the clarification after initially feeling confused.
Truthlover
Hi everyone, I was questionning myself about a problem that I have surely learn in school but I want to know if it's possible to solve a division with imaginary numbers without using the polar transformation.
Example: \frac{2+2i}{1-i}
So with the polar tansformation we have this:\frac{2\sqrt{2}\angle45°}{\sqrt{2}\angle-45°}=2i
Now I was wondering if someone know a way to find the solution of 2i without the polar transformation. If it's the case can you show me how you have done it.
Thanks
Mathematics news on Phys.org
Multiply both numerator and denominator with the complex conjugate of (1 - i ).
I'm not sure if I do the right thing but the conugate of (1-i) is (1+i). So if we do the multiplaction it give: (2+2i)*(1+i)= (2*1)+(2*i)+(2i*1)+(2i*i)= 2+2i+2i-2=4i
This is not the answer. What I have done wrong?
You didn't include the denominator!
\frac{2+2i}{1-i}\frac{1+i}{1+i}= \frac{(2+2i)(1+i)}{(1-i)(1+i)}
Now the numerator is, as you say, 4i. The denominator is 1- i2= 2.
\frac{2+2i}{1- i}= \frac{4i}{2}= 2i
which is correct:
(2i)(1- i)= 2i- 2i^2= 2+ 2i.
I feel really stupid but thanks a lot
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 17 ·
