Does zero describe something real or just a conceptual absence?
116 replies · 22K views · last reply
Jarle said:
Is it just me, or is this discussion very ambiguous? How can you even talk about a 'direct conflict' between 0 and {}? How could such a conflict ever arise, and in what terms would it manifest itself? I can honestly not understand how formal symbols like {} and 0 can cause any confusion at all!
In fact it is philosophically natural to arrive at dichotomies. However dichotomies are "conflicts" that are in fact complementary. If you break a symmetry, you arrive at an asymmetry.
This was why set theory was an attempt to define what was fundamental in maths. It represented the notion of global constraints ( {} - what exists as a limit) and local degrees of freedom (0 - the least that can exist locally, and yet there still be something local, just in the same way a zero dimensional point was the basis of Euclidean geometry).
{0} is thus the mathematical expression of a fundamental "conflict" - or rather, a fundamental symmetry breaking. It breaks things apart into their contexts and their events, their global constraints and their consequent local freedoms.
Zero is made intelligible as the least there can be at a location, given this specific context.
Which is why the meaning of zero oranges depends on whether the global set is "oranges", "fruit", or "entity". The local zero-ness becomes more general as the global context or definition of the set becomes more general.
And {0} was the attempt to define things at the level of maximum generality.
Jarle said:
Is it just me, or is this discussion getting very ambiguous? How can you even talk about a 'direct conflict' between 0 and {}? How could such a conflict ever arise, and in what terms would it manifest itself? I can honestly not understand how formal symbols like {} and 0 subject to well-defined formal operations can cause any confusion at all!
This is a philosophical discussion. What does {} != 0 is an academic statement, but what does it mean to you?
Jarle said:
A sentence like
"This identifies an {} as an infinitesimal with an unknown transfinite cardinality, a limit."
is completely nonsensical to me. You appear to have arbitrarily thrown three different mathematical concepts (infinitesimal, transfinite cardinality, limit) into a grammatically correct sentence, but nothing more!
Yes, I know what kind of distortion of various set theories my perspective distorts, but what exactly does your own definition entail?
Jarle said:
{} (empty-set) is neither an infinitesimal, nor a limit. And its cardinality is 0; not unknown and not transfinite.
Fair enough, I know the cardinality of {} is 0, but think about exactly how you define the difference. If {} has cardinality of 0, it, like 0, defines non-existence, which appears to indicate {} = 0, which is false. Given the axiom of empty set, it can't even be a member of itself. It's like saying: There is a snake that is not a member of any set of snakes. Is that more sensible than simply converging such logical round runs by dividing things into existential and potential infinitesimals?
Jarle said:
The previous post strikes me (and this might be caused by my lack of understanding of your terms and reasoning) as completely incoherent.
I understand the incoherence it might convey. To me it is incoherent to put concepts on the same footing as existentials and degrees of freedom. Set theory is full of incoherent sophistry it simply defines itself out of. Thus you can, by wearing the blinders it defines for itself, follow the structure and pretend it's meaningful. But to me a snake of a member of some set of snakes, and being an {} shouldn't have to break that logic.
So yes, I knowingly broke the rules, and stated it as a personal take on it. But how many blinders must you wear to accept logical end run around self contradictions like the axiom of empty set?
Not quite. Firstly, you're using a limited example: only positive integers make sense when counting snakes, and it's also an absolute quantity.
Consider voltage, instead, a relative quantity that can be irrational and negative. Voltage can exist and be 0 at the same time, so the statement V=0 doesn't speak to the existence of an electric potential, only to its value.
This attitude, and accusing academics of blind sophistry, is not only an ineffective argument by its ad hominem nature, but also happens to be misleading. Academic pursuit is built on philosophical curiosity. Philosophical discussions are in no way void of academic judgment and are often unproductive and meaningless when there is no academic or commercial enforcement involved. Political enforcement is obviously useless :P
Even though this is a philosophical discussion, I find it hard to believe that it has anything to do with mathematics. But I do not understand your question, perhaps you could say it differently.
