Does mass really increase with speed
  • Level: Graduate
  • Thread starter Thread starter lowemack
    increase Mass Speed
103 replies · 24K views
PeterDonis said:
But there will be some point on p's worldline to the future of that event where the rockets will move outside the future light cone of p; in other words, there will be some point after which p can no longer send light signals to either rocket. From the rockets' point of view, this will be because p is closer to the singularity than they are, to the point that any light emitted by p will fall into the singularity before it reaches them.
Yes.
Thank you for your comments, its very helpful.
Ok the penny dropped.
Referring back to the balance readout between the 2 rockets, seen from Earth and from the rockets. See post # 13.
I stated something like: since we need to take account of force transformations, the 2 sets of observers might not see the same value on the readout. This is not true.
The solution is that the balance has its own internal spring. If we also apply the same force transformation on this spring, the readout will stay pointed to the exact same point. So, although there just might exist different forces, both observers must see the same value of readout.
Yes, you've got it.
PeterDonis said:
It depends on what part of p's worldline you look at. Obviously, since the rockets move on timelike worldlines, they will remain in the future light cone of the event on p's worldline at which they left p and started accelerating.
Sorry, after overthinking that I started to be puzzled.
For simplicity A and B shall be in free fall together (no radial distance) inside the horizon. At event u B decides to accelerate in the direction opposite to the fall. Now, after the time interval dt A and B should be separated by a radial distance dr. Then however a lightpulse of A can't reach B, because A's light-cone is tipped towards the singularity.
This sounds strange however. How could B be outside of A's future lightcone having taken a time-like path? Your argument is convincing.
Any help what's wrong with my reasoning is appreciated. Further, this issue seems not within the context of this thread. Please give me a hint in case I should ask elsewhere.
Thanks
timmdeeg, remember that light cones are "attached" to *events* in spacetime, not just to observers whose worldlines pass through those events. As an observer moves along his worldline, the light cone at the event he is passing through changes.
Also, remember that light rays move in spacetime, not just space. To determine whether one observer can reach another with a light ray, it's not enough just to look at their respective spatial locations. You have to consider time as well.
Not necessarily. It's true that light can't move outward (i.e., can't increase its r coordinate) inside the horizon. But B is moving inward, so still may be possible for "outgoing" light from A to reach B; the light just has to move inward slower than A does, so B can catch up to it. When the light reaches B, that corresponds to B entering the future light cone of the event from which A *emitted* the light; but that event, of course, will *not* be in the future light cone of events further along A's worldline.
Viewed in spacetime, A's future light cone at the event where he emits the outgoing ray is indeed tipped towards the singularity, but that just means the "outgoing" side of the light cone no longer points in the direction of increasing r. It still points in the direction of increasing time, so it's still possible for B's worldline to cross it.
Btw, I should explain why I said "increasing time" just now instead of specifying a coordinate like t. First of all, Schwarzschild coordinates are singular at the horizon, and inside the horizon r and t switch roles: r is timelike and t is spacelike. So these coordinates are not good ones to use when trying to understand what's going on at or inside the horizon.
The picture of the light cones tilting inward towards the singularity comes from Eddington-Finkelstein coordinates:
http://en.wikipedia.org/wiki/Eddington–Finkelstein_coordinates
The light cones also look similar to this in Painleve coordinates:
http://en.wikipedia.org/wiki/Gullstrand–Painlevé_coordinates
In both these coordinates, r is spacelike inside the horizon, which is a lot easier to deal with. However, in these coordinates, the "time" coordinate is *also* spacelike inside the horizon! (In other words, all four coordinates inside the horizon are spacelike.) So we can't really use their time coordinates either to indicate the direction of increasing time inside the horizon.
The only coordinates I'm aware of where the "time" coordinate is timelike everywhere in a black hole spacetime are Kruskal coordinates:
http://en.wikipedia.org/wiki/Kruskal–Szekeres_coordinates
In these coordinates, light rays are always 45 degree lines, so seeing the causal structure of the spacetime is easy. For instance, these coordinates make it easy to see why everything, including light, has to move in the direction of decreasing r inside the horizon: in that region, lines of constant r are spacelike lines (hyperbolas in the upper region of the diagram), since they're more horizontal than vertical. It's also easy to see why you can't avoid the singularity: it's one of those "constant r" hyperbolas, so it's to your future no matter where you are inside the horizon. But rather than get too deep into all this, I just said the direction of increasing "time" above.
