Does 0.000...1 equal 0?
  • Level: High School
  • Thread starter cyclogon
14 replies · 4K views · last reply
cyclogon
Sorry if the question has been asked before, but is there any proof that 0.00...1 equals 0?
Or not, as the case may be
Thanks for any replies :)
What is
cyclogon said:
0.00...1
? Where is the one placed at?
Here's a more interesting example. Consider the function ##x \longmapsto e^{-(x-n)^2}##. For ##n=10## it looks like
Plot of a bell-shaped curve peaking at y = 1.0 when x = 10, with a vertical blue line marking x = 10; x-axis runs from 8.5 to 11.5 and y-axis from 0 to 1.0.
and the greater ##n## is, the more to the right is the bump. The area below the curve is ##\int_{-\infty}^{+\infty} e^{-(x-n)^2}\, dx \,=\, \sqrt{\pi}\,##. If we move it to infinity, then it is still the same bump with the same area ##\lim_{n \to \infty} \int_{-\infty}^{+\infty} e^{-(x-n)^2}\, dx \,=\, \sqrt{\pi}##. However, if we first move the bump to infinity, we get ## \lim_{n \to \infty} e^{-(x-n)^2} = 0## and the area ##\int_{-\infty}^{+\infty} (\lim_{n \to \infty} e^{-(x-n)^2})\,dx ## vanishes with it. This is the same with your ##1##. If we move it to infinity, it vanishes, because wherever we look, we are left from the bump and arbitrary close to zero, the bump is never reached.
  • Plot of a bell-shaped curve peaking at y = 1.0 when x = 10, with a vertical blue line marking x = 10; x-axis runs from 8.5 to 11.5 and y-axis from 0 to 1.0.
There's a huge difference between 0.999... and 0.000...1 that is alluded to in post #2. In the first expression, the ellipsis (...) means that the same pattern of 9 digits repeats endlessly, so that each position to the right of the decimal point contains the digit 9. In the other expression, it's not specified where that 1 digit is, making it not well-defined.
Perhaps better written as $$\lim_{n\to \infty} \frac{1}{10^n}=0$$
But keep in mind that is the limit. And that is different than zero.
hi, thanks for all your replies. Sorry about not explaining clearing enough.
The "1" is at the end of a length of infinitely many zeros
ie. 0.0000000...(infinte zeros)...1 Thanks
Yes, I think people probably realized that's what you meant, but there is no such thing which is why folks are saying that it's undefined. If you get to a point where you can put a 1, then you are not yet at infinity so your statement is nonsensical/undefined.
This is a self-contradiction: if the string of zeros is infinite, it doesn't have an end. That's why that expression doesn't work isn't used in math.
That limit is not different from zero. It is precisely zero. As one can see from the epsilon/delta definition of a limit.
To be picky, one could index the digits in a decimal string over a set of positions with order type omega plus one. The difficulty is not that this is a self-contradiction. The difficulty is that the resulting digit strings do not naturally form an algebraic field.
Perhaps I should have said the limit is zero but the sequence 1/10, 1/100, ... is never precisely zero.
The sequence, which is just a list of numbers, is never precisely anything. This sequence converges to zero, although no element of the sequence is zero.
I would phrase it that "no term of the sequence is zero".
Edit: Beaten to it by @Mark44
Thank you all, for your time in answering this question. Although I cannot add anything more to the discussion, I am still fascinated by the replies. Thanks :)
