Does 1/n(log(n))^2 converge or diverge
  • Thread starter Thread starter grossgermany
16 replies · 31K views · last reply
grossgermany
Does 1/[n(log(n))^2] converge or diverge
We know that Does 1/[n(log(n))] diverges by integral test
No sir, 1/[n(log(n))] diverges, comparison test would not help in this case.
Most unfortunately both ratio test and limit comparison test give you 1 which is inconclusive.
EDIT: Never mind, I think I misread the question.
Just to make sure, it's x log^2(x), not (x log(x))^2, right?
Char. Limit said:
Have you tried integrating [tex]\int \frac{dx}{x^2 log^2(x)}[/tex]?
It requires the Exponential Integral function Ei(u) to even be possible.
From the way he wrote it, it looks like it should be
[tex] \frac{1}{n (log(n))^2}[/tex]
But if you are right that he meant x^2 log^2(x) then it is trivial.
Hint: log^2(x) > 1 for x > 3.
Unfortunately I have never tried the Ei(u) thing. Nor have I heard of integral function.
In other words 1/[n(log(n))^2] diverges?
Yes, the integral test, however please tell me how to evaluate this integral? I suspect the result would be some expression that goes to infinity.
Wait, before we continue.
We need to know your bounds.
Is the initial n n=1?
Or is the initial n n=2?
How to evaluate
[tex] \int_{2}^{\infty} \frac{1}{x log^2 (x)} dx[/tex]
that?
Think back to Calc II. Try a u-substitution.
You can also use a "bare-hands" argument, without the integral test. Imagine that the natural logarithm were instead a binary logarithm (it's just a constant factor different), and estimate the sequence by blocks whose boundaries are powers of 2.
grossgermany said:
initial n=2
Then an integral test will work just fine. Just do as l'Hopital suggested.