PeterDonis said:
Which means the rockets had to expend energy by burning fuel--also it means there was rocket exhaust ejected. To properly compute the invariant mass of the entire system you have to take all these things into account.
I'm not interested in the entire system but in the two objects only. For the question discussed the ejected exhaust is completely negligible.
PeterDonis said:
So if the rockets are inside the Schwarzschild radius of the system as a whole *after* they have accelerated to high speed, they must have been inside the Schwarzschild radius of the system as a whole *before* they accelerated to high speed.
Sorry, but that's rubbish. The Schwarzschild radius is limited but the starting distance between the rockets is not.
PeterDonis said:
what I said above is true no matter how the total invariant mass of the system as a whole is split up among the rest masses and kinetic energies of its parts.
I am not talking about the gravity of the whole system. I am talking about the gravity of each body.
PeterDonis said:
No, it doesn't. That is, if by "acceleration" you mean the acceleration the bodies actually feel, and which would be measured by accelerometers carried along with the bodies.
This "acceleration" is always zero because the bodies are in free fall and a free falling body doesn't "feel" any acceleration. That's not very helpful.
PeterDonis said:
If you mean something else, then please clarify what you mean.
I mean the derivation of velocity with respect to time. That's the definition of acceleration.
It most certainly is not. You are postulating rockets that can reach high relativistic speeds. Take a look at the relativistic rocket equation to see the mass ratio required to achieve a given gamma factor:
http://www.desy.de/user/projects/Physics/Relativity/SR/rocket.html
For the kinds of speeds necessary to realize your scenario, the mass ratio will be huge; so by focusing on just the two objects and ignoring all the fuel and exhaust it took to get them to their speeds, you are ignoring by far the largest energies in the problem.
You postulated a scenario such that, if we calculate a "Schwarzschild radius" using the rockets' relativistic masses, they will be inside each other's Schwarzschild radius. That limits the starting distance between them.
As I said above, you are ignoring most of the energy in the system if you focus only on the two rockets. All that energy gravitates. You can't just ignore it.
Velocity as in ordinary 3-velocity? That's frame dependent. Or velocity as in 4-velocity? That can be represented as a covariant 4-vector, but then what derivative do we take? The derivative with respect to coordinate time, or with respect to the object's proper time? It makes a difference.
The answer I gave you, that the acceleration that bodies actually feel does not depend on their velocities, is the only answer that IMO has any physical meaning, because the acceleration bodies actually feel has physical meaning. So that's the only kind I care about. That kind of acceleration is defined as the derivative of the object's 4-velocity with respect to its proper time. Since the derivative of the 4-velocity is independent of the 4-velocity itself (i.e., by applying appropriate forces to the object we can make the derivative of its 4-velocity anything we like, regardless of the 4-velocity itself), I answered that the object's acceleration is independent of its velocity.
If you care about some other kind of acceleration, or some other kind of velocity, you need to specify what kind. Just saying "velocity" or "the derivative of velocity with respect to time", as I noted above, won't do; it doesn't actually specify what you mean, because the terms "velocity" and "time" are ambiguous.
I realized after making my first response to this that you may be thinking of a scenario where the rockets are moving towards each other, not away. I was assuming they were moving away from each other.
I think that this scenario you have postulated needs to be nailed down more precisely. How about giving some actual numbers? You don't need to give many; just the following:
(1) The rest mass of the rockets. (Just one number, we'll assume it applies to both rockets.) This should be just the payload, i.e., just the part that is there when the rockets are inside each other's Schwarzschild radius according to you. As an example, the rest mass of the Apollo command module was approximately 20 metric tons (20,000 kg).
(2) The distance between the rockets whey they are supposedly inside each other's Schwarzschild radius. (This is distance as seen in the "lab" frame, the frame in which the rockets are moving at ultra-relativistic speeds.) This will fix the invariant mass of the total system.
