Do electron orbitals ever change?
The discussion revolves around whether electron orbitals change in shape and size under different states of matter, specifically comparing solids and liquids. Participants explore various models of electron behavior, including the probability cloud model, and consider factors that might influence orbital characteristics.
  • Some participants question whether the discussion pertains to the Bohr model, the probability cloud model, or other models.
  • It is noted that electron orbitals are constantly changing in shape, particularly when transitioning between states such as solid and liquid.
  • Some argue that the presence of nearby atoms significantly perturbs the "free atom" solutions to Schrödinger's equation, complicating the behavior of electrons.
  • Participants discuss that heavier elements may have slightly tighter orbitals, though this is not universally agreed upon.
  • One participant suggests that while the shape of orbitals may change with temperature, the fundamental allowed energy states for a hydrogen atom remain unchanged.
  • There is a suggestion that the shapes of orbitals for different atoms can vary significantly based on their interactions in solid or liquid states.
  • Hybridization of orbitals is mentioned as a factor that can affect their geometry, which is crucial for chemical bonding.
Participants express differing views on the extent and nature of changes to electron orbitals in different states of matter. There is no consensus on how these changes manifest or the implications of such changes.
Limitations include the complexity of interactions in multi-electron atoms and the challenge of defining orbital shapes in non-isolated conditions. The discussion also highlights the dependence on the specific atoms involved and their interactions.
jactor
1. Do electron orbitals ever change in _shape_? Specifically, does a solid have the same orbital shapes as a liquid?
2. Are there any factors that would change the _size_ of electron orbitals?
Are you asking about the Bohr model, or about a probability cloud model, or about some other model?
Probability cloud model (which I understand to be the current accepted model?)
The probability cloud outwardly decreases in density. The electron will jump if you force it to do so. Just exactly how much force that will require remains anyone's guess. We know that the numbers are 'more than this' and 'less than that', and the threshholds are well-established and thoroughly published, but we don't know determinately at the quantum level.
This doesn't really seem relevant to my original questions?
I think one must be careful here. The presence of any other atom nearby will start to perturb the "free atom" solution to Schrödinger. As more atoms get closer and closer the changes become profound. The electrons are no longer assignable to one nucleus and the solutions are very complicated. Most of the art of solid state and molecular physics (no surprise here) is to extract the detailed information required without solving the whole N atom problem. The solutions for isolated atoms with electrons are not even approximately eigenstates
Do “electron orbitals” really have a size or a shape ?
The electrons that are involved with bonding will have different configurations in different states.
The size or shape of a bond is in the model you have in your mind. We do not know how you imagine your model.
https://en.wikipedia.org/wiki/Electron_configuration
Then let's please look again at your questions:
Electron orbitals are constantly changing in shape, but not by very much, unless something bigger happens.
A liquid has more freedom than a solid; in the probablistic model, yes, that can change the shape a little, and no, an electron orbital cloud does not have the same shape in the solid state as in the liquid state.
I'm pretty sure that if at all not by much ##-## as far as I know, heavier elements may have slightly tighter orbitals ##-## the EM force varies as the cube on the distance ##-## obviously, atoms remain tiny ##-## if the energy gets to be big enough, the electron jumps ##-## as far as I know, that doesn't change the orbital size ##\dots##
This is the thing I most want to dig into. In what way do the shapes change? And is there also a difference between gas/liquid as there is with liquid/solid?
That is intuitive, thanks.
So to consider a single atom in a vacuum, would the shape change as the atom is heated?
  • Skeptical
For a hydrogen atom the orbitals (allowed energy states and associated eigenfunctions) would be unchanged but the electrons would not be in an eigenstate of energy. Interactions with the temperature "bath" (whatever it may be ) would demand a superposition of higher energy states on average. So the probability "cloud" for the average atom would get bigger because the excited states are "bigger" For multielectron atoms it can be more complicated, but generally this is true also
That is a very difficult question to answer, as it depends entirely on which atoms you're dealing with and how they end up interacting or binding together when the go into liquid and solid states. For example, atoms which form metallic solids have a very different 'shapes' for their electron orbitals than something like carbon or oxygen.
Note that the atomic orbitals you're used to seeing on something like wikipedia only really exist in an isolated atom with one electron. An atom that's interacting with nearby atoms or one that has multiple electrons may have very different atomic orbital shapes.
A single atom can't really be 'heated' like you would think. All it can really do is accelerate or have its electrons excited to higher energy states. I don't think either of these would change the shape of the atomic orbitals though. The electrons would just exist in different orbitals which intrinsically have different shapes than their lower energy counterparts.
Separate orbitals can sometimes hybridize, which affects their geometry. This is called orbital hybridization, and without it, most of chemistry wouldn't happen - in fact, carbon based life wouldn't exist!
Probably not what you were looking for, though.
  • · Replies 56 ·
  • · Replies 41 ·
