Does AB = I Imply BA = I for Square Matrices?
  • Thread starter Thread starter zohapmkoftid
18 replies · 47K views · last reply
zohapmkoftid
Let A and B be n × n matrices. Show that if AB = I, then also BA = I, so A and B
are invertible, A = B−1 and B = A−1.
How can I prove this?
Thanks
How do you think you should go about solving the problem? Show some work!
Sorry, I have no clue about this question. I found some solutions on the web but they are related to vector space which I haven't learned yet
fzero said:
Can you compute ABA?
The thing confuses me is the definition of inverse
B is the inverse of A if AB = BA = I
B is the inverse of A if AB = I
Which one is the correct definition?
ABA = IA
A-1ABA = A-1A
BA = I
You're supposed to show that if AB = I, then BA=I as well, so the two definitions are equivalent.
ABA = IA
A-1ABA = A-1A
BA = I
This isn't a proof since you assumed the existence of the inverse of A, which is what you're trying to prove.
Could you give me some hints?
You're given AB = I. You can therefore show that ABA = A. What about BAB? What can you conclude about BA given what happens when you multiply with it on the left or right of these matrices?
ABA = A
BAB = B
We can conclude that BA = I ?
zohapmkoftid said:
1. Homework Statement
Thanks
As Scotty from Star Trek would say, Damn it man :)
Well You know the property of the invertible [tex]n \times n[/tex] matrix which states
[tex]AB = I[/tex] which by inturn mean that [tex]A \cdot A^{-1}=I[/tex]
If [tex]B = A^{-1}[/tex] then also implies [tex]BA = I[/tex]
Back then I went to High School during the Clinton years I learned
Let a be a real number then if you say [tex]a \cdot a^{-1}= 1[/tex]
e.g. [tex]5 \cdot 5^{-1} = 1[/tex]
What you need to realize, man.
Let A and B be two square matrices of equal size which means that
[tex][a_1 \ a_2 \ \cdots \ a_n] \cdot B = A \cdot B[/tex] exists (remember that the Matrix-Matrix product only exists if you can use the row column rule from lin-alg).
We know that the basic property of the invertible square matrices is
then by letting [tex]B = A^{-1}[/tex] then by the row-column rule
[tex][a_1 \ a_2 \ \cdots \ a_n] \cdot A^{-1} = A \cdot A^{-1} = I[/tex] Thus
[tex]A\cdot B = I[/tex]
Then you can easily show the other way BA = I yourself :)
But the problem did not say, initially, that A and B are invertible. That was one of the things to be shown.
HallsofIvy,
I know you have the ability to use the force at a higher level than the rest of us.
But the assigment does say
"Show that if AB = I, then also BA = I, so A and B
are invertible."
In my opinion it all comes down to how you read the problem at hand.
1) For A and B to be invertible then they must live up to AB = I, which implies that either
AA^-1 = I if B = A^-1. Or if BA = I which implies that A = B^-1.
2) Hence then for the matrix product to exist then it has to live up to the row column rule. Then I choose A and B to be square matrices, then A*B = AB exists.
3) For A to be invertible then A has to be non-singular. Then if A is non singlar and I replace B with A^-1 and since we know that AB = I, then A is invertible.
Same goes if you if reversed then you will arrive that A and B are both invertible. Hence both AB = I and BA=I.
Can I prove like this?
AB = I
det(AB) = detI
(detA)(detB) = 1
detA != 0 and detB != 0
Therefore, A-1 and B-1 exist
AB = I
A-1AB = A-1
B = A-1
BA = A-1A
BA = I
Susanne217 said:
HallsofIvy,
are invertible."
The problem description is clear, with little room for interpretation. We are given that AB = I, with A and B n x n matrices.
You are starting by assuming that which is to be proved.
uvc29 said:
It can poove by taking an example
No, you can't. A single counterexample works just fine for disproving some conjecture but an example does not suffice for proving some conjecture.
AB = I
det(AB) = detI
(detA)(detB) = 1
AB = I
A-1AB = A-1
B = A-1
BA = A-1A
BA = I
While there's nothing wrong with what you wrote, I don't think it was the intent of the problem. The idea is to show if A has a right inverse B, B is also its left inverse. Then by definition A and B are invertible and are inverses for each other.
It there's a more straightforward proof than what I'll suggest, I don't see it, but then I've never been particularly good at figuring out clever manipulations. Start by showing that if you have a vector c, you can always find a solution x to the equation
xTA = cT
In particular, you can find a solution when c is equal the i-th column of the identity matrix. Combine all n equations into one matrix equation and use the fact that the identity matrix is equal to its transpose to show BA=I.
Susanne217 said:
HallsofIvy,
are invertible."
No, that's wrong. In order for A and B to be invertible, both AB= I and BA= I must be true.
I don't think this is enough.
You can't prove this only using the group properties.
Prove instead that (BA-I)b=0 for any nx1 matrix b
Then show that the components of BA-I are 0 by choosing specific vectors b
