Does differentiating under the integral sign reverse the integration?
  • Thread starter unscientific
    Integral
12 replies · 3K views · last reply
unscientific
The question is as attached in the picture.
I haven't got to the answer, but I wonder if this is OK:
g(y) = ∫ f(x,y) dx
= F(y) - F(0,y)
(dg/dy) = f(y) - f(0,y)
Since the 'x' is just a dummy variable where the final function g will be in terms of y. By integrating it with respect to x, then filling it in with 0 and y, by differentiating g does it reverse back the integration process and simply filling it with 0 and y?
  • Textbook problem 5.31: f is differentiable with f(0)=0, and g(y) is defined as the integral from 0 to y of f(x) dx divided by the square root of (y minus x).
I don't see any question in that picture.
Sorry that was just part of the question, I am trying to find out if its OK to do the steps above.
g(y) = ∫ f(x,y) dx
= F(y) - F(0,y)
I can't follow this. ##g(y) = \int f(x,y)\, dx## doesn't make any sense to me. It's an indefinite integral and surely there would be an ##x## on the left side. Then you have ##F(y)-F(0,y)##. I gather that is supposed to represent an antiderivative, but is ##F## a function of one or two variables? Then in your last line you have ##f(y) - f(0,y)##. But ##f## is a function of two variables, so ##f(y)## is meaningless.
Anyway, whatever it is you are trying to do, try it with ##f(x,y) = y^2\cos(x)## or something like that. It has to make sense and work for something simple to have any chance of being true in general.
Sorry the integral is meant to be a definite integral as in the question, I'm not sure how to use latex...
How about if
g(y) = ∫ f(x,y) dx (definite integral)
= F(y,y) - F(0,y)
then
dg/dy = f(y,y) - f(0,y)
Does this make more sense?
You have the right idea, but the steps you're using are wrong. The function in the integral is not a function of x and y, it is solely a function of x, so your antiderivatives in the second part don't make any sense.
How about if
= F(y,y) - F(0,y)
then
Integrate the function in the integral with respect to x while keeping y constant.
Yes that's right but are my steps right? I'm concerned about the conversion from 'F' to 'f' by differentiation. Since they are entirely in terms of y after integration.
How about if
= F(y,y) - F(0,y)
then
You don't need to use LaTeX (although some posters might complain if you don't), but you DO need to write things explicitly. For example, if you want to write
[tex]\int_a^b f(x,y) \, dx[/tex] in plain text you can just write int( f(x,y) dx, x=a..b), for example.
RGV
Lleibniz integral rule:
[tex]\frac {d} {dy} \int_{a(y)}^{b(y)} f(x, y)dx = \frac {db(y)} {dy} f(b(y), y) - \frac {da(y)} {dy} f(a(y), y) + \int_{a(y)}^{b(y)} \frac {\partial} {\partial y} f(x, y)dx[/tex]
Would it apply, because the function isn't continuous over [0,y]?
OP, try integrating by parts.
EDIT: It worked for me. Integrate by parts and then fundamental theorem of calculus combined with the hint that f(0) = 0.
And then the Leibniz rule :)
