Does the (0,0) component of the Ricci tensor equal Poisson's equation?
130 replies · 36K views
"If good old Schwarzschild metric (which is a good approximation)"
The Schwarzschild Solution is an exact solution.
" is all we need, why do we spent some much time on understanding the differential geometry and curvature tensor?"
To understand the fundamental character of Nature.
GRstudent said:
This example is being made with myriads of assumptions; and furthermore, it's a weak field. Can you come up with the strong field example? Like dwarf or a black hole?
The SET you wrote down for a fluid is valid for *any* fluid, not just a fluid with a weak field; the only restriction is that it must be a perfect fluid, i.e., zero viscosity and a perfect fluid equation of state. So it would describe a white dwarf or neutron star.
However, there is one other key restriction: the SET components you wrote down are in the rest frame of the fluid--i.e., *every* small fluid element is at rest in these coordinates. That is what makes the SET look so simple; in other coordinates it would not.
This SET does *not* describe a black hole--a black hole is a vacuum solution to the Einstein Field Equation (as I think has been mentioned before). See below.
GRstudent said:
If good old Schwarzschild metric (which is a good approximation) is all we need, why do we spent some much time on understanding the differential geometry and curvature tensor?
The "good old Schwarzschild metric", by itself, only describes one particular solution of the Einstein Field Equation--a black hole. The SET is zero everywhere. There are lots of other solutions that describe other kinds of spacetimes.
Check out this Wikipedia page and the pages it links to:
http://en.wikipedia.org/wiki/Solutions_of_the_Einstein_field_equations
ApplePion said:
I hope my notation is understandable.
It would really help if you would take a few minutes to learn how to use the forum LaTeX feature.
[itex]R_{\mu \nu} = g_{\mu \nu}[/itex]
Find [itex]G_{\mu \nu}[/itex]
What is this supposed to mean? If you are using [itex]R_{\mu \nu}[/itex] and [itex]g_{\mu \nu}[/itex] with their standard definitions (Ricci tensor and metric, respectively), then your equation is simply false.
Looks like pure dark energy to me.
[tex] \begin{align}<br /> \kappa T_{\mu \nu} &= G_{\mu \nu} \\<br /> &= R_{\mu \nu} - \frac{1}{2} R g_{\mu \nu} \\<br /> &= g_{\mu \nu} - \frac{1}{2} g^\alpha_\alpha g_{\mu \nu} \\<br /> &= g_{\mu \nu} - 2 g_{\mu \nu} \\<br /> \kappa T_{\mu \nu} &= -g_{\mu \nu}<br /> \end{align}[/tex]
PeterDonis said:
But is it even possible to have the Ricci tensor equal the metric in the first place?
Yes, this is de Sitter space.
Here is another way to look at it. Start with the stress energy tensor for dark energy [itex]\kappa T_{\mu \nu} = - g_{\mu \nu}[/itex]. This, together with Einstein's equation and some manipulations, leads to [itex]R_{\mu \nu} = g_{\mu \nu}[/itex].
You guys seem to misunderstand what I was trying to say. I meant 2d Sphere. So on a surface of a sphere, the metric tensor is just the Einstein tensor.
[itex]R_{\theta \theta}=1[/itex]
[itex]R_{\theta \phi} = 0[/itex]
[itex]R_{\phi \phi} = sin^2(\theta)[/itex]
Now, I am trying to calculate the Einstein tensor using these Ricci components. So I got that [itex]G_{\theta \theta}=0[/itex] and [itex]G_{\phi \phi}= sin^2(\theta)-\dfrac{1}{sin^2(\theta)}[/itex]. Please check my answers! Thank you.
I got that the metric tensor was equal to the Ricci curvature tensor, and that the Einstein tensor was 0.
^ yeah that's true. Why Einstein Tensor is zero on a 2d sphere (not in mathematical view)?