(3) The relative directions the rockets are traveling in; this will fix the combined momentum of the rockets. (This is also to avoid the kind of confusion I mentioned above.)
Thank you for very helpful explanations, Peter.
Yes, understood, this is the point I haven't realized.
This is hard to imagine. The only layman interpretation I am aware of sounds like this: r is timelike inside the horizon, as it has only one direction, like time flows only in one direction. But the weirdness seems "only" to be a matter of the choosen coordinates and can be transformed away, you mentioned the Kruskal coordinates already.
The terminology of calling a coordinate "timelike" or "spacelike" is unfortunate since it doesn't really convey what's going one, especially if what looks like the *same* coordinate (r in this case) is said to be timelike in one coordinate chart (the interior Schwarzschild chart) and spacelike in others (ingoing Eddington-Finkelstein and Painleve). Here's what I think is a better way of looking at it:
A "coordinate" like r is really a shorthand way of referring to two different things. One is a set of surfaces in the spacetime: each surface is labeled with a unique value of the coordinate, and every event in the spacetime lies on one and only one of the surfaces. For example, in Schwarzschild spacetime, there is a set of surfaces of constant r that satisfies the above properties.
The second thing a coordinate refers to is a directional derivative: for example, r corresponds to [itex]\partial / \partial r[/itex], the rate of change of something in the "r direction". The thing to remember about this is to avoid the "second fundamental confusion of calculus" (I learned this term from George Jones, one of the mentors here, who pointed me at a reference to it in one of Roger Penrose's books): partial derivatives can change depending on what other variables are being held constant. So a coordinate defined as a directional derivative will depend on what other coordinates it is combined with in a specific chart.
You can probably see what's coming next: when you change coordinate charts, the two things above do not necessarily change together. For example, in all three of the coordinate charts for Schwarzschild spacetime that I mentioned above, the first aspect of the "r" coordinate is the same: i.e., the "r" coordinate in all three charts refers to the *same* set of surfaces of constant r. What changes from chart to chart is the directional derivative. This seems to be the usual convention for coordinate nomenclature: a given coordinate name, such as "r", is applied to a given set of curves; then the changes in the directional derivative between charts are captured by calling the coordinate "timelike" or "spacelike" in different charts, according to the direction the derivative points in.
As a concrete example, here's how things work out for all of the charts I have mentioned for Schwarzschild spacetime:
(1) The Schwarzschild chart. (Technically, there are actually two of these, exterior and interior, because the coordinates are singular on the horizon.) Outside the horizon, the directional derivatives look like this: [itex]\partial / \partial t[/itex] timelike; [itex]\partial / \partial r[/itex] spacelike; [itex]\partial / \partial \theta[/itex] spacelike; [itex]\partial / \partial \phi[/itex] spacelike. So a surface of constant t is a spacelike 3-surface; but a surface of constant r has one timelike and two spacelike dimensions. (I won't talk about surfaces of constant theta, phi here; angular coordinates work a little differently. The usual way of talking about them is just to say that, since the spacetime is spherically symmetric, we can think of it as a set of coordinate pairs (t, r), where each unique pair labels a 2-sphere, which is a spacelike 2-surface covering all possible values of theta, phi. So what I said above can be condensed to: outside the horizon, lines of constant t are spacelike, and lines of constant r are timelike, where each "line" is really a series of 2-spheres. The only exception is r = 0, which is a single point, and is not technically part of the spacetime because the curvature is infinite there--but that's a whole other post :smile:.)
Inside the horizon, the r and t derivatives switch directions: [itex]\partial / \partial t[/itex] is spacelike and [itex]\partial / \partial r[/itex] is timelike. This is what the common statements that "r is timelike inside the horizon" or "t is spacelike inside the horizon" refer to. You can also see that, inside the horizon, lines of constant *r* are now spacelike, and lines of constant *t* are now timelike. So the labeling of coordinates as "timelike" or "spacelike" will look backwards if you are looking at the lines of constant coordinate value instead of the directional derivatives.
