Does the Solar System spin around an axis and if so where is it?
The discussion revolves around whether the solar system spins around an axis as it travels through space, akin to how a planet rotates while orbiting a star. Participants explore the concept of rotation in the context of celestial mechanics, considering the solar system as a collective entity and examining the implications of gravitational forces and angular momentum.
  • Some participants propose that the solar system does not have a single axis of rotation due to the non-rigid nature of its components, which move in orbits with varying axes.
  • Others suggest that the line perpendicular to the ecliptic plane, passing through the Sun, could serve as an approximate axis for most objects in the solar system.
  • One participant likens the solar system to a "squashed transparent ellipse" that occupies space and creates eddies as it moves, expressing a fluid-like perception of space.
  • There is a discussion about the barycenter, or center of mass, of the solar system, with some arguing it could represent a point along a rotational axis.
  • Some participants mention that while the Sun contains most of the solar system's mass, the majority of angular momentum resides in the planets, particularly Jupiter.
  • Mathematical calculations are presented to compare the angular momentum contributions of the Sun and Jupiter, with varying interpretations of the results.
  • Participants discuss the Sun's motion around the barycenter and its implications for angular momentum, noting that this motion is not constant.
  • One participant shares a simulation demonstrating the Sun's orbit around the solar system's center, highlighting the influence of planets on the Sun's path.
Participants express multiple competing views regarding the solar system's rotation and the significance of the barycenter. There is no consensus on a definitive axis of rotation or the implications of angular momentum contributions from various celestial bodies.
Some discussions involve assumptions about the solar system's structure and dynamics, including the nature of gravitational interactions and the definition of angular momentum. The complexity of the solar system's motion and the varying contributions of its components are acknowledged but remain unresolved.
Darkan9el
Hi, Does the solar system spin around an axis as it travels through space, much like a planet rotates as it orbits the sun and if it does where is the axis point.
I know the solar system is orbiting the centre of the galaxy, I was just wondering if it behaved like a planet because things tend to follow the same rules.
Astronomy news on Phys.org
Hi Darkan9el, welcome to PF!
When we talk about the rotation of a rigid body, like a planet, it's easy to say where the axis of rotation is located, as no matter which point on or inside the planet you choose, it will rotate around the same axis.
With solar system, it's a bit more complicated, as the particles(i.e., planets, asteroids, the Sun, comets, gas) comprising the system are not rigidly bound together, so they can move in orbits whose axes of rotation each point somewhere else.
It is thus impossible to name a single axis that would fit all the celestial objects.
However, due to the dynamics of the formation of the solar system, all planets ended up orbiting in nearly the same orbital plane, very close to that of the Earth. As a first approximation then, it's possible to say something like "the line perpendicular to the ecliptic(Earth's orbital plane) passing through the Sun is approximately the axis around which most objects in the solar system orbit".
Such an axis points towards the constellation Draco, pretty much in the centre of the first loop of the Dragon's serpentine body, counting from the head. There are no particularly bright stars there. The star Polaris is, unsurprisingly, 23.5 degrees away from this point.
A bit better, more rigorous approach would be to calculate the total angular momentum of the solar system, by adding component vectors from each of the major bodies(Sun, planets) in the system. The direction of the resultant vector wouldn't differ from the previous approach by more than a few degrees, though.
Thank you for your reply, I was taking the solar system as a whole, as an entity a bit like if you have separate objects in an image then you group them and all of them rotate together but obviously all the different components move within this group and solar system group ends up a bit like a squashed transparent ellipse, that kind of occupies space like a bubble on water and creates eddy's as its moves, I don't know I've always perceived space as a kind of liquid, just not very dense.
One of the ideas I was looking at was does the sun move around the Earth but in a less perceptible way, while the Earth orbits the sun.
Only in the sense of the two bodies orbiting their mutual centre of mass. It lies well within the Sun, but not at its centre.
I'm not sure I understand your previous statement. It looks like an analogy of the angular momentum approach.
