Mentor
- 51,094
- 27,125
harrylin said:SR merely makes predictions.
Fine, s/explain/predict/ in what I wrote; it's still true.
harrylin said:This thread examines the repeated claim elsewhere that SR predicts a large accelerometer reading in free fall
I haven't made any such claim, and I don't think anyone else has either. I agree, and I suspect all the others here do too, that SR predicts zero accelerometer reading in free fall. What SR doesn't predict is that a worldline curving around a star the way the turnaround worldline of the traveling twin has to will be in free fall. You need GR to predict that.
harrylin said:Similarly, Langevin's example could be analyzed within one, resp. two universal inertial frames (the ones of SR) because the turn-around was supposed to happen so fast and over such a short time span compared to the duration of the trip that this should be irrelevant for the calculation
For the calculation of total proper time, yes. But not for the calculation of what an accelerometer will read during the turnaround. There's no way to do such a calculation in a single local inertial frame.
harrylin said:however both for CERN as well as Langevin we can only be certain if we do a GR estimation
But what you will be "certain" of is two very different things:
In the CERN case, you'll just be confirming that any single CERN experiment can be analyzed in a single local inertial frame: the corrections from spacetime curvature are too small to matter. So you'll just be confirming that the SR calculation you do in a single local inertial frame is valid to within a good enough approximation.
In the Langevin case, you'll be actually doing a calculation (of the accelerometer reading during the turnaround) that can't be done at all with SR, because it can't be done within a single local inertial frame.
