Does the Rank of a Commutator Determine Common Eigenvectors?
  • Level: Graduate
  • Thread starter Thread starter Hurin
    Commutator rank
1 reply · 3K views
Hurin
I found this theorem on Prasolov's Problems and Theorems in Linear Algebra:
Let V be a [itex]\mathbb{C}[/itex]-vector space and [itex]A,B \in \mathcal{L}(V)[/itex]such that [itex]rank([A,B])\leq 1[/itex]. Then [itex]A[/itex] and [itex]B[/itex] has a common eigenvector.
He gives this proof:
The proof will be carried out by induction on [itex]n=dim(V)[/itex]. He states that we can assume that [itex]ker(A)\neq \{0\}[/itex], otherwise we can replace [itex]A[/itex] by[itex]A - \lambda I[/itex]; doubt one: why can we assume that? For [itex]n=1[/itex] it's clear that the property holds, because [itex]V = span(v)[/itex] for some [itex]v[/itex]. Supposing that holds for some [itex]n[/itex]. Now he divides into cases:
1. [itex]ker(A)\subseteq ker(C)[/itex]; and
2. [itex]ker(A)\not\subset ker(C)[/itex].
Doubt two: the cases 1 and 2 come from (or is equivalent to) the division [itex]rank([A,B])= 1[/itex] or [itex]rank([A,B])=0[/itex]?
After this division he continues for case one: [itex]B(ker(A))\subseteq ker(A)[/itex], since if [itex]A(x) = 0[/itex], then [itex][A,B](x) = 0[/itex] and [itex]AB(x) = BA(x) + [A,B](x) = 0[/itex]. Now, the doubt three is concerning the following step in witch is considered the restriction [itex]B'[/itex] of [itex]B[/itex] in [itex]ker(A)[/itex] and a selection of an eigenvector [itex]v\in ker(A)[/itex] of [itex]B[/itex] and the statement that [itex]v[/itex] is also a eigenvector of [itex]A[/itex]. This proves the case 1.
Now, if [itex]ker(A)\not\subset ker(C)[/itex] then [itex]A(x) = 0[/itex] and [itex][A,B](x)\neq 0[/itex] for some [itex]x\in V[/itex]. Since [itex]rank([A,B]) = 1[/itex] then [itex]Im([A,B]) = span(v)[/itex], for some [itex]v\in V[/itex], where [itex]v=[A,B](x)[/itex], so that [itex]y = AB(x) - BA(x) = AB(x) \in Im(A)[/itex]. It follows that [itex]B(Im(A))\subseteq Im(A)[/itex]. Now, comes doubt four, that is similar to three: he takes the restrictions [itex]A',B'[/itex] of [itex]A,B[/itex] to [itex]Im(A)[/itex] and the states that [itex]rank[A',B']\leq 1[/itex] and therefor by the inductive hypothesis the operators [itex]A'[/itex] and [itex]B'[/itex] have a common eigenvector. And this proves the case 2, concluding the entire proof.
-Thanks
Let V be a [itex]\mathbb{C}[/itex]-vector space and [itex]A,B \in \mathcal{L}(V)[/itex]such that [itex]rank([A,B])\leq 1[/itex]. Then [itex]A[/itex] and [itex]B[/itex] has a common eigenvector. He gives this proof:
We need a common eigenvector, not necessarily to the same eigenvalues. If ##A## is injective and ##\lambda## an eigenvalue of ##A##, which always exists over ##\mathbb{C}##, then
\operatorname{rank}([A-\lambda I, B])=\operatorname{rank}([A,B]) \leq 1
and the condition still holds, and ##A-\lambda I## is not injective. Now let's assume we found an eigenvector ##v \in \mathbb{C}^n## for both, i.e. ##(A-\lambda I)(v)=\nu v\, , \, B(v)=\mu v##. Then ##A(v)=(\nu+\lambda)v## and ##v## is an eigenvector for ##A##, too. Hence we may assume that ##A## is not injective, since a result in this case delivers a result for the injective case, too.
What is ##C##? I assume it stands for ##C=[A,B]##?
Anyway. The answer is no, since we can always distinguish these two cases. There is simply no third possibility, regardless of how ##C## is defined.
Yes. But where is the problem?
Say ##v\in\ker A \subseteq \ker [A,B]## by assumption of case 1. Thus ##AB(v)=[A,B](v)+B(A(v)) = 0+0=0## and ##B## can be restricted to ##B':=\left.B\right|_{\ker A}\in \mathcal{L}(\ker A) \neq \{\,0\,\}##, and ##\dim (\ker A)<n##, because ##\dim (\ker A)=n## means ##A=0## and all vectors are eigenvectors to the eigenvalue ##0##, i.e. any eigenvector of ##B## will do. Hence we have a vector ##v\in \ker A ## by induction, which is an eigenvector of ##B'## and and an eigenvector of ##A##: ##B'(v)=B(v)=\mu v## and ##A(v)=0\cdot v=0##. Remains to check the rank condition for the induction step, but
\left. \operatorname{rank} [A,B']\right|_{\ker A}=\left.AB'\right|_{\ker A}=\left.AB\right|_{\ker A}= \left. \operatorname{rank} [A,B]\right|_{\ker A} \leq \operatorname{rank} [A,B] \leq 1
##y=v :=[A,B](x)\, , \,x \in \ker A - \{\,0\,\}##
-Thanks
##[A,B](V)## is at most one dimensional, and ##[A,B](x)\neq 0##. Hence
[A,B](V)=[A,B](x)=A(B(x)) = v = [\left.A\right|_{\mathbb{C}x},\left.B\right|_{\mathbb{C}x}] \neq 0
and ##\operatorname{rank}[A',B'] = 1## so the induction hypothesis applies. Since we only restricted the transformations to invariant subspaces, all vectors, including the solution eigenvector are still vectors in ##V##. Note that we remained in the non injective case for ##A## the entire proof!