Well, you were using words with definite mathematical meaning, and by applying it on mathematical concepts you oblige yourself to do it correctly. If not you should explicitly explain how your usage of the words differ from common usage.
I can not see how the fact that the cardinality of {} is 0 should imply that {} = 0. A set is just not a number. In the analogy of sets being "bags of elements" it simply means that it contains no elements. Postulating the existence of the empty set is merely making it intelligible in set theory to talk about a set which does not contain any elements. To me it makes perfect sense, and I can hardly see the difficulty.
It is not like saying "there is a snake that is not a member of any set of snakes". It is like saying "there is a bag which is empty". Furthermore; the empty-set can be an element of other sets (for example its powerset), so the analogy is faulty. And it has nothing at all to do with infinitesimals.
I don't think it is a relevant critique of set theory that it "defines itself out". Set theory does not need to be "self-contained" so to say, it does not need to back itself up. It just postulates a collection of axioms for what we think of as sets. It is meaningful as long as we can accept the axioms as valid of our intuition of sets. Where the acceptance comes from is irrelevant for set theory.
And pythagorean brings up an important point. 0 is also used in ways in which it can hardly be seen as qualitatively different from any other number, for example when measuring voltage or celsius. That is to say; 0 degrees is not the absence of degrees, it's just another temperature.
apeiron said:
The usual take on the entymology is that the root term is peras - limit. Hence the unlimited.
But regardless of entymology, the meaning of words lies in their use, their semiosis. So it was how the ancients used the term that really gives apeiron its meaning.
In sum, we've passed from zero (miden) to unlimited (apeiron).
But anyhow, your post #61 is interesting and says much. Thanks.
Jarle,
When you say a set is not a number I agree, but what exactly is the difference?
Technically there is only one empty set. This is the result of the axiom of extensionality. Yet if a bag holding an empty set can hold a set of marbles, how many marbles can it hold? Why can it hold that many, but not more, if it contains a single empty set?
Let's look at a more clear cut paradox. The Banach–Tarski paradox. Now explain why this is not proof by contradiction that something is wrong with the axioms that lead to it. Yet somehow it's supposed to be true because the number theory that defined it to be true also defines itself to be true. Now certainly, scale independence is a fundamental physical principle, and any change of absolute scale, whether you define it as a mathematical or global physical operation, doesn't define a real change. But the Banach–Tarski paradox appears to indicate that relative scale is also independent. Physics, and conservation laws, would be a pipe dream in such a world. Dr Who would rule, and you could put all the marbles you want in that bag containing an empty set.
It comes down to the fact the points defined between any two points can not be fully specified, and how Lebesgue measurability is defined for limits. Hence, on the basis that limits are measurable relative to limits within their own equivalency class, they are assumed be measurable wrt a finite interval. Basically an artificial separation between limits, empty sets, and numerical labels. Ostensibly to acedemically define itself out of self contradiction, even if it's physically absurd.
You have your facts wrong; the Banach-Tarski paradox is not a logical contradiction.
What it does do is demonstrate vividly that the notion of "measure" does not behave well when applied to a calculation involving sets for which the notion of measure does not apply.
The two reactions are purely on aesthetic, and possibly practical issues:
  • Hrm. I should be very, very careful when I try to apply "measure" outside of its domain of applicability.
  • Bah. I will work in a variation of set theory where all sets of Euclidean space are measurable. I opine that this convenience surely outweighs all other inconveniences of such a set theory.
more words
None of what follows appears to make any sense.
Jarle said:
Sony AD, this has nothing to do with physical quantities, but has everything to do with euclidean geometry.
It has everything to do with physical quantities. Physical quantities are the ultimate result and pursuit of any worthwhile computation. Even if these physical quantities are virtual (in the case of simulations - 3D games, for instance).
What is there you may wish to compute (or even be able to reliable compute without being able to test your predictions against reality while developing the required math) that is not of the physical world or in semblance of it?
