Does gravitational time dilation imply spacetime curvature?
230 replies · 25K views
PeterDonis said:
Hm. So you're saying an alternate version of Schild's argument could be formulated, which says that, since the "SR with gravity" theory predicts that geodesics of the Minkowski metric locally maximize proper time (even if they're not free-falling worldlines), if this theory were true, you could set up Schild's scenario locally, and derive a contradiction using local measurements--use the "maximal proper time" criterion to mark out the two opposite geodesic sides of the quadrilateral, and then observe that gravitational time dilation makes them have unequal lengths, which would not be possible in a flat spacetime.
Not quite. I'm saying if we really lived in a universe consistent with SR gravity, you would find:
1) There is no gravitational time dilation; there is 'pseudo-gravity time dilation' in an accelerating rocket. This would be a violation of the Einstein Equivalence Principle; only the WEP (Weak Equivalence Principle ) would hold in this universe.
2) Globally defined straight lines also maximize proper time.
As a result of verifying this, you could, in principle find geodesics locally by maximizing proper time. You could then locally set up an instance of Schild's quadrilateral near a planet that had no contradiction because gravitational time dilation cannot exist in such a universe (by Schild's argument).
In a rocket, you could try assuming you might be sitting on a planet and that the back and front traced out geodesics. You would then find that pseudo-gravity time dilation disproved your assumption and you would know you these are not geodesics.
PeterDonis said:
As you've stated it, no, it isn't, it's just a tautology, because "free fall" and "inertial motion" mean the same thing in the usual usage of those terms.
That might be true today, but that's because the equivalence principle implies that they are the same thing, so there is no need for two different notions. But conceptually, they are not the same. Inertial motion is the path that an object takes in the absence of forces acting on it. Freefall is the path an object takes when the only force acting on it is gravity. In a theory in which gravity is a force, then they are different.
But in normal usage, this would be called geodesic motion, not "inertial" motion. So a better way of phrasing your version of the EP would be: "locally, there is no way to distinguish between free fall motion and geodesic motion".
So you are saying that freefall and inertial motion mean the same thing, and that inertial motion and geodesic motion mean different things. I would disagree with both of those, but I guess it's just a matter of definitions, and you can use whatever definitions you like.
PeterDonis said:
But in any case, maximizing proper time is not the criterion Schild is using; he is using the clearly nonlocal criterion that "geodesic" worldlines are the ones that are at rest relative to observers far outside the gravitational field.
I don't see how that makes sense, because there is no absolute notion of "rest".
It seems to me that implicitly, he's assuming that there is an inertial coordinate system in which the gravitational field is time-independent, and then he's defining inertial motion to mean at rest relative to that coordinate system. Or maybe you can just say that the geodesic worldlines are ones that are rest relative to some inertial observer far from the source of gravity?
Let me motivate the modern notions of equivalence principle as described in the Living Review article I have linked a couple of times in this thread. This approach has many advantages over ill defined heuristics or overly narrow technical definitions.
1) The modern definitions are precise and well defined.
2) Being phenomenological, and separating the equivalence principle into different components, you can define different strengths of the principle, all of which can be applied as tests of even wholly non-metric theories, where notions of covariant derivative are irrelevant. Thus you have the WEP (weak), the EEP (Einstein, not really a good name), and SEP (strong). Non metric theories (e.g. Newton's, or the non-metric SR theory discussed in this thread) of gravity observe the WEP only. The broad class of metric theories, including e.g. Brans-Dicke theory observe the EEP universally, but fail to observe the SEP. So far as is known, despite great effort, it appears to be impossible to construct a theory that makes different predictions from GR (even just in very strong gravity regions) without violating the SEP. GR appears to be the unique theory consistent with the SEP.
3) Being strictly local by definition, you don't worry about specialized scenarios when they apply. A theory is said to observe a strength of EP only if it is universally true of all solutions of the theory - everywhere and everywhen for all solutions of the theory.
PAllen said:
Let me motivate the modern notions of equivalence principle as described in the Living Review article I have linked a couple of times in this thread. This approach has many advantages of ill defined heuristics or overly narrow technical definitions.
Some questions that I've had for a long time (they may have been answered for me, but I don't remember the answers) are:
  1. Does the Lense–Thirring effect imply that the path of a particle with intrinsic spin might depend on its spin?
  2. If so, does that violate the equivalence principle? (The strong one, I guess)
Yes, all of these terms have different possible meanings in ordinary language, so it's a matter of making sure we identify the correct concepts. I agree that, conceptually, all of the following are distinct, and it's an empirical question which ones turn out to be the same:
(1) The path an object takes in the absence of all forces.
