Does the Buchner funnel have a better alternative with less loss?
  • Thread starter Thread starter Biochemgirl2002
    Loss
The Buchner funnel is commonly used for suction filtration in laboratories, but alternatives like sintered glass funnels may offer convenience without the need for filter paper. Sintered glass funnels, available in various pore sizes, perform comparably to Buchner funnels with filter paper, though they can be more expensive and may pose a risk of substance loss through the pores. For optimal results, the Buchner funnel is effective when filtering larger crystals and should be used with a slow filtration technique to minimize losses. Micropore PTFE filters exhibit the least transfer loss but are not suitable for all applications.
  • Understanding of suction filtration techniques
  • Familiarity with sintered glass funnel pore sizes
  • Knowledge of micropore PTFE filter applications
  • Cost analysis of laboratory filtration tools
  • Research the performance characteristics of sintered glass funnels versus Buchner funnels
  • Explore the cleaning techniques for sintered glass funnels
  • Investigate the applications and limitations of micropore PTFE filters
  • Analyze cost-benefit scenarios for different filtration methods in laboratory settings
Laboratory technicians, chemists, and researchers involved in filtration processes who are evaluating the efficiency and cost-effectiveness of different filtration tools.
Biochemgirl2002
the Buchner funnel is used often in the lab, but i was wondering if there was a great enough transfer loss in the filter paper to switch to an alternate funnel for filtering by suction. I've looked into sintered glass funnels but i don't know if it would have the same transfer loss since the substance could get sucked through the holes as well.
Chemistry news on Phys.org
Sintered glass funnels come with different pore sizes (usually listed as fine, medium, coarse, or some variation thereof). They work about as well as a Buchner funnel with a piece of filter paper, but they're a bit more convenient in that you don't have to go begging for filter paper when you run out. That said, the Buchner funnel is usually fine as long as 1) you're crashing out decent sized crystals, and 2) you do the filtration slowly. You can always refilter if stuff pulls through.
Consider cost. Buchner and paper are cheap, sintered glass is expensive.
It would depend on your application. Small samples can suffer serious losses when using large filters. The filters I have used with the smallest losses is micropore PTFE filters but they aren’t the best for all applications.
and isn't it more difficult to clean, and to know when you have sufficiently cleaned of stuff stuck in the glass afterwards?
  • · Replies 19 ·
  • · Replies 16 ·
14K