I would think the barycenter (solar system's center of mass) would make a good point along the putative rotational axis. This point follows a straight line from the point of view of a distant observer in an inertial frame of reference.
With respect to the center of the galaxy, the solar system moves in an approximately elliptic orbit.
Unless we can find a 200-million year old observer who is so far away from the Milky Way as to be outside of its gravity well, I think it's safe to ignore the sun's orbit.
Wouldn't our solar systems rotation be governed by a larger gravitational force that could in fact create a solar system rotation around the larger gravitational force of many solar systems? How much larger would that gravitational force need to be and how many other solar systems would rotate around it much like the planets of our solar system rotate around our sun?
Since 99% of the mass our our solar system is in the Sun itself, the rotation of the sun around its own axis would pretty well qualify. IN the big picture, our solar system is remarkably round. :)
The Sun may have the most mass, but most of the angular momentum is in the planets.
I did not know that. Interesting if true!
Well, let's calculate.
We'll compare the Sun's and Jupiter's contributions.
Let's use units of solar radii for distance, Jupiter's mass for mass and days for time.
Angular momentum is ##L=I\omega##
Angular velocity is ##\omega=2\pi/T##
Moment of inertia of a uniform ball is ##I=2/5 mr^2##
The Sun is not a uniform ball, nor is it rotating uniformly across its volume, but by assuming unformity we'll get an easy to calculate ballpark result that's goint to set an upper bound on the real value.
In our chosen units, solar mass=1000, r=1, T=25
we get ##L=2/5*1000*1^2*2\pi/25=~1000##
A point mass in orbit has got moment of inertia ##I=mr^2## (there's nothing to stop us from treating planets as point masses).
For jupiter, m=1 r=1000 T=4300
we get ##L=1*1000^2*2\pi/4300=~1400##
So Jupiter's orbital motion alone contributes more to total angular momentum of the solar system than the Sun does.
That ignores the motion of the sun around the barycenter of the solar system about once every Jovian year or 11.86 Earth years. The distance of the sun from the barycenter varies from 0 to ~2 solar radii. Unfortunately this means the sun's orbital angular momentum around the barycenter is not constant. But if we assume the average distance2 is 1 solar radius2 (and a sun with point-like mass), then L = 1000 * 12 *2pi/12 = 524
The result is in different units than the previous ones. Time should be in days, so you end up with ##L=1000*1^2*2\pi/4300=1.4## i.e., completely negligible contribution.
(just as is the contributrion of Jupiter's rotation)
Here's a simulation of the Sun going around the center of the solar system:
http://orbitsimulator.com/gravitySimulatorCloud/ssBarycenter.html
After you load the page, you need to press the Play button under the words "time step".
You can also switch the focus object to Earth, and watch Earth and Moon orbit the Earth/Moon barycenter.
You can also switch the focus object to Pluto and watch Pluto and its moons orbit their barycenter.
You might want to slow the time step and zoom in the screen width for Earth and Pluto.
This is pretty cool. And easy to observe the influence the planets and their orbits have on Sol. I watched out for a hundred years or so, enough to see the non-uniform, 'curly-Q' path for almost two cycles. I'm guessing that even the small stuff like moons, comets, meteors and asteroids would contribute small, but ever-changing influences to the system, so the Sun's path will never complete a fancy, 'Spirograph' type design. :p
The simulation suggests some periodic changes to the force vector and the resultant acceleration on the sun as it revolves around the solar system. One has to wonder what effect all this has on its inner parts of varying density, and on the system creating sunspots and other magnetic fields. If the sun were completely axisymmetrical, it shouldn't produce a self-exciting dynamo (Cowling antidynamo theorem).
Bandersnatch - good call. I must have posted that calculation in haste. Subluminal - per Einstein the sun is following a straight line in space time so despite it's apparent wandering it is in free-fall. There will be tidal forces produced by the planets, but if you calculate their effect, they produce tides on the order of a millimeter on the sun.
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 52 ·
  • · Replies 18 ·
