Does Sign Convention Affect the Lagrangian in Rotational Motion Problems?
1 reply · 2K views
rolypoly3000
1. We have a cylinder of Mass M rotating about its axis. String is wound around it. Other end is connected to a spring. A mass m is attached to the spring.
The problem is to find the Lagrangian. My only issue is with finding the potential energy. The problem asks to use the distance of the mass m from center of axis of cylinder to be 'y' and length of spring to be 's'.
If I take downward positive, I can write,( with U=0 at axis of cylinder) I can write,
U=mgy + 1/2ks^2
But if I take downward negative, U= -mgy+1/2 k s^2
So using two coordinate systems will result in two different end answers for equations of motion.
Any thing wrong in what I am doing
This is just a sign convention and it should not matter in the final answer.
In this case I think that y and s are independent, right? So the equation of motion for y is just m g y'' = 0 in one convention and -m g y'' = 0 in the other, so it doesn't matter. When you are careful with the sign in imposing the boundary conditions, you should be fine.
Also, note that flipping the sign on y also flips the sign on s (so you get a different U, but that's ok - but differentiating you will lose the s^2).
So, to summarize, I don't think there is a problem. If you think there is, maybe you can post some details/