(2) Ingoing Eddington-Finkelstein & Painleve charts. (I lump these together because they are the same in the aspects we're discussing; also I specify "ingoing" because there are also "outgoing" versions of these charts. I won't go into the difference here.) Outside the horizon, these are the same as the Schwarzschild exterior chart; [itex]\partial / \partial T[/itex] is timelike and the other three coordinate derivatives are spacelike. So (leaving out theta, phi again as above) lines of constant T are spacelike and lines of constant r are timelike. Note that we are using a different label, T, for the "time" coordinate because it refers to a different set of lines (or surfaces if we include the angular coordinates) than the Schwarzschild "t" coordinate does.
*On* the horizon (these charts are nonsingular at the horizon, so this is meaningful here), [itex]\partial / \partial T[/itex] is *null* in both charts. ("Null" means it points in the same direction in spacetime as a light ray--an outgoing light ray, in this case.) However, the other three coordinate derivatives stay spacelike in this chart. So on the horizon, lines of constant T are still spacelike, but lines of constant r are null. In fact, that is one way of stating the *definition* of the horizon: it is a null line (of 2-spheres) of constant r.
Inside the horizon, [itex]\partial / \partial T[/itex] is spacelike; this means that lines of constant r are spacelike. This is why it's impossible to "hover" at a constant r inside the horizon: you would have to move on a spacelike line, i.e., faster than light. But [itex]\partial / \partial r[/itex] is *also* spacelike inside the horizon in this chart; in other words, *all four* coordinates are spacelike inside the horizon! This seems very weird, but that's how it is; what it is really telling you is that, to get a timelike vector at all inside the horizon, you have to combine [itex]\partial / \partial T[/itex] and [itex]\partial / \partial r[/itex] with opposite signs; for example, a future-directed timelike curve will have positive [itex]\partial / \partial T[/itex] and negative [itex]\partial / \partial r[/itex]. This is just another way of saying that everything inside the horizon is forced to fall into the singularity. In Painleve coordinates, for example, an observer freely falling into the black hole from rest "at infinity" is described by the vector [itex]\partial / \partial T - \sqrt{2M / r} \partial / \partial r[/itex], where M is the mass of the hole in units where G = c = 1.
(3) The Kruskal chart. Here what we normally think of as "r" and "t" (or "T" in the Eddington or Painleve charts) are not coordinates at all: they are functions of the coordinates that are used to label curves. The actual coordinates T, X in the Kruskal chart don't have a straightforward physical interpretation, but they do have a key property that makes the chart nice for seeing the global structure of the spacetime: their directional derivatives work just like the ones for the standard Minkowski coordinates of special relativity. In other words, [itex]\partial / \partial T[/itex] is timelike everywhere, and [itex]\partial / \partial X[/itex] is spacelike everywhere, and their relationship is such that null curves (light rays) are always 45 degree lines in the chart.
In this chart, lines of constant r are hyperbolas outside and inside the horizon; and the horizon itself, r = 2M, is a null line, i.e., a 45-degree line. Actually, it is a *pair* of 45 degree lines in the "maximally extended" Kruskal chart, which is mathematically well defined but is not physically realistic (again, that's a whole other post); these lines are the asymptotes of the hyperbolas for r > 2M and r < 2M. For r > 2M, the hyperbolas are more vertical than horizontal, and for r < 2M, they are more horizontal than vertical, so it's easy to see how the nature of the r coordinate changes.
Lines of constant Schwarzschild t in the Kruskal chart are straight lines radiating from the origin (T = 0, X = 0, which corresponds to the point where the two horizon lines for r = 2M, the asymptotes of the r hyperbolas, cross). The exterior lines radiate to the left and right, and the interior lines radiate up and down. So again, it's easy to see how the nature of the Schwarzschild t coordinate changes from exterior to interior: the lines of constant t are obviously spacelike in the exterior and timelike in the interior.
Unfortunately, I don't know a simple way to describe how the lines of constant Painleve time or Eddington-Finkelstein time T (technically they aren't quite the same set of lines, but they're close) look on the Kruskal chart. But they are spacelike lines in both the exterior and interior regions.