The answer? Insanity. The pointless intellectual perdition modern mathematicians love to indulge themselves in while leaving such basic, fundamental questions as:
"What is the area of overlap between two random triangles?"
or
"What is the clockwise area of a complex polygon?"
Not even addressed.
Jarle said:
I brought it up as an example of a piece of mathematics in which irrational numbers are used as naturally as rational numbers.
What proof do you have they are even numbers? That's just a tenet of dogma.
Would you call infinity a number? Do you think it exists? Do you think it makes sense? That which has no value because it is boundless. Even though it has no value (because it is boundless), its value must also be greater at any time in its existence than it had ever been until that point. It must grow. Otherwise how can you accommodate the fact that, no matter how much you keep on churning decimals, you never quite get to its value?
Sounds like religion to me.
But, who knows? Maybe irrational numbers are why the universe is expanding, no?
Jarle said:
What can occur and what cannot occur in nature is completely irrelevant to mathematics.
When that happens it is haughty mathematics that actually becomes irrelevant, unbeknownst to it. Knowledge preceded and is more than mathematics. In fact, part of mathematics is contrary to knowledge because part of mathematics are some fallacious concepts, like infinity, irrationals, etc.
Jarle said:
All triangles are imagined, both those with irrational sides and those with rational sides. It has nothing to do with physical measurement, that is a blind road.
When you compute the length of the hypo from the length of the sides you are actually only defining a function. You are not computing length.
Jarle said:
Mathematics is a field concerning abstractions, not physical measurement. And it is certainly not bounded by whatever physical perspective one might have.
The ultimate result must be grounded in and bound by physical reality.
We don't assume shares of something grow larger the more ways you split it or the finer the cuts. We assume the opposite. Mathematicians do not.
It is mathematics that is bound by dogma. Philosophy is only bound by logic. So mathematics will fail long before philosophy does.
Jarle said:
You say we can't assess their value, but this is a play with words.
What is the value of infinity? See above.
Jarle said:
sqrt(2) is fine as it is, and I can compare it to any given rational or irrational number if I want.
You can compare the growth of two twin parameter (seed, expansion length) functions that only grow, yes.
Jarle said:
A value is not necessarily bound to a representation through rationals which you seem to imply. Treating irrationals symbolically is completely justified if it can be done so consistently, and it can.
A value IS a rational.
Calling irrationals numbers is not, though.
Jarle said:
Numbers can be abstracted in various ways.
Yes. Irrationals are not numbers, though.
Or would you consider logy(x), with x being an unknown variable, to be a number? I fear you would.
Hurkyl said:
I'm not sure how to make sense of your comment, though, since irrational numbers and infinitary methods are used of all of the best physical theories we have of reality.
They're not numbers.
Hurkyl said:
Or rather, I have a pretty good idea what argument you're implying, but have never understood why people think "la la la, I can pretend everything is a natural number and still function in society" is a convincing argument of, well, whatever point they are trying to convince people of with it.
I think it's wrong to say everything is one single, solitary natural number. One or many is probably correct.
*checks lexicon* looks like a number to me.
In the immortal words of Charles Dodgson
`When I use a word,' Humpty Dumpty said in rather a scornful tone, `it means just what I choose it to mean -- neither more nor less.'​
I can't tell you what you mean by the word "number"; you're free to use the word in whatever fashion you want. However:
  • You can't tell me what I mean by the word "number".
  • You can't expect to communicate meaningfully when you are using a word differently than everybody else, especially if you refrain from explaining that you are doing so, and what you actually mean
From wikipedia:
In mathematics, the definition of number has been extended over the years to include such numbers as 0, negative numbers, rational numbers, irrational numbers, and complex numbers.
I think you're the first person I know to claim irrational, uh, numbers, are not numbers :-p
Nice to see you both took so much out of that little post. :rolleyes:
wrongusername said:
From wikipedia:
Wikipedia also regurgitates the myth that turbochargers run on "otherwise wasted energy".
or
Not even addressed.
