Does the force between perpendicular moving charges violate Newton's third law?
6 replies · 2K views · last reply
bob012345
In his lecture 26 vol 2 Feynman discusses charges moving at right angles shown in fig 26-2. As Feynman states "It appears that action is not equal to reaction." He states it will be discussed further but I cannot find that. My question is what is the most updated thought on this 60 year old question? Thanks.
Check out 27-6
Feynman said:
We will mention two further examples of momentum in the electromagnetic field. We pointed out in Section 26–2 the failure of the law of action and reaction when two charged particles were moving on orthogonal trajectories. The forces on the two particles don’t balance out, so the action and reaction are not equal; therefore the net momentum of the matter must be changing. It is not conserved. But the momentum in the field is also changing in such a situation. If you work out the amount of momentum given by the Poynting vector, it is not constant. However, the change of the particle momenta is just made up by the field momentum, so the total momentum of particles plus field is conserved.
Thanks. I thought it might be that similar to the Feynman Disk. Anyone have any other thoughts?
The fourth Maxwell’s equation states that a magnetic field is produced by a current density and by a changing electric field.
Here the changing electric field generates the component of the magnetic field which is not mentioned. After including it the action will be equal to the reaction.
So what about momentum of the field?
If I understand Feynman’s argument, momentum is conserved by including the field momentum and change in the field momentum balances the forces but the forces do not balance among the charges only but the system of charges and fields.
Sorry for wrong explanation in the post #4.
