Does gravity as a fictitious force do work? (GR's free-falling frame POV)?
76 replies · 14K views
TrickyDicky said:
you need to have everything written down explicitly and in the most conventional textbook way, no matter the context.
Well, I just disagree with that philosophy.
And I disagree with your philosophy of making personal attacks and demanding that people, who have done nothing but make correct statements in a conventional textbook manner, should nevertheless admit they were wrong. But yes, I can move on.
That's not my philosophy as you well know. But it's ironic that you say you disagree with that philosophy by making a personal judgement.
Really? Wish you could.
TrickyDicky said:
In the above linked thread stevendaryl argued that the equivalence failed because he could find coordinates in the schwarzschild spacetime that made the metric appear time varying. Being obvious that coordinates can introduce artifacts that don't affect the physics of the situation I still don't know what his point was wrt the physics of the problem at hand.
I was only pointing out a disanalogy between the case of (1) flat spacetime and (2) Schwarzschild spacetime. In the first case, there is a coordinate system in which an inertial observer is at rest and the metric is time-independent. In the second case, there is no such coordinate system. In Schwarzschild spacetime, any coordinate system in which a freefalling observer is at rest will have a time-varying metric.
This comes into play in the scenario under discussion because conservation of energy only makes sense for metrics that are time-independent.
What about an observer at rest in the center of the spherical mass? Isn't the metric in his rest frame time independent?
You're right. that's an interesting case, since it's the only case in which the notion of "inertial observer" and "observer at rest at constant radius" coincide.
I guess the statement that I wanted to say that only in flat spacetime is it true that every inertial observer can view himself at rest in a coordinate system with time-independent metric components.
Why conservation of energy is relevant here is because
  • In the case of a book sitting on a table in an accelerating rocket in flat spacetime, the table is doing work on the book (as viewed in free-fall coordinates) and we can account for where the energy comes from: The energy comes from burning rocket fuel.
  • In the case of a book sitting on a table on a planet in curved spacetime, the table is doing work on the book (as viewed in free-fall coordinates) but we can't account for where the energy comes from: No fuel is being used up. But in this case, there is a time-varying metric, and energy is not conserved.
What if you replace the the planet with an infinite wall?
http://www.mathpages.com/home/kmath530/kmath530.htm
Will an observer in free fall towards the wall observe a time-varying metric too?
stevendaryl said:
[*]In the case of a book sitting on a table on a planet in curved spacetime, the table is doing work on the book (as viewed in free-fall coordinates) but we can't account for where the energy comes from: No fuel is being used up. But in this case, there is a time-varying metric, and energy is not conserved.
[/LIST]
Energy is conserved in the Schwarzschild spacetime by definition. The fact that time-varying coordinates can be chosen doesn't mean energy is not conserved as long as there is some coordinate system that is time invariant. We've been thru this already. A possible cause of misunderstanding is in the use of the term "metric". This link might be useful: http://badphysics.wordpress.com/2009/10/21/metric/
Sure we can, gravitational energy, which happens to be well defined in the Schwarzschild solution (although not generally in GR).
No, in the free-falling coordinates, there is no gravitational potential energy.
First, once more the choice of coordinates doesn't affect the physics, second, you must be referring to the free falling frame, it is simply the fact that we are using as observer one whose motion is geodesic in Schwarzschild geometry.
Gravitational energy is simply that associated to a gravitational field and as I said in this particular case is well defined thanks to the timelike KV.
There are two very different meanings to "energy is conserved". One is true for any spacetime, in any coordinates, another is only true for special spacetimes for special coordinates. The differential form of conservation of energy is true in any coordinate system, in any coordinates: [itex]\nabla_{\mu} T^{\mu \nu} = 0[/itex]. In this form of conservation of energy, there is no "gravitational potential". It's a local statement.
A second form of conservation of energy is in terms of conserved quantities; quantities whose values do not change with time. This notion of conserved quantity is very coordinate-dependent. If the metric is time-varying, then there is no quantity, in general, that is conserved and independent of time.
You need to be clear about what you mean by "energy" and by "is conserved". The meaning of energy in the stress-energy tensor does not include "gravitational energy".
We've been through this already.
Yes, I know.
Nope.
That's true, but so was what I said. "Gravitational potential energy" is a coordinate-dependent quantity. In free-fall coordinates, it's zero.
GR has no notion of "gravitational potential energy", in general. You're right, that there is a coordinate-independent quantity associated with a timelike Killing Vector field, but it's extremely misleading to call it "gravitational potential energy". It plays that role in Schwarzschild coordinates, but in other coordinates, it's not meaningful to call it a potential energy.
You're getting way off track. The particular scenario that we are talking about is that of a table sitting on the surface of the Earth. In freefalling coordinates, the table does work on the book. But in those coordinates, there is no "source" for the energy imparted to the book by the table. There is no rocket fuel being burned.
