Do these two cancel each other out?
  • Thread starter Thread starter XIshaX
Mixing two handwashes, one containing sodium benzoate and the other containing methylchloroisothiazolinone, methylisothiazolinone, and potassium sorbate, is unlikely to cancel out their antibacterial effects. Sodium benzoate is the primary antibacterial agent in both formulations, and the presence of other ingredients in handwash 2 does not interfere with the effectiveness of handwash 1. However, handwash 2 is specifically designed for antimicrobial purposes, so it is advisable to use it alone for optimal antibacterial benefits. Mixing them will not enhance their antimicrobial properties.
XIshaX
I'm wondering if by mixing these to handwashes, the antibacterial effect of both is cancelled.
Handwash 1: Aqua, Sodium Laureth Sulfate, cocamidopropyl betaine, sodium chloride, glycerin, polyquaternium-7, parfum, sodium benzoate, lactic acid, tetrasodium glutamate diacetate, benzotriazolyl dodecyl p-cresol, limonene, hexyl cinnamal, butylphenyl methylpropional, linalool, CI 42051
Handwash 2: Aqua, sodium laureth sulfate, sodium chloride, citric acid, cocamidopropyl betaine, sodium benzoate, cocamide DEA, disodium EDTA, glycerin, PEG-7 glyceryl cocoate, chamomilla recutita flower extract, methylchloroisothiazolinone, methylisothiazolinone, potassium sorbate
Any idea?
Thanks
Chemistry news on Phys.org
XIshaX said:
, , methylisothiazolinone, potassium sorbate
Any idea?
Thanks
In both cases, the main antibacterial is sodium benzoate. They won't interfere with each other.
The second handwash has methylchloroisothiazolinone, methylisothiazolinone, and potassium sorbate. It is unlikely that anything in the first handwash would interfere with these, but I don't know.
Here's the ingredients for the first one:
Aqua: water
Sodium Laureth Sulfate: a soap and surfactant
cocamidopropyl betaine: a natural mix, a surfactant
Sodium Chloride: salt
glycerin: probably included to provide a sweet scent
polyquaternium-7: antistatic or "fabric softener"
parfum: fragrance
sodium benzoate: preservative, this is your first antibacterial agent, it requires an acid environment to be effective
lactic acid: and here's you acid environment
tetrasodium glutamate diacetate: preservative booster (antibacterial)
benzotriazolyl dodecyl p-cresol: protects this mixture from UV
limonene: orange scent
hexyl cinnamal: fragrance
butylphenyl methylpropional, fragrance
linalool, fragrance
CI 42051: blue coloring
Additional ingredients in second one:
citric acid: provides acid environment and perhaps fragrance
cocamide DEA: foaming agent
disodium EDTA: water softener
PEG-7 glyceryl cocoate: skin conditioner
chamomilla recutita flower extract: fragrance
methylchloroisothiazolinone: antibacterial
methylisothiazolinone: antibacterial
potassium sorbate: antibacterial
Likes Merlin3189
Aqua: water
parfum: fragrance
linalool, fragrance
Wow - thank you so much for that detailed reply! I'm pleased that you've explained what the different ingredients do - always wanted to know that!
So, it looks like handwash 1 wouldn't be weakened by handwash 2, but it's possible that handwash 2 is weakened by handwash 1. Have I got that right?
It is very unlikely that either will interfere with the other. But if you are looking for an antimicrobial handwash, stick with handwash 2; it was specifically developed for that. Mixing it with handwash 1 won't make it more antimicrobial.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
