How can I fix a device that requires a ping response from www.skype.com?
  • Thread starter Thread starter fog37
The discussion centers around troubleshooting a device that requires a ping response from www.skype.com, which has stopped functioning due to Microsoft disabling the ping response. Participants explore potential solutions, including DNS configuration changes and device-level adjustments.
  • One participant explains the role of DNS in converting URLs to IP addresses and inquires about blocking pings to www.skype.com while allowing other devices to access it.
  • Another participant suggests turning the ping service back on and asks for the type of operating system in use.
  • A third participant provides a link to an article that may assist with enabling ping responses on Windows 10.
  • A later reply notes that the device requires an ICMP echo from www.skype.com, which is no longer available, and proposes using a custom DNS server to control responses.
Participants have differing views on the best approach to resolve the issue, with no consensus on a definitive solution. Some suggest enabling ping responses, while others propose DNS modifications.
Participants express uncertainty regarding the capabilities of the router and the implications of changing DNS settings for other devices on the network.
fog37
Hello Forum,
I understand that the DNS (primary and secondary) in my internet router convert URL requests into numerical IP address to use for retrieving the requested content from the web.
I have a host device that is skype enabled that stopped working (does not connect to the internet anymore) because it pings the skype.com and does not get a ping back (Microsoft disactivated the ping response).
How can I fix that?
Is it possible to block the pinging to www.skype.com and have the device ping something else? What changes should I make to the DNS configuration? I don't think my router let's me block certain URLs...If I managed, somehow, to place a block to www.skype.com on the DNS, also all the other host devices would not be able to connect to www.skype.com. Could I let the other devices access www.skype.com by tweaking things at the devices level (DNS configuration on each device)?
thanks,
fog37
Computer science news on Phys.org
Your best bet is to figure out how to turn the ping service back on. What type of system do you have? Windows 7, 10, or something else?
The problem is that the device is requiring that www.skype.com return an ICMP echo. That site no longer returns a response to ICMP echo.
You could do the DNS shenanigans if you have something that can have a DNS server installed. Just change the primary DNS server on your router to that and and you have full control over the DNS responses. You could set it up so that the offending device gets an IP address of the DNS server instead of the Microsoft provided one. You can respond to the ping from there and probably put a tunnel into make everything seamless.
BoB
9K