(2) The path an object takes in the absence of all non-gravitational forces.
(3) The path an object takes which makes it weightless (i.e., an accelerometer attached to the object reads zero).
(4) The path an object takes that locally maximizes proper time.
Yes, I think this is correct.
The Lense-Thirring effect as it applies to a model of a macroscopic gyroscope is no problem for SEP because it is an effect that is inherently non-local in time. It is a dynamic curvature correction over 'long' time spans.
To my knowledge, it is not clear how to represent particles with intrinsic spin in classical GR, and this is where generalizations of GR come in, e.g. Einstein-Cartan theory. These theories do, according to papers I've seen, violate the SEP. However, I really don't know much about these theories.
Just a question; if we have a very precise protractor, we can still be able to measure the sum of the angles of a small triangle on the surface of a sphere and confirm it is more than ##\pi##. Similarly, can a free faller be able to confirm his frame is not inertial when he has very precise tools for that?
Adel Makram said:
if we have a very precise protractor, we can still be able to measure the sum of the angles of a small triangle on the surface of a sphere and confirm it is more than ππ\pi. Similarly, can a free faller be able to confirm his frame is not inertial when he has very precise tools for that?
Yes. The size of a patch of spacetime over which tidal gravity effects are not observable obviously depends on how accurate your observations are.
There are ways of formulating the equivalence principle that allow for this--heuristically, this is done by taking limits as the size of the small patch of spacetime goes to zero. But that's getting off topic for this thread.
PeterDonis said:
Hm, interesting. That would mean that just showing the presence of gravitational time dilation would not be enough; you would have to look at the details of how it varied with height and show that the resulting 2-d submanifold could not be embedded in flat 4-d Minkowski spacetime. I think this could be done for the r-t submanifold of Schwarzschild spacetime, but I admit I don't know how one would go about it in any detail.
When Vera Rubin discovered the non Newtonian of galaxies everyone jumped to the dark mater conclusion. If the black hole were massive enough to gravitationally constrain the galaxy could the motion be explained by space time distortion? We are estimating that black hole size by the motion of stars within a few light weeks...measurements could be way off. Also if matter falling into the black hole is being accelerated to the speed of light could mass be generated outside the event horizon?
Why do you think so? What basis do you have for doubting the measurements?
It isn't.
No. Seen from far away, the process of an object falling into the black hole does not change the total mass of the system (object + hole) at all.
Objects deep in the gravity well would appear to move slower to someone outside the gravitational influence...Einstein
Have you done the math to see how large this effect is for an object in the closest possible free-fall orbit to a black hole? Have you checked the literature to see if they have done such calculations to estimate whether this effect is significant?
Or, at any rate, in the orbits in which the stars in question are actually observed?
Also, have you considered whether, when astronomers calculate the mass of an object based on observed orbital periods and distances, they use a formula that is in terms of the faraway observer's time? That is, the "orbital period" in the formula is the period that would be observed from far away, taking into account the time dilation effect.
Haven't used calculus since 1967(UofA engineering)
I'm just a laymen with an axe to grind with dark matter. That being said the effect assuming the current estimated black hole size probably wouldn't be significant. If the black hole was large enough to anchor the galaxy ...maybe
If relativistic effects are being accounted for ...I fold
Had an idea didn't want to take it to the grave. Maybe someone else is thinking along these lines.
Would someone observing Earth's orbit around the sun from a distance farther than the Earth itself not measure the same values from close to Earth's orbit? If not is the distant measure a faster orbit (less than a year)?
Grinding axes has no place here. If you are going to make a criticism like "measurements could be way off", you should be able to back it up.
It's correct that the effect of time dilation--the difference in orbital period/frequency as seen by a faraway observer, compared to as seen by an observer riding along with the orbiting object--won't be significant in this context. But that's not even the key point. See below.
They don't need to be. If you work out the math, you will see that the mass of the black hole can be calculated from observations of orbiting objects by a faraway observer using Kepler's Third Law (i.e., the formula ##M = \omega^2 r^3 / G##, where ##\omega## is the observed orbital frequency, ##r## is the orbital radius, and ##G## is Newton's gravitational constant) even in the relativistic case; the effect of time dilation cancels out of the formulas. So in this particular case, the Newtonian formula turns out to still be exactly correct.
The observed orbital period will be different for an observer far away as compared to an observer riding along with the Earth in its orbit. (For Earth orbiting the Sun, the difference is very small--I think about 1 part in a hundred million. But for a black hole it could be larger.)
But that's not what was being asked. What was being asked is if time dilation would have to be taken into account when computing the mass of the object from observations of orbital periods and distances, as seen from far away. The answer to that is no--see my previous post.