You will have to understand that mathematics, or rather 'mathematical activity' is formal manipulation. It does not correspond to any physical fact of nature. Mathematics makes no predictions about reality whatsoever! The formal premises/axioms might have their motivation in our intuition of various concepts or phenomena, but doing mathematics is expanding our calculus of formal 'truth'. Some find this 'insane' activity quite interesting.
However, playing on your premises; it is more clear now than ever how interconnected mathematics and physics is. To say that mathematicians have wandered on a lone road of pointless indulgence in abstract nonsense is more far off than you can imagine. Modern physics is quite clearly dependent on much of modern mathematics and make good use of the 'fallacious concepts' like the basic notions of irrational numbers and infinity.
You seem to have a clear-cut opinion of what a number is and what it is not, but can you define a number? How do you define value? What makes you think that you decide what is allowed to be called a number, and what isn't? What 'numbers' mean is exactly the usage of numbers, and the usage is not bound by anything but convention. What you call 'dogma' I call natural elasticity.
I could very well call infinity a number (of course in the context of e.g. the extended real line), but I don't - but this is a matter of convention. Infinity in the context of the extended real line is not a natural, rational or real number; but there is nothing which hinders the conventional definition of 'number' to include infinity in this case.
Certainly, no.
EDIT: You will have to explain what you mean by a 'random triangle', :rolleyes: and how they are part of such basic and fundamental questions.
Fascinating, the things I get you to say.
So basic mathematical operations such as addition, subtraction, etc. applied to natural numbers have no rooting in nor relation to anything of encompassing reality? Or what it means to be in a basket?
Adding two apples to three already in the basket does not make five apples in the basket? Or are you going to harper on the definition of an apple?
Really! It does not predict that 5 Kg of concrete added to 5 Kg already in the shopping trolley will make for 10 Kg of concrete in the trolley?
What is the purpose of mathematics then?
Cool. If only anyone were working on stuff remotely, remotely useful to me.
I only tackle the stuff I can wrap my head around. When someone knocks me out https://www.physicsforums.com/showpost.php?p=2789257&postcount=15" I scurry on back to my hole as soon as I come to and shut up.
Not knowing/understanding what something is does not necessarily preclude its use. As intended or natural or otherwise.
Numbers have definite & definitive values, for starters. These values don't change the closer you look at them.
How do you prove an axiom?
Common sense.
The freedom to call a spade a fork.
If you admit infinity (let alone call it a number) then, by implication, you must accept division by 0 makes sense. And you must share with us the exact value of any given number divided by 0 and how to compute this value.
A triangle being random only means there is no special/particular numerical relation between the lengths of its sides or any special value to its angles.
Reality only intrudes into mathematics at the level of its axioms. But it does intrude there.
Yes, once an axiom is assumed, then all else that follows is formal modelling - free of reality even if it happens to fly in a parallel path to reality.
But the creation of axioms is an informal exercise. You could chose something as a matter of whim, or because it seems "logical", or intuitive. But in fact axioms tend to get chosen because they seem true by some kind of generalised observation of the world. So our view of what is real does intrude at the start of things because all our ideas are ultimately grounded in our experience.
We can get much more specific about this business of getting started. For example, there is Peirce's logic of vagueness and process of abduction.
But we don't need to get that specific to see the central confusion that is being expressed in this thread.
Yes, formal systems based on axioms are no longer part of reality. And yes, axioms are "unreal" statements too. But yes, axioms are justified by something in the end, and it is our general informal impressions of what is true about our experiences of reality.
So numbers can both fail to really exist, while absolutely existing formally. And to the extent that the two worlds fly along in parallel, most people will never think about the essential difference. But philosophically, it matters that there is a gap and a relationship that bridges that gap.
I never said mathematics have no relation to reality, we use mathematical reasoning in many physical situations. The point you must understand is that mathematics does not correspond to physical reality; mathematics deals with definite formal rules of mathematical concepts which may very well be abstracted from physical situations. That does not mean it is 'rooted' in physical reality.
