Do Desktop Computers Have Built-In Batteries Like Laptops?
  • Thread starter kolleamm
    Batteries
8 replies · 4K views · last reply
kolleamm
A Google search only yielded whether they have CMOS batteries, but I'm referring to batteries that if you were to unplug your computer it would go off.
I opened up a mini Desktop and just saw a motherboard without any large battery anywhere, so I'm guessing no? I would like to be sure however.
Thanks in advance
No. Desktops are usually connected to an external power backup in case the power goes out. Some have minimal batteries, but they're designed to last basically just long enough for the computer to properly shut down.
Thanks, my concern arose from having a battery fail before the computer does.
The Real Time Clock module will generally have a small battery. And it does have a limited lifetime -- that's why some older PCs do not have an accurate time anymore and have to be reset when powered up. And since it can also be responsible for storing BIOS information (in older PCs before cheap serial flash memories were available), it can cause other problems and need to be replaced.
http://www.makeuseof.com/tag/why-does-my-motherboard-have-a-battery/
In modern desktops those batteries are almost always 2032 size coin cells. Usually they are replaceable with nothing more complicated than a small prying device. Often the lever is operable with your finger. The clock may run the wrong speed long before you get any other faulty operation. If it is not keeping the correct time it is time to replace the battery.
When they get low you can sometimes get odd operation. As I recall, intel's 810 series of chipsets would lock up when the battery went dead. Te revive them you needed to go through a certain series of actions when replacing the battery. Just popping in a new one would not work.
BoB
Thanks guys that clears it up for me. Desktops have no batteries for the whole system.
Except when you are connected to a UPS. There are UPS designs that are installed internally in a spare drive bay.
So there are some rare cases where the desktop has a battery to run the whole system. The run time is generally just long enough to save your work and shut down. It is not for general use.
BoB
I think it is wise to have a UPS for a desktop PC. I have one that will power the PC, monitor, and a small LED lamp for a short time so I can close files I am working on and shut it down if the power goes out. (My power does out a LOT at unexpected times.)
FactChecker said:
I think it is wise to have a UPS for a desktop PC. (My power does out a LOT at unexpected times.)
Very wise... my power goes off at unexpected times, too...
PowerPanel Personal Edition window from CyberPower showing Current Status: AC Utility power, 124 volts, normal power condition, battery 100% fully charged, 49 minutes remaining runtime, UPS load 99 watts.
PowerPanel Personal Edition window from CyberPower showing the UPS working normally: AC utility power source, battery capacity 100%, estimated runtime 49 min, and a Power Problem Summary listing power outage, under voltage and over voltage as Never.
