Does the variable take these values?
  • Topic:
  • Thread starter Thread starter evinda
    Variable
12 replies · 3K views
evinda
MHB
Hello! (Wave)
If we have the following for loop:
Code:
 for (i=8^{n-1}; i<8^n; i+=1)
(where $n$ is an integer)
does $i$ take the values $8^{n-1}, 8^{n-1}+1, \dots, 8^n-1$, or am I wrong? (Thinking)
You are correct. Note, however, that this precise syntax would not work in C, C++, Java and other C-like languages.
Nice, thank you! (Smile)
It should be also $n \geq 1$, right? (Thinking)
- - - Updated - - -
Or do we not have to take restrictions for $n$ ? (Thinking)
The loop will not terminate unless $n$ is a positive integer.
Edit: As I remark later, the loop will always terminate.
So, can I just say that $i$ takes the values $8^{n-1}, 8^{n-1}+1, \dots, 8^n-1$ times, so the for loop will be executed $7 \cdot 8^{n-1}$, or do I have to say that $i$ takes these values, only if $n \geq 1$ ? (Thinking)
First, my remark about termination was wrong. The loop will terminate in any case because the loop guard is $i<8^n$ and not $i=8^n$.
What you said is correct when $n\ge 1$ and $n$ is an integer. Determining the precise number of iterations when $8^{n-1}$ or $8^n$ is not an integer requires some thought (though it's not hard). Do you really need this?
I am given this algorithm:
Code:
Function(int n){
  int key=1, j,t,x;
  for (j=2*n; j<=8*n; j++){
        for (t=8^(n-1); t<8^n; t++){
             for (x=3; x<55; x++){
                  key++;
and I want to find how many times the command key++ is executed.
The first for is executed $6n+1$ times, the secod for is executed $7 \cdot 8^{n-1}$ times and the third one, $52$ times. So, the command is executed $(6n+1) \cdot 7 \cdot 8^{n-1} \cdot 52$ times.
Do I have to say that it is executed only when $n \geq 1$ ? (Thinking)
Yes, your analysis is correct when $n\ge 1$ (and the argument type says that $n$ is integer). If $n=0$, then the first and second loops execute 1 time each, so [m]key++[/m] is executed 52 times. If $n<0$, then the first loop is never executed, so [m]key++[/m] is executed 0 times.
So, if $n=0$, does $t$ take only the value $\frac{1}{8}$ and then the for loop terminates? (Thinking)
Yes, because $8^{-1}+1=\frac{1}{8}+1>1=8^0$.
I understand! (Nod)
So, do I have to distinguish the cases:
  • $n=0$
  • $n \geq 1$
and find a formula for each case? (Thinking)
  • $n=0$
  • $n \geq 1$
Yes, and $n<0$.
In each case, formulas have already been written explicitly in this thread.
Edit: My guess is that the problem authors assumed that $n\ge 1$, but I can't be sure.
Yes, and $n<0$.
Nice! Thank you very much! (Smile)