Natural numbers are such an example. Arithmetic is purely the formal manipulation of the symbols we call numerals according to definite rules, while still being incredibly useful in real situations. It is a critical fact of mathematics that it deals only in formality.
Do you know what an axiom is?
No, that is not an implication. However, division by 0 does make sense! (or more precisely: it can make sense)
http://en.wikipedia.org/wiki/Riemann_sphere
EDIT: Apeiron makes an important point when he separates the informal process of choosing ones axioms from the formal deduction which takes place afterwards. However, only the latter part is mathematics, or 'mathematical activity' (not ignoring the extreme importance of this process to mathematics).
So what axiom, rule, etc., was broken in the Banach-Tarski paradox? Limits are defined as Lebesgue measurable in many cases. What is the difference between "does not behave well" and "logical contradiction"? To say the notion of measure does not apply is not how Lebesgue measures are defined.
How do you decide whether a number really exists, rather than just existing formally?
Part of the definition of a measure is a specification of what sets are measurable (with respect to that measure).
If A, B, C, D, and E are disjoint measurable sets, then:
m(A union B union C union D union E) = m(A) + m(B) + m(C) + m(D) + m(E)
If A is measurable , A' is the transform of A by a Euclidean motion, and m is the Lebesgue measure, then A' is measurable, and:
m(A) = m(A')
Combining these, we can prove:
Theorem: If A, B, C, D, and E are disjoint measurable sets, m is the Lebesgue measure, A' is the transform of A by a Euclidean motion and similarly for B', C', D', and E', and A', B', C', D', and E' are disjoint, then
m(A union B union C union D union E) = m(A' union B' union C' union D' union E')
Note that all of the theorems above have the hypothesis that the sets involved are measurable. Some of the five sets constructed in the proof of the Banach-Tarski paradox are not measurable, and thus do not satisfy the hypothesis of the theorem.
(aside: the Banach-Tarski paradox uses the axiom of choice in the construction, which is why it comes up in discussions over that axiom)
By prediction and measurement.
The best modern epistemologist IMHO is Robert Rosen who was a mathematical biologist and wrote great stuff on the modelling relation. His last book, Essays on Life Itself, is all about precisely this issue.
So say we are talking about the number 1. We have defined it formally as a model of "one-ness". It exists formally. But how do we find exactly 1 of anything in the real world? We take the model and use it to justify a process of prediction and test.
Is that one apple I see on the table? Well, I might have to walk all round it to be sure a second, or an infinity of apples, is not hidden just behind it, blocked from my line of sight. I might have to reach out and touch it, to be sure it is not a collection of carefully painted beetles holding some apple like formation. Or if we zoom in for a microscopic view, at some point everything dissolves into atoms (whatever they look like) and we can wonder where this exact apple starts and ends. Etc, etc. If you are talking about absolute certainty, then there are in reality an unlimited number of doubts that must be ruled out.
So can we ever really know that some physical thing is an exact example of one-ness, as formally defined? In pragmatic fashion, we can pretty quickly agree that we only have a single apple on the table. All doubt seems trivial. But doubt must always remain because reality does not seem completely measurable.
One, of course, seems the simplest number to relate to reality. Others like pi and infinity remain more troublesome.
And I think there is then another whole level to this particular debate to do with "doubt" within formal models themselves.
Quickly, axiomatic truths are in fact inevitably dichotomistic. You cannot confidently assert one thing without also creating the equally definite possibility of its opposite (thesis and antithesis as Hegel said). So you say discrete, I say continuous. You say local, I say global. You say event, I say context. You say stasis, I say flux. You say determined, I say random.
All basic concepts come in complementary pairs as all crisply definite assertions are symmetry breakings (the breaking of the symmetry of vagueness or ignorance into asymmetric polar opposites).
And so, secretly - it is rarely acknowledged, except by category theory! - that all mathematical systems have a fundamentally mixed nature. They must employ both ends of a dichotomy, even if they prefer to suppress awareness of one of the ends.
