Point Conception
- 1,985
stevendaryl said:It seems that Bell's separability condition is logically something beyond locality. Without even mentioning locality, there is an assumption along the lines of:
If ##A## is correlated with ##B##, then it must be the case that one of the following is true:
Entanglement in quantum mechanics without FTL influences seems a lot like this possibility. You have distant particles, and certain measurements on them are correlated, but there is no common cause to the measurement outcomes.
- ##A## influences ##B##
- ##B## influences ##A##
- There is some common cause ##C## that influences both.
And the above would be option # 4 that is related to the viewpoint by experimental physicist Stephen Boughn :
He states that QM predicted spin correlations P(z.n) = - cos θ arises from a single particle wave function .With one electron measured with a double Stern - Gerlach apparatus with first one aligned in z direction and the second one aligned in the n direction positioned in upper arm of first detector. He shows that the correlation for +1 from first detector with +1 in second detector is again P(z,n) = cos θ. The sequences of indeterminate events in a single particle show an overall pattern. And in a spacelike separated experiment in a common rest frame the two patterns of both entangled particles taken together show a pattern in accord with predicted QM correlations
https://arxiv.org/pdf/1703.11003.pdf
