Danfishman
- Messages
- 2
- Reaction score
- 0
Hello,
I hope this is the right area to post this question. We are having a debate at my workplace and was hoping there was someone more qualified to settle the debate.
We are a packaging company and have setup an experiment to test the pressure differnential from sealiong at 1800m vs. Sea Level. We would like to see if the packaging can with stand the external pressure at sea level. We have calculated this diffence to roughly .2 bar (~3PSI), set up an experiment by placing the sealed packs in pressure chamber, and add the 3psi of air to the tank.
The debate came about as to wether adding chips (the product) would effect the result. Ie decreasing the amount of air (chips are displacing the air) would help offset the external air pressure being applied.
One side is saying that the smaller volume of air will result in less external pressure as there is less air trying to equalise. The otherside believes it makes no difference, as the pressure is being applied externally and the amount of air is inside makes no difference, as long it is at the same pressure in both instances.
Would having chips in the packaging affect the result?
Cheers!
Cheers!
