Do I need a loop to read multiple student names and marks?
  • Topic: Comp Sci
  • Thread starter asz304
    Loop
asz304
I'm not sure how this works. If I need to put a loop before the first cout statement.
Code:
include <iostream>
include <cmath>
using namespace std;
string name[number];
char letterGrade[number];
double mark[number];
int main(){
  cout <<"Enter number of students";
  cin >> number;
  cout << " Enter the name ";
  cin >> name[number];
  cout << " Enter the mark ";
  cin >>  mark[number];
Is this right?
or should there be a loop before the first cout statement that holds till the third cin statement?
if you just want to two numbers then you don't need anyones name first of all. Second, do you plan to input all of these numbers? If so, I would store the numbers first into an array, and then manipulate the arrays separately. running a loop the size of your class and inputting them would be an annoying way to carry through this.
1. Your three arrays all have number elements, so unless you're doing something fancy with dynamically-allocated arrays, number needs to be a constant that is known at compile time.
2. You have declared the three arrays twice each: once at the gobal level, and once inside main.
3. If you have a small number of student names and their letter grades and marks to enter, you can use a for loop that looks like this:
Code:
for (int i = 0; i < number; i++)
  cout << "Student name: ";
  cin >> name[i];
  // Prompt for letter grade in a similar way
  // Prompt for mark in a similar way