The two rocket do have some gravitational attraction. Let us say that they start out separated by a distance L1 side by side. After 50 years Earth time we see through our telescope (at year 100 on Earth because the light had to return 50LYs) the distance is now L2 (a number smaller than L1). Likewise on the rockets the people (old people) see a distance L2. But they have aged only 1 year (pick gamma so this is so). The people on Earth conclude the gravitational force is low due to changing the separation by L1-L2 in 50 years where as the folks on the rocket conclude the force is larger due to a L1-L2 change in only 1 year. It seems like the rocket folks will think there is more force?
Is the distance "side by side" perpendicular to the direction of the rockets' motion? If so, it won't appear to change as viewed from Earth (or from the rockets, of course) due to the rockets' motion.
Yes side by side. There is a small gravitational pull. Both rocket have some mass, rest mass or rest mass time gamma we can argue about but either way they have mass and gravitational attraction and over 50 years even a small attraction adds up.
To simplify the scenario let's assume two hypothetical spherical symmetric mass distributions with identical radius r and identical rest mass m that can be superposed without any interaction except gravity. If both objects are at rest they shouldn't collapse to a black hole. That means
[itex]r > \frac{{4 \cdot G \cdot m}}{{c^2 }}[/itex]
If you need actual numbers let's take r = 1 m and m = 3.354·1026 kg (59% the mass of Saturn).
Deformations due to the tidal forces shall be neglected.
Due to the assumption above they will never be inside each other's Schwarzschild radius and if they are at rest they even can not be inside the Schwarzschild radius of the entire system. But if the bodies are moving with an identical absolute value v of the velocities this will happen for
[itex]d < 2 \cdot \left( {r_s - r} \right)[/itex]
with the common Schwarzschild radius
[itex]r_S = \frac{{4 \cdot G \cdot m}}{{c^2 \cdot \sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}[/itex]
As the distance d (measured from center to center) can not be negative this is possible for
[itex]v > c \cdot \sqrt {1 - \left( {\frac{{4 \cdot G \cdot m}}{{r \cdot c^2 }}} \right)^2 }[/itex]
With the above mentioned values this minimum velocity would be 2,602·107 m/s (8,68% the speed of light).
To avoid a resulting momentum or angular momentum it should be a head-on collision.
PeterDonis, thank you for your valuable post 71#, which improved my notion regarding the switching coordinates. It also motivated me to look into "General Relativity from A to B" by Robert Geroch. I bought this book long time ago, perhaps you know it. And I will need to digest your post furthermore.
So you are postulating two rockets, each with a rest mass 59% the mass of Saturn, and each compressed so that they are less than half a meter long (so their centers can be 1 m apart without them touching). Wow. But ok, we'll go with that. It won't take long to see the problem.
As I've said before, you left out two key part of the whole system. First, where does the energy come from to accelerate both these objects to 8.68% of the speed of light? You're talking about two objects each with 59% of the mass of Saturn. Have you calculated how much fuel they would need to have at the start? You have to *add* that fuel mass to the mass of the systems at the start.
Second, some of that starting energy isn't contained in the rockets in the final state; it's contained in the rocket exhausts. You need to account for that as well. See below.
Ok, that at least clarifies that. Here are the correct equations for your scenario (I won't bother filling in actual numbers, the issue will be obvious without that).
I have two rockets, each with a *payload* mass m, that are moving towards each other, so their combined momentum is zero. That means that the invariant mass of the two rockets combined is:
[tex]M_{total} = \frac{1}{c^{2}} E = 2 \gamma m[/tex]
where v is the velocity of each rocket (they're both the same, obviously). You have postulated that this combined invariant mass is sufficient for the rockets to be inside each other's Schwarzschild radius; that radius is
[tex]r_{S} = \frac{2 G M_{total}}{c^{2}} = \frac{4 G \gamma m}{c^{2}}[/tex]
But you have also postulated that the rockets were not within each other's Schwarzschild radius at the start, so their initial separation is greater than [itex]r_{S}[/itex], and their initial sizes are each less than 1/2 [itex]r_{S}[/itex].
