Do Black Holes Outlive Everything Else in the Universe?
  • Context: Graduate
  • Thread starter Thread starter Shayne T
    Blackholes Fun
Black holes generate the strongest gravitational fields in the universe, leading to significant gravitational time dilation effects. While they are theorized to have infinite density due to their singularity, they will not outlive everything else in the universe. As the cosmic background radiation cools, black holes will begin to evaporate through Hawking radiation, with smaller black holes evaporating first. The discussion emphasizes that gravitational time dilation does not equate to longevity, as the elapsed time experienced by observers near a black hole differs significantly from those further away.
  • Understanding of black hole physics and singularity concepts
  • Familiarity with gravitational time dilation principles
  • Knowledge of Hawking radiation and its implications
  • Basic cosmology, particularly the concept of heat death of the universe
  • Research the mechanisms of Hawking radiation and its impact on black hole longevity
  • Explore the implications of gravitational time dilation in astrophysics
  • Study the concept of cosmic background radiation and its evolution over time
  • Investigate theories surrounding the heat death of the universe and its consequences
Astronomers, astrophysicists, and anyone interested in the long-term fate of black holes and the universe's evolution.
Shayne T
Hey all,
This is a just for fun question, as I am sure there is no definitive correct answer. But here it goes
Blackholes to my knowledge, generate the strongest gravitational fields in the known universe. While thinking about gravitational time dilation, and the sheer magnitude that black holes affect gravity, does this mean that black holes will outlive EVERYTHING in the universe? I know black holes, more specifically, the singularity within the black hole, are considered to have an infinite density made possible by a volume = 0 I am assuming (any mass/0 volume = infinite density). So all in all, I guess this question is asking, is the gravitational time dilation factor of black holes large enough to allow them to outlive everything else?
Blackholes are extremely fun to think about. I truly believe that they hold the answers to everything about the origins of our universe, and possibly other universes. But that's a whole different subject! Let me know what some of you guys think about my proposed question!
Cheers
When the cosmic background radiation cools enough (billions of years in the future) black holes will eventually start radiating more energy than they acquire from the background radiation and start evaporating. Some stars are too small to form a black hole when they run out of fuel and end up as cold bodies, and these bodies might possibly outlive the black holes as they are not subject to Hawking radiation. The high gravitational time dilation just outside the event horizon of a black hole means that an observer at this location will generally measure less elapsed time between two co-located events than an observer further out in space. *There is a caveat here, the two observers should be stationary with respect to each other.*
If you look up Hawking radiation, you can see that once a black hole starts evaporating, the rate that a black hole evaporates increases exponentially as they get smaller and this evaporation rate is calculated at infinity and will appear even faster close to the black hole. The onset of the evaporation process is dependent on the size of the black hole. The bigger the black hole, the colder the background radiation has to get, before the process starts, so the small black holes start evaporating first. Perhaps the radiation from dying small black holes may contribute to the background radiation and be enough to preserve the larger black holes. All this assumes that the universe will continue expanding and that the universe suffers a 'heat death', which is possible debatable. That aspect is probably better discussed in the cosmology forum.
You're confusing the gravitational time dilation factor with how long an object "lives". The two are not the same. For example, suppose you and I are both in a space station far above a black hole. I climb into my rocket and go down very close to the hole and "hover" there for a while, then I come back up to the station. We will find that the elapsed time on my ship's clock is much less than the elapsed time on the station clock; but does that mean I have "outlived" you? (To make the question even more pointed, assume both you and I are immortal; neither of us will ever die of natural causes. That is a better analogy to the black hole case anyway.)
  • · Replies 51 ·
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 20 ·