[itex]R_{\phi \phi}=sin^2(\theta)[/itex]
[itex]G_{\theta \theta} = R_{\theta \theta} - \dfrac{1}{2} g_{\theta \theta} R[/itex]
[itex]G_{\theta \theta} = 1 - \dfrac{1}{2} 2[/itex]
[itex]G_{\theta \theta} = 0[/itex]
and
[itex]G_{\phi \phi}= R_{\phi \phi} - \dfrac{1}{2} g_{\phi \phi} R[/itex]
[itex]G_{\phi \phi} = sin^2(\theta) - \dfrac{1}{2} sin^2(\theta) 2[/itex]
[itex]G_{\phi \phi} = 0[/itex]
WHY?
There aren't enough degrees of freedom. The Einstein tensor is zero for any 2-dimensional manifold, not just for S^2.
That is as clear as day. Again, WHY? W H Y ?
What are you talking about? What degrees? Fahrenheit or celsius?
Isn't the integrand for the Gauss Bonnet quantity in 2 dimensions the square root of negative g times the Riemann Scalar?
If so, then any variation in that quantity will be zero because the topology does not change. But that same quantity is the Lagrangian density for General Relativity--its variation gives the Einstein tensor. So the Einstein tensor in two dimensions must vanish.
If you don't know what "degrees of freedom" means then you are probably in over your head.
GRstudent said:
I don't really understand what are you trying to explain yet I came up with another idea. If Einstein Tensor on a 2d Sphere is zero then the energy density on the sphere surface is zero as surface doesn't have any energy. Yet it is strange somewhat because the source of gravity is not only mass but also momentum, so when we take 2d sphere on the Earth, we shouldn't get 0 because Earth is in orbit 30km/sec. So this is unclear.
Nonsense.
I am not interested in your "probabilities" and "conclusions".
Rude, arrogant and ignorant. Are you a child ? Someone should teach you some manners.
If you don't wish to help me--fine. Ignore this thread.
Degrees of freedom are ways in which something can change. So, in 4D a t vector can deviate in the x direction while going around a yz loop, or it can deviate in the z direction while going in a xz loop, or ... there are lots of different ways. Not so in 2D.
If you just go through the definitions and calculate the Riemann curvature tensor of an arbitrary metric in 2D and then contract it down to the Einstein tensor then you will see that everything will cancel.
Btw, you are being a little impolite. Please make an extra effort at civility.
But when I chose to do just this, i.e., I when I decided that I no longer wanted to try and help, and that I wanted to ignore the thread, you went back and edited an earlier post in order to direct sarcasm towards me.
In 4-dimensional spacetime, the Riemann curvature tensor has 20 independent components, the Ricci tensor has 10 independent components, the Ricci curvature scalar has 1. This makes sense, because Ricci is a contraction of Riemann, and the curvature scalar is a contraction of Ricci. In a 2-dimenional space, however, the Riemann curvature tensor, the Ricci tensor, and the Ricci curvature scalar all have just one independent component.
Consequently, it seems plausible to me that
[tex]R_{\mu \nu} - \frac{1}{2} R g_{\mu \nu}[/tex]
vanishes for 2-dimensiona spaces. Plausible, but I can't just "see" it, and I need to use math to verify it. You wrote
to which I don't have an answer. I have to use math. This is (just) one reason that I chose to ignore the thread.
For 2-dimensional spaces,
[tex]R_{\mu \nu} = K g_{\mu \nu},[/tex]
where [itex]K[/itex] is a function of position. Thus, in two dimensions,
[tex]R = R^\mu_\mu = K R^\mu_\mu = 2K.[/tex]
Using the above two equations in the Einstein tensor gives zero. This is a general result for 2-dimensional space, and not something special about 2-dimensional spheres.
Do you really want to look at Einstein's equation for 2-dimensional spacetimes, or do you want to look at Einstein's equation's equation for a 4-dimensional spacetime and project the results on a 2-dimensional surface? These are two quite different things?
This idea seems to make some sense to me.
This is not about dimensions. I was just looking for a concrete example of EFE in use. I mean, if EFE is such a big topic in physics, there must be some real application of this.
The point of me asking for 2d was only because in 2d, Ricci has non-zero component so in this case, it was more interesting for me to understand this.
Besides, FRW metric (which is extremely complicated) I would like to get a standard case, when [itex]G_{\mu \nu}[/itex] has non-zero components.
But the 2-dimesional case is not interesting physically precisely because of the lack of degrees of freedom. For this case physicists sometimes add extra degrees of freedom, like a dilaton field.