To achieve that velocity, according to the rocket equation, each rocket with payload mass m must also start out with a fuel mass M given by:
[tex]\frac{M}{m} = \gamma \left( 1 + \frac{v}{c} \right) - 1[/tex]
That means each rocket starts out with a total mass M + m given by:
[tex]M + m = \gamma m \left(1 + \frac{v}{c} \right)[/tex]
*That* means each rocket starts out with a Schwarzschild radius, based on its own starting mass, of:
[tex]r_{s} = \frac{2 G \left( M + m \right)}{c^{2}} = \frac{2 G \gamma m}{c^{2}} \left( 1 + \frac{v}{c} \right)[/tex]
You will note that [itex]2 r_{s} > r_{S}[/itex], i.e,. the combined Schwarzschild radius of the two rockets at the start is *larger* than the Schwarzschild radius of the two rockets combined at the end. In other words, if the two rockets together are confined inside a black hole at the end, each rocket separately must have been confined inside a black hole at the start.
The above also implies, of course, that the combined invariant mass of the two rockets at the end is *not* the combined invariant mass of the whole system; there is still energy with a mass-equivalent of
[tex]\frac{4 G \gamma m}{c^{2}} \frac{v}{c}[/tex]
missing. This is the energy contained in the rocket exhaust.
As I said before that doesn't matter. To make any additional energy negligible you just have to keep its distant from the center great enough. Therefor we do not need to take it into account.
I do not need that because I never defined a specific method for the acceleration of the objects. It was your idea to think about rockets. So if there would rise problems from this method it is not my fold. But even with rockets there are no problems that couldn't be solved. Just make them bigger than their own initial Schwarzschild radius and let the objects release at sufficient distance to push the rockets far enough out of the way.
But you do not need any rockets. You could also use solar sails or something similar to accelerate the object (just to give you another example). The specific method and the energy needed for the acceleration is irrelevant for this Gedankenexperiment.
What I was calling the "rocket equation" is a simple consequence of the conservation of energy and momentum; those laws must be obeyed by any method of accelerating objects. All that changes is the specifics of how the energies in that equation are assigned to parts of the system. For example:
In this case the energy that pushes the solar sails still needs to come from somewhere; the "fuel mass" that I was calling M would reside at the energy source for the solar sail, and would gradually be expended as the sails were accelerated, so that what I was calling the energy of the "rocket exhaust" would now be the energy contained in the radiation that pushed the sails. But the total energy of the system would still be the same. Also, in order to keep the total momentum zero, the source of the radiation that pushes the sail has to move in the other direction, to cancel out the radiation's momentum; so some of the energy that I was calling "rocket exhaust" would actually become kinetic energy of the radiation source. I'm pretty sure that in this case the total energy of the system would have to be even higher than in the rocket case.
That is already accounted for in the equation I gave. In the final state, all that is present in each final object is the "payload" with rest mass m, which is what you are calling the "object" itself; all of what I was calling the "fuel" with original mass M is no longer there, it's been converted into energy, some of which is now contained in the "object" and some of which is contained in what I called the "rocket exhaust". The point in the case of the rocket is that, when the rocket is sitting on the launch pad, *all* of that mass is in the same place.
It's true that the latter point does *not* apply, strictly speaking, in the case of a solar sail or some similar method; the source of the radiation that pushes the sail could be anywhere, in principle. However, I have thought of yet another factor that we have not yet taken into account. Since we are talking about Schwarzschild radius and objects being inside it, we are implicitly assuming that the gravity of the amount of total mass contained in those objects in their final state is not negligible. That means that SR does not really apply to this scenario, since SR assumes that gravity is negligible.
So a correct analysis of this scenario requires GR; i.e., it requires taking into account the curvature of spacetime produced by the system as a whole. Doing that changes things a lot. I'll put that in a separate post.
Continuing from my last post, we are considering how to analyze DrStupid's scenario using GR, since the scenario implicitly assumes that gravity is not negligible and so SR is not valid:
Consider first a simpler case where the proper acceleration of both bodies is zero; we just have two objects, each with total mass 1/2 M_0 (half of the total final invariant mass in your scenario), separated by some distance r which is greater than the Schwarzschild radius associated with M_0, and initially at rest. Their mutual gravity will cause them to fall into each other; at some point, they will be separated by *less* than the Schwarzschild radius associated with M_0, and they will form a black hole. This is just a stripped-down version of the spherically symmetric collapse of a star, as in the classic Oppenheimer-Snyder paper of 1939.
