Does pair production involve helium nuclei in creating matter?
  • Context: Undergrad
  • Thread starter Thread starter avito009
    Pair Pair production
10 replies · 2K views
avito009
Does pair production use helium nuclei for matter creation?
Pair production occurs when a photon (Light Particle) strikes a heavy nucleus, it disintegrates and produces a pair of an electron and a positron. Is that heavy nucleus of Helium?
Not normally, but it may be.
Low energy targets for pair production from light are typically metals like aluminium or copper.
Note: it is not usually helpful to think of the process as a collision or a disintegration.
In principle you only need two photons for pair production. Usually, however, one photon comes from a high-energy gamma ray and the second one is a "virtual" photon from the electric field close to a nucleus. Heavier nuclei have stronger electric fields. The nucleus is not directly affected by the pair production process.
Thr cross section for pair production increases with atomic weight.
Does it? I thought it went as Z squared.
The cross section should increase with the nuclear charge, Z, not its mass.
The cross section for normal Hydrogen, Deuterium and Tritium should be the same, even though they have different atomic masses.
It does depend on atomic number, but I believe it is more complicated
Actually I will tell you why I asked the question. Especially why I asked about helium.
Pair production is one of the primary methods of forming matter in the early Universe. So 3 seconds after the Big Bang Protons and neutrons came together to form the nuclei of simple elements: hydrogen, helium and lithium. It took another 300,000 years for electrons to be captured into orbits around these nuclei to form stable atoms.
So early on Hygrogen and Helium were created. So for pair production to happen a photon (Light Particle) should strike a heavy nucleus (Which according to me is Helium nucleus), so that it disintegrates and produces a pair of an electron and a positron.
But after reading some more I realized this could be the wrong approach as Pair Production can happen when two high energy gamma ray photons collide and an electron-positron pair are produced (Energy is converted to mass E=MC2)
Given enough energy you can produce particle-antiparticle pairs of almost anything, including protons and antiprotons.
The real question is: Why was more matter produced than antimatter?