I don't know of a simple example that has non-zero T. Other interesting cases that have non-zero T are the Schwarzschild constant density spherical "star" (different from the "standard" Schwarzschild solution), Oppenheimer-Snyder collapse, and the Vaidya solution.
Sounds interesting to me. Where can I find more details about this? Can you write down its components (T or G)?
Here is the metric, which is treated in many relativity texts (e.g., texts by Schutz, by Hobson, Efstathiou, Lasenby, and by Misner, Thorne, Wheeler),:
George Jones said:
If the Earth is modeled as a constant density, non-rotating sphere, then Schwarzschild's interior solution can be used. When [itex]G=c=1[/itex],
[tex] d\tau^{2}=\left( \frac{3}{2}\sqrt{1-\frac{2M}{R}}-\frac{1}{2}\sqrt{1-\frac{2Mr^{2}}{R^{3}}}\right) ^{2}dt^{2}-\left( 1-\frac{2Mr^{2}}{R^{3}}\right) ^{-1}dr^{2}-r^{2}\left( d\theta ^{2}+\sin ^{2}\theta d\phi ^{2}\right),[/tex]
where [itex]R[/itex] is the [itex]r[/itex] coordinate at the surface of the Earth.
If an observer on the Earth's surface uses a telescope to look down a tunnel to a clock at the Earth's centre, he will see his clock running faster than the clock at the Earth's centre.
Consider two dentical clocks, one moving around the Earth once a day on the Earth's surface at the equator ([itex]\theta = \pi/2[/itex]) and one at the Earth's centre. Both clocks have constant [itex]r[/itex] values, so [itex]dr=0[/itex] for both clocks, and, after factoring out a [itex]dt^2[/itex], the above equation becomes
[tex] \left( \frac{d\tau }{dt}\right) ^{2}=\left( \frac{3}{2}\sqrt{1-\frac{2M}{R}}-\frac{1}{2}\sqrt{1-\frac{2Mr^{2}}{R^{3}}}\right) ^{2}-v^{2},[/tex]
where [itex]v=rd\phi/dt[/itex] is, approximately, the speed of something moving along a circular path. At the centre, [itex]v=r=0[/itex], and, on the surface, [itex]r = R[/itex] and [itex]v = 1.544 \times 10^{-6}[/itex], which is one Earth circumference in one day.
Then, with [itex]G[/itex] and [itex]c[/itex] restored,
[tex] \frac{d\tau_{centre}}{d\tau_{surf}}=\left( \frac{d\tau_{centre}}{dt}\right) \left( \frac{d\tau_{surface}}{dt}\right)^{-1} =\frac{\frac{3}{2}\sqrt{1-\frac{2GM}{c^{2}R}}-\frac{1}{2}}{\sqrt{1-\frac{2GM}{c^{2}R}-v^{2}}}[/tex].
Running, the numbers, I get
[tex] \frac{d\tau_{centre}}{d\tau_{surf}} = 1 - 3.5 \times 10^{-10}.[/tex]
Lots of places errors could have crept in, though.
I don't understand this. Where is Stress-Energy Tensor or Einstein Tensor?
George Jones showed you the Schwarzschild metric. It's a solution of the Einstein field equations for a perfectly spherical non-rotating body. You don't need either of those things to make calculations with it, since they were used to derive it.
The Einstein tensor can be calculated from the metric (R is constant); I am not going to type this into a post.
This can be inverted. Einstein's equation, together with symmetry and physical reasonableness, give rise to relativistic equations of structure for stars.
In my opinion, there are not internet substitutes for some of the excellent relativity texts.
*Every* spacetime used in GR is a solution of the EFE, so every application of GR is an application of the EFE. If you check out the Wikipedia page on solutions of the EFE that I linked to many posts ago, you will see many examples.
If you're looking for the actual mechanics of how the EFE is solved in specific cases, much of the heavy lifting nowadays is done by computers, particularly in "real applications" where the system being studied is more complicated than the simple ones for which we can write down analytic solutions.
Just out of curiosity, why do you find the FRW metric "extremely complicated"? In some ways it's simpler than other solutions that are being discussed in this thread.
