I Does Poisson's equation hold due to vector potential cancellation?
  • Thread starter Thread starter Bob44
    Electromagnetism
The discussion centers on the implications of vector potential cancellation in the context of two symmetrically charged particles moving apart. It is shown that the vector potential along the x-axis vanishes, leading to the conclusion that Poisson's equation holds in this scenario. However, a counterargument is presented, indicating that the divergence of the vector potential does not equal zero along the x-axis, suggesting a conceptual error in the initial assertion. The analysis emphasizes the need to consider the effects of acceleration and the proper application of the Lorenz gauge. Ultimately, the discussion highlights the complexities of electrodynamics in systems with axial symmetry and the importance of accurate mathematical treatment.
Bob44
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion.
The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is
\begin{eqnarray*}
A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\
&+&\frac{q\,[-\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+(-y)(-\dot{y})/c]_{\mathrm{ret}}}\\
&=&0.
\end{eqnarray*}
Along the ##x##-axis we have
$$A_x=A_y=A_z=0\tag{2}$$
and
$$\nabla \cdot \mathbf{A}=\frac{\partial A_x}{\partial x}+\frac{\partial A_y}{\partial y}+\frac{\partial A_z}{\partial z}=0.\tag{3}$$
Gauss's law is given by
$$\nabla \cdot \mathbf{E} = \frac{\rho}{\varepsilon_0}\tag{4}.$$
Using the expression for the electric field in terms of potentials
$$\mathbf{E}=-\nabla \cdot \phi - \frac{\partial \mathbf{A}}{\partial t}\tag{5}$$
we substitute eqn.##(5)## into eqn.##(4)## to obtain
$$\nabla^2 \phi + \frac{\partial}{\partial t} \nabla \cdot \mathbf{A} = -\frac{\rho}{\varepsilon_0}.\tag{6}$$
Now by substituting eqn.##(3)## into eqn.##(6)## it seems that we can assert that along the ##x##-axis Poisson's equation holds
$$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{7}$$
with the solution for the pair of charged particles
$$\phi=\frac{q}{2\pi\varepsilon_0(x^2+y^2)^{1/2}}.\tag{8}$$
By substituting eqn.##(2)## into eqn.##(5) ## we find that the ##x##-component of the electric field along the ##x##-axis is given by
\begin{eqnarray*}
E_x &=& -\frac{\partial \phi}{\partial x}\tag{9}\\
&\approx& \frac{q}{2\pi\varepsilon_0 x^2} - \frac{3\,q\,y^2}{4\pi\varepsilon_0 x^4}.
\end{eqnarray*}
I began with the Lorenz gauge, but the symmetry of the experimental setup appears to enforce the Coulomb gauge along the ##x##-axis.
I set up an electrodynamics experiment with an axial symmetry which causes the vector potential to vanish.
The Lorenz gauge
$$\nabla \cdot \mathbf{A} = - \frac{1}{c^2} \frac{\partial \phi}{\partial t}$$
is usually employed in electrodynamic situations so that the scalar and vector potentials obey wave equations.
But in the above example the divergence of the vector potential along the x-axis vanishes.
This implies that the time variation of the scalar field ##\phi## also vanishes.
Thus we end up with Poisson’s equation with an instantaneous solution for the scalar potential ##\phi## along the x-axis which must be wrong.
Is there a conceptual error here?
In your example in post #1, ##\large \frac{\partial A_y}{\partial y} \neq 0## for points along the x-axis. So, ##\nabla \cdot \mathbf{A} \neq 0## along the x-axis.
You can verify this explicitly for the case where the two charges move with constant speed. Expressions for ##\mathbf{A}(x, y, z, t)## and ##\phi(x, y, z, t)## in the Lorenz gauge for a uniformly moving particle can be found in standard E&M textbooks. Applying these to your two-particle example, you can show that on the x-axis, ##\large \frac{\partial A_y}{\partial y} \neq 0##, ##\large \frac{\partial \phi}{\partial t} \neq 0##, and ##\nabla \cdot \mathbf{A} = \large -\frac{1}{c^2} \frac{\partial \phi}{\partial t}##.
Likes renormalize
I presume the charges are accelerating and so would seem to radiate in the directions 45 degrees to the axes and zero along the axes.
Thread 'The rocket equation, one more time'
I already posted a similar thread a while ago, but this time I want to focus exclusively on one single point that is still not clear to me. I just came across this problem again in Modern Classical Mechanics by Helliwell and Sahakian. Their setup is exactly identical to the one that Taylor uses in Classical Mechanics: a rocket has mass m and velocity v at time t. At time ##t+\Delta t## it has (according to the textbooks) velocity ##v + \Delta v## and mass ##m+\Delta m##. Why not ##m -...