For you to say that the source of the energy is gravitational energy just makes no sense. Or, at least, I don't think it makes any sense. What exactly do you mean by that? How is the table transferring gravitational energy to the book?
You bring up the existence of a Killing Vector field in Schwarzschild geometry, but what does that have to do with the table imparting energy (doing work) on the book?
I don't think your explanation makes any sense.
stevendaryl said:
In flat spacetime with an accelerating rocket, we can look at things from two different points of view: from the point of view of an inertial observer, the only energy is kinetic energy, and work must be done in order to keep the rocket accelerating.
From the point of view of an accelerating observer (Rindler coordinates), the rocket is stationary, and no work is being done on the rocket. So where does the energy used up by the rocket go? It goes into throwing exhaust gases backwards. Those exhaust gases are NOT stationary, and so work is done to get them moving backwards.
Hi I have a couple of questions.
Within the accelerating system is the total energy from the (assuming) chemical reaction
exactly equivalent to the imparted momentum to the ejected mass??
This scenario as presented seems to contradict the 3rd law of motion , no?
Also it would seem that the observers would be aware of the system acceleration both through their accelerometer and through observed increased velocities of inertial objects.
While I am here: my knowledge of electrodynamics is vague but you might know.
An electromagnet picks up (accelerates ) a ferrous mass off the ground through the air.
Work is done increasing it's PE. Once in contact the mass is still being held static against the downward acceleration of G but no work is being done because of constant PE and KE=0
My question is does this condition require additional electric draw compared to the magnet's base electric draw without the mass?
Thanks
Well, if we define "does work" as "changes energy", which seems to me to be a reasonable reading of the intent of the question, the first thing we have to answer is "which energy are we talking about?", given that GR has several different notions of energy.
It seems pretty clear that Tricky Dicky , at least, is talkig about the conserved Komar energy, also sometimes known as "the energy at infinity" ala MTW , which is the sort of energy defined in GR whenever you have a static or stationary space-time, such as the Schwarzschild metric. It may have other names, too, but Komar energy and "energy at infinity" are the two names I've heard this sort of energy called most often.
It should also be clear from using this definition that if we have a particle (book) with r = theta = phi = constant, that this Komar energy , aka the energy at infinity, is constant.
I suspect that some of the other readers in this thread are not familiar with the basic definitions of the different sorts of energy in GR. This makes it rather difficult to have a meaningful discussion, alas - the thread just wanders around in circles, which is what I think is happening here.
Then local energy isn't physics since the choice of coordinates does change energy. Not that there is anything wrong with taking that position.
Yes, you're exactly right. That could be taken to be a distinguishing difference between "inertial forces" and "real forces": inertial forces don't obey the 3rd law.
Yes, only in inertial, Cartesian coordinates is it the case that geodesics (the paths of freefalling objects) are "straight lines" (when you plot position as a function of time).
Thanks
That's a good question. I don't know the answer off the top of my head.
Well, the discussion has wandered all over the place, but I thought that the issue (or one of the issues) was that from the point of view of a local free-falling frame, the normal force on the table is pushing the book upward, and so by the usual definition of "work", the normal force is doing work on the book.
Yes they do.
Remember that in the accelerating frame, the momentum and kinetic energy added to the rocket's exhaust is *larger* than it is in the freely falling frame. So the energy burned by the fuel *is* entirely taken up by the exhaust.
Also remember that the "inertial force" of gravity on the rocket is balanced by an equal and opposite force of the rocket on the Earth. You have to include the Earth in the 3rd law analysis for everything to balance out.
This is only true in a local coordinate patch. You can't set up inertial coordinates covering the entire Earth such that the paths of all freely falling objects are straight lines.
The answer is no. If the answer were yes, you would need to hook up electrical power to a kitchen magnet to keep it stuck to your refrigerator.
PeterDonis said:
Yes they do.
SO this does seem in contradiction of the 3rd law if this is the case.
If the total energy is accounted for by the exhaust then where does the momentum/energy to provide the acceleration registered by the accelerometer come from?
i assumed we were talking flat spacetime but could you elaborate on this concept?
How is the thrust of the rocket transmitted to the earth, through the air do you mean??
Obviously a permanent magnet is a different story. I would imagine the energy in that case is stored potential from the energy/work required to organize the structure.
If that is not so then the conservation of energy regarding such a magnet is a complete mystery as they seem to be able to do an unlimited (timewise) amount of work with no apparent source of energy.
As I understand an electromagnet it does require power to create the field, DO work.
So the refrigerator analogy may not apply.
Not that your answer might not be correct, I obviously don't know, hence the question.
Don't get your frames confused. In the accelerated frame, the momentum and energy of the rocket don't change. The fact that the accelerometer reads something other than zero is irrelevant; under Newtonian gravity accelerometer readings are not how "acceleration" is defined. (Yes, I know that seems paradoxical; one of the advantages of GR as a theory, IMO, is that it *does* define acceleration, in the invariant sense, by accelerometer readings, i.e., by a direct physical observable instead of a coordinate-dependent definition.)
