Do Vectors a, b, and c Satisfy the Right Hand Rule?
The discussion revolves around determining whether the vectors a=(1,2,3), b=(-1,2,-1), and c=(0,1,-2) satisfy the right-hand rule. Participants explore the relationships between these vectors, particularly through the concepts of cross products and dot products.
  • Participants discuss the necessity of the cross product of a and b equaling c to satisfy the right-hand rule. There are questions about how to determine if vectors are perpendicular and the implications of the dot product being zero. Some participants express confusion about the relevance of vector c in this context.
The discussion is active with multiple interpretations being explored. Some participants suggest that linear independence of the vectors may be sufficient for satisfying the right-hand rule, while others focus on the calculations involving dot and cross products. There is no explicit consensus yet on the correct approach.
Participants are navigating the definitions and properties of vector operations, including the right-hand rule, without complete clarity on how these concepts interrelate in this specific case. The original poster expresses confusion regarding the requirements for the vectors to satisfy the right-hand rule.
Grawr
1. Homework Statement
Let a=(1,2,3) b=(-1,2,-1) and c=(0,1,-2). Do these vectors taken in this order, satisfy the right hand rule? Explain.
3. The Attempt at a Solution
I was told a cross b must equal c otherwise this is not satisfying? I'm VERY confused...can someone help out please and thanks?
The cross product of a and b is perpendicular to both a and b.
how can you tell if two vectors are perpendicular?
Two vectors are perpendicular if the dot product is 0. So for example a cross b = c
So then a dot c should equal 0 and the same should go for b dot c. So if both do equal zero it must mean they do satisfy the rule correct?
EDIT: Ok nvm that does not help me out at all in my question.
and if a dot c is not zero or b dot c is not zero, c cannot be the cross product of a and b.
Hmm so how does the c=(0,1,-2) play a role in here?
the fact that c=(0,1,-2) obviously plays a role in calculating the dot product of a and c or b and c.
You don't have to take cross products, all you need is that they are linearly independent and they are.
If you define the x-axis to point along a, y-axis to point along b and z-axis to point along c would your coordinate system be right handed? If so, then a-b-c in that order satisfies the right hand rule.
  • · Replies 18 ·
13K
