Do different SCRAMjet designs use alternative compression methods?
  • Thread starter Thread starter Sickwayne77
    Design Efficiency
1 reply · 3K views
Sickwayne77
So I was wondering if there was only one generally accepted SCRAMjet design or if there are many.
Based on the small amount of info available, info primarilly concerning theoretical hypersonic operation, it seems that most design proposals involve a "physical" compression of air in the inlet. This is to say that the compression is achieved by a volumetric decrease from front to rear in the inlet, just like a ramjet engine. So is it just a lower drag, lower compression rate version of a ramjet design that allows the air to enter and combust at supersonic speeds? I ask because I feel that a method of compression that didn't involve a volumetric decrease would be more efficient. A specifically shaped engine could utilize the bernoulli effect and would create much less drag with a smaller cross sectional surface area.
Any thoughts?
When you work with supersonic speeds and shock waves, you can't depend on the Bernoulli effect equations.