You can't be if the scenario includes gravity. (If you are talking about Newtonian gravity, technically "spacetime" is not a valid concept at all; but in so far as the term applies, spacetime is not flat in Newtonian gravity any more than it is in GR.)
I mean that the "inertial force" of gravity of Earth on the rocket--the force that, in the accelerated frame, is opposed by the rocket's thrust so that the net motion of the rocket is zero in that frame--is balanced, by Newton's 3rd law, by an equal and opposite force of the gravity of the rocket on the Earth. Similarly, the upward thrust of the rocket exhaust on the rocket is balanced, by Newton's 3rd law, by an equal and opposite downward force of the rocket on the exhaust.
A permanent magnet stuck to your refrigerator does no work because there's no relative motion between the two. So there's no need for energy to be expended to hold it there. If there were, as I said, you would need to have a power source hooked up to it; otherwise the magnet would be able, as you say, to do an unlimited amount of work with no apparent source of energy. (There was some work done when the permanent magnet was originally created, to align the atoms' magnetic moments; but that stored energy is not available to do work, because releasing it would remove the magnet's magnetism.)
An electromagnet does require some power to create the field; but your own statement of the scenario already allows for that, in the magnet's "base electric draw without the mass". You were asking whether, once the magnet has something stuck to it and there is no further relative motion, any *additional* energy has to be expended beyond that base electric draw. The answer to that is no.
There is confusion. If you look at my post #45 stevendaryl was talking about Rindler observers in explicitly flat spacetime. As were my questions.
So i think our discussion is a bit disjointed as we have been talking about different conditions
What happens to be conserved is the total energy, a local change of coordinates doesn't change energy globally in the system, nor affects anything locally, it is like changing the units from joules to ergs, however precisely to conserve energy globally different observers in different frames must observe different energies and frequencies for matter/radiation, it is in this context that local energy is frame dependent, it must be in order to preserve global energy conservation.
This might explain yet another disagreement we had when you were saying energy was frame dependent and I said total energy is not because energy is globally conserved (always referring to classical mechanics or GR static solutions scenarios). It is obvious that local energy is frame dependent just by looking at the gravitational redshift example.
But the local free-falling frame is not that of the table, the table is non-inertial. Work is computed by an observer considered at rest in a free-falling frame, like for instance one free-falling towards the book and table that sees them moving upwards. Remember coordinate systems are not exactly the same thing as frames.
Wikipedia:
"A frame of reference in physics, may refer to a coordinate system or set of axes within which to measure the position, orientation, and other properties of objects in it, or it may refer to an observational reference frame tied to the state of motion of an observer. It may also refer to both an observational reference frame and an attached coordinate system as a unit."
Locally energy is the timelike component of the four momentum or the time time component of the stress energy tensor. Both of which do, in fact, change under a change of coordinates. They are conserved, but coordinate dependent.
I am not saying that it is wrong to consider coordinate dependent things like components of tensors to be non physical, just that if you do so then local energy is non physical.
I'm not going to comment on the relativity discussion in this thread. But you've got this backwards! The state with all magnetic moments aligned is the ground state, and raising the temperature (and hence internal energy) will introduce disorder and demagnetize the magnet.
In order to magnetize a lump of iron, you can place it in a constant magnetic field and lower its temperature. Misaligned magnetic moments will then align with the ambient field, releasing energy over time.
But it does cost energy to generate the ambient magnetic field (e.g. by passing current through coils). As usual, in order to lower entropy in one place, you must increase it somewhere else.
PeterDonis said:
Yes they do.
Consider some arbitrary scenario in inertial coordinates in flat spacetime. Every force has a 3rd law reaction force, and these are all real forces. Now, transform that scenario to a reference frame accelerating to the right. All of the real forces still exist, but now each object has an additional inertial force pointing to the left. None of the inertial forces point to the right, so none of them are 3rd law pairs with each other, and all of the real forces are already in 3rd law pairs with other real forces. Therefore inertial forces do not always obey Newtons 3rd law.
Perhaps a clarification of what is usually meant by "non-physicality of coordinate dependent components" is in order.
IMO it usually means that their change due to a coordinate transformation doesn't imply a change in the physics of the situation, because as long as we are dealing with tensors that coordinate transformation implies the corresponding change in other component that compensates it(or the change of basis if it is a vector). That is the reason we use geoemtrical objects like tensor that are invariant to coordinate system transformations.
There's nothing more to it.
Energy has that issue in GR unlike in classical mechanics: It is well defined only locally (as the tt component of the enegy-stress tensor) in all instances where there's no timelike KV.
Doesn't Newtons 3rd imply instantaneous action at a distance? Even EM-forces don't satisfy Newtons 3rd, but they do satisfy the idea behind it (momentum conservation) by assigning a momentum to the field.
But how is it in GR? Are the inertial gravitational forces by two masses on each other always equal and opposite, in every frame which includes both masses?
