Do FCC Structures only have a CN of 12?
FCC (Face-Centered Cubic) structures typically have a coordination number (CN) of 12, but this can vary due to lattice vacancies and atomic site distortions. The discussion reveals that a small number of defects, such as vacancies, can exist without significantly affecting the symmetry of the FCC structure. Specifically, references indicate that up to one vacancy per 1000 atoms may be permissible at equilibrium near the melting point of metals. However, the stability and diffraction characteristics of disordered FCC structures may be compromised with higher vacancy concentrations.
  • Understanding of FCC (Face-Centered Cubic) crystal structures
  • Knowledge of lattice defects and their impact on crystal symmetry
  • Familiarity with crystallography and diffraction techniques
  • Basic concepts of thermodynamics as they relate to crystal stability
  • Research the effects of lattice vacancies on FCC crystal structures
  • Study the relationship between temperature and defect formation in metals
  • Explore crystallography techniques for analyzing diffraction patterns
  • Investigate the stability of disordered FCC structures under varying conditions
Materials scientists, crystallographers, and researchers studying the properties of metallic structures and defects in crystalline materials.
letshin
Hi all,
Without first delving too deeply into the literature I wanted to ask if its is only permissible for FCC structures to have a coordination number of 12. In the case of lattice vacancies and/or distortion: wherein the atomic sites are slightly displaced; is there a kind of tolerence for this to happen without breaking the FCC symmetry?
Are there any publications on this topic?
Many thanks,
Let
No real crystal is exactly perfect everywhere - you always have some defects. The number of defects is very small compared to the total number of atoms, so usually they can be neglected if you consider the crystal structure.
Cheers. When you say small, what is the order of difference?
In the case of a, say, disordered FCC structure how many vacancies would be needed before the structure loses symmetry and say, no longer shows FCC-type diffraction peaks?
That really depends on the crystal, its temperature, purity and so on.
I'm not sure if such a broken crystal would still be stable enough to use it as a crystal at all.
Reference 2 of the wikipedia article suggests up to one vacancy per 1000 atoms in equilibrium at the melting point of metals. And that is a very high number of vacancies.
Likes letshin
Thanks for that. That helped quite a bit - of course I should have checked wiki first at the very least. Silly me.
  • · Replies 62 ·
11K
  • Sticky
503K