There is a technical point here: since the bodies will acquire kinetic energy as they fall, their starting rest masses will be *less* than 1/2 M_0; how much less depends on how far apart they are at the start. Their *total* energy at the start is still 1/2 M_0, but not all of that energy will be rest mass. The difference can be thought of as the "gravitational potential energy" of each body in the field of the total invariant mass M_0. From a distance much greater than the initial separation of the bodies, the system as a whole will look like a single mass M_0.
The case where the two bodies are accelerated towards each other, by rockets or solar sails, or whatever, clearly can't change the final conclusion; the bodies will still form a black hole. The only difference is that, since the source of energy that accelerates the bodies may not be part of the final system, the initial invariant mass of the system (i.e., the two bodies) may be *less* than M_0, assuming the final invariant mass of the black hole that is formed is M_0. (In other words, things like the energy in the radiation that pushes the solar sails, or in the rocket exhaust, or in the momentum of the radiation source, are not part of the "system", so the system can exchange energy with other systems, whereas in the first case of purely freely falling bodies, the system was isolated and its total energy could not change.)
So you are correct that it is possible for two bodies, neither of which is a black hole, to come together (maintaining zero net momentum) to form a black hole, and I was wrong to think that was not possible. However, my answer to the original question, does the acceleration of bodies (in the sense of acceleration felt, or "proper acceleration") depend on their velocity, is still no. :smile: In both the cases I just described, the acceleration the bodies feel is specified by the scenario, and there are no constraints on what we can specify. In the first case, the proper acceleration of the bodies is always zero; in the second, it is whatever the acceleration source (rocket, solar sail, whatever) produces, and we can specify it to produce any acceleration we want, in principle, including a constant one.
As I said before the size rockets of the rockets can be much grater than their oown Schwarzshild radius. You mentioned that this already accounted for in the equation you gave but I do not see it there.
Of course this is possible but that's not the key point. Is is even possible for fast bodies that doesn't form a black hole if they come together with negligible relative velocity? I would say it is and that would mean that in this special scenario the velocity of the bodies affect their gravity even with your definition of the "amount of gravity produced".
It seems, your expectation is in agreement with http://ajp.aapt.org/resource/1/ajpias/v53/i7/p661_s1?isAuthorized=no .
Thanks for this link. I was already aware that the gravitational mass of a photon must be twice its inertial mass (due to deflection of light in gravitational fields resulting from GR or observed at the edge of the sun) but I wasn't sure whether this can be shown for relativistic bodies with rest mass too. We live and learn.
The article is behind a paywall so I can't read the text, but I strongly suspect that the authors are using confusing terminology. Calling the effect they are describing an "increase in active gravitational mass" would only be justified if the Newtonian formula for the "force" of gravity were correct. It isn't. See below.
The experimental result you are referring to for the deflection of light by the Sun is well known, of course, but it doesn't mean what you think it means. It is true that, if I do a naive Newtonian calculation of how much the light should be deflected, by dividing the light's energy by c^2 and plugging into the Newtonian formula for "acceleration due to gravity", I get an answer that is half the deflection that is actually observed. That is because gravity is not described by the Newtonian formula; it's described by the GR formula, which is the Einstein Field Equation. So trying to draw deductions from what the Newtonian formula says is not correct.
In particular, the deflection result for light does not mean that the light's "gravitational mass" is twice its "inertial mass"; to justify any such interpretation, you would have to first specify how we are to measure the light's "inertial mass" in such a way that that relationship always holds. Saying that the light's inertial mass is its energy divided by c^2 won't work, because there are other scenarios where the energy divided by c^2 is the *same* as what you are calling the "gravitational mass". (For example, put some light in a box with reflecting walls whose mass is negligible; the externally measured gravitational mass of the box will be the total energy of the light divided by c^2. This will also be its inertial mass if you try to push it and measure the ratio of applied force to acceleration.)
