Mentor
- 2,467
- 3,620
I would be very surprised if anybody, anywhere, with the best software available could create a simulation capable of analyzing this problem with reasonable accuracy. That is because it is multiphysics - impact forces coupled with hydrodynamics. The situation is even more difficult if the impact is sufficient to cause yielding or complete failure of any solid component. My experience with nonlinear dynamic analysis is that all analyses need to be compared to experimental results, and that those experiments need to be sufficiently similar to the analysis.skywalker09 said:there’s no testing planned. But, we’re hoping to improve simulation by accounting for surrounding fluid.
There are analysis techniques that supposedly work in simple cases. What little I have read on the subject compared kinetic energy to the energy to plastically yield a simple shape. I do not recall anything for your case of low velocity with high momentum. Water will probably have a large effect because the mass of water affected by movement of the plate is much larger than the mass of the plate. Unless the impact is a such low velocity that inertial effects are minimal.skywalker09 said:Is it possible to write kinematic or energy/momentum equations for such collision in air? How to consider effect of fluid?
All of which sent me down a rabbit hole when I searched for, and found, videos of low speed impacts in water using search terms ship hitting dock.
In your case, an analysis good enough to get usable results would almost certainly cost more than an experiment. The experiment would be needed to confirm the analysis. And if you did the experiment, you might not need the analysis.