GR explains the "increase" in deflection of ultra-relativistic particles as a consequence of the spacetime curvature produced by the mass of the "source" object. The Newtonian formula only captures a part of the effects of that curvature, the "static" part, i.e., the part analogous to the Coulomb force in electromagnetism. But there is an additional effect analogous to the magnetic force in electromagnetism, which only appears when an object is moving relative to the source (or, equivalently, when the source is moving relative to the object); in the limit when the speed of the relative motion approaches the speed of light, this "magnetic" effect becomes equal in magnitude to the static effect. That's why light and ultrarelativistic particles deflect more.
I said "analogous to" the Coulomb and magnetic forces above, but it's important to keep in mind one crucial difference: the objects being deflected (the light or the ultrarelativistic particles) feel *zero* acceleration; they are in free fall. So the answer to DrStupid's question about acceleration depending on velocity is still no.
On re-reading, I should note that the increased deflection of ultra-relativistic particles by a large mass is often attributed to the Shapiro time delay effect (i.e., gravitational time dilation close to a mass, meaning that an object just grazing the mass spends a longer time there as seen from far away), or the space curvature caused by the mass (meaning that the objects have to travel through a larger distance), or some combination of the two. For example, see Garth's post on PF here:
https://www.physicsforums.com/showpost.php?p=842496&postcount=12
Also see Ned Wright's page here:
http://www.astro.ucla.edu/~wright/deflection-delay.html
The explanation I gave, adding a "magnetic" component to the effective "force" seen by an object moving relative to the mass (I put "force" in quotes because, as I noted before, objects moving under this "force" feel zero acceleration), is a different way of saying the same thing; all of these explanations refer to the same underlying mathematics.
My problem is to understand why "active gravitational mass of a moving object" isn't a priori in contradiction with 'mass is invariant'.
Because you're using the wrong definition of "active gravitational mass"; you're plugging numbers into the Newtonian formula for gravitational "force" and trying to read off what the "active gravitational mass" is by applying F = ma, but the Newtonian formula for F is not correct; it doesn't fully describe the actual "force" exerted by a massive object.
When you plug numbers into the correct formula for the "force" (i.e., adding in the "magnetic" force that I referred to, which is predicted by GR but is *not* predicted by Newtonian theory), you find that the "active gravitational mass" you deduce for the object via "F = ma" is equal to its inertial mass, as it should be. (This is all bearing in mind, as I noted before, that this "force" is not felt--the object in question is in free fall.)
However, as I also noted, viewing gravity as a "force" is not the recommended way to view it in GR, because even after adjusting the formula for the "force" as above, you still have to be careful about other formulas like "F = ma"; the straightforward interpretation of that formula in Newtonian terms does not work in the relativistic case. It turns out to be easier to discard the idea of gravity as a "force" altogether and view things in terms of spacetime curvature; in those terms you would predict the trajectory a particle moving at high speed relative to a gravitating mass by looking at the curvature of space and time caused by the mass, and viewing the particle's trajectory as a geodesic (the analogue to a straight line) in that curved spacetime. This gives the same answer as the "force" viewpoint (when we use the correct covariant formulas for "F" and "a").
What else? Gravitational mass is defined by Newtons law of gravitation.
As I must use Newtons law of gravitation to determine the gravitational mass it makes sense to use his definition of inertial mass too. That leads to m=E/c² in relativity and this works in every case including for light.
Of course you can also use rest mass and relativistic momentum but that leads to the same result for the gravitational mass.
You do know that Newton's theory of gravity is wrong, right? That it is experimentally falsified? Including his law of gravitation? So if you are using his laws to define "gravitational mass", you are defining something that is going to give you false predictions in regimes where his laws are known to be wrong. Particles moving at or near the speed of light is one such regime.
Again, only if you insist on using Newton's (wrong) definition. If you use the correct relativistic formulas, you get that "inertial mass" always equals "gravitational mass", in so far as those terms even have useful definitions. Or you can recognize that this whole issue is irrelevant in GR, and calculate everything using spacetime curvature without ever having to worry about "inertial mass" or "gravitational mass".