So with number theory. We have discrete numbers existing on a continuous line. Both aspects are essential to the formal model, but one aspect is suppressed.
For example, the number 1 is just taken as a discrete point (on a continuous line). This is a formal statement that seems to need no further "measuring". It just is.
But say we wanted to check? Well what we are really saying is that 1 is 1.000... Check its location on the line to as many decimal places as we like, and it will be exactly there. But of course, we also know there is a practical issue when it comes to establishing infinite facts. In practice, we can never arrive at a final count. The continuity that we have tried so hard to push out of view is here reasserting itself.
Again, the 1-ness of the number 1 is about the least troubling either in the real world, or within its own world, the realm of axiomatic formal modelling. But even for 1, there is a hidden duality behind the presumed monadic description. Counting appears based on the notion of fundamental discreteness, but for exactly this reason, it is just as much based (formally, axiomatically) on the assumed absence of fundamental continuity (and hence, in practice, by the suppression of what must also exist as part of initial state of possibility, back when axioms were being formed and reality was still intruding).
It is a case of A and not-A. You make a division and you must create two things. Both are equally real. But in your model, you just want to keep things simple and use the A. And suppress any non-A-ness. So 1 is discretely just 1, and you don't have to run round constantly stamping out threatened confusion from 1.00000... sometimes being actually 1.000001, or some other infinitesimal fluctuation.
However, when it comes to irrationals and infinities, people are more aware that the counter-balancing option of continuity is being actively suppressed (suppressed axiomatically). So they will protest and try to re-open the door to fundamental doubt. And if they go all the way back to axiom-formation, they can see doubt is justified - numbers are not real - but also that there was a reason why the formalism went with option A rather than option not-A.
Imaginary numbers are the same. To me, the notion of 2-dimensional numbers, or n-dimensional numbers, seems quite natural. A point is a constraint on a line, but a line is a constraint on a plane, which is a contraint on a volume, etc. So you can play about on the spectrum between the absolutely discrete (a zero-D point) and the absolutely continuous (an infinite, unconstrained, dimensionality).
Again, the fundamental continuity (or its suppression) becomes more obvious and so more troubling with imaginary numbers, but it is there for all numbers in a necessary fashion. To have A, you have to make not-A. To have a figure, you must have ground. To have an event, you must have context.
Which hopefully loops round to my initial points about vagueness, zero and the null set. For zero to be a local absence, it must exist in the context of a global presence. The formalism of set theory wants to throw away the {} along with its contents - treat them as a nothing as well. But it would be less confusing to accept them for what they are, a necessary part of breaking the symmetry of pure possibility. To have thesis, you must also have anti-thesis.
And vagueness then is this realm of the pure unbroken possibility, a state of infinite symmetry. Imagine a place which is neither discrete nor continuous, neither random nor determined, etc, etc. Yet can be divided into these crisp, mutually-defining, polarities.
m(A) = m(A')
Ok, this makes sense. My particular perspective is not built from a purely mathematical point of view. It is based more on my utilitarian application of math, and the applicability is not entirely dependent on a mathematicians nose for details.
It seems that, given what you provided, Banach-Tarski intentionally transformed disjoint measurable sets, or different equivalence classes, to impose just the effect it had.
Right.
People have a habit of focusing on conclusions too much -- they balk when they see a theorem that concludes a single ball can be rearranged into two balls.
However, much of the point of theorem proving is not to prove conclusions, but to derive hypotheses: Banach-Tarski is a vivid demonstration that non-measurable sets fail to have the geometric properties we would like to demand of shapes in three-space -- and that failure can manifest itself even when dealing with the nicest of shapes such as a ball.
(I believe previous demonstrations had involved more convoluted sets, so some might be inclined to intuit that all of the oddities might be confined to weird sets, but as long as you start and end with reasonable shapes everything worked out fine)
So the conclusion to be derived from Banach-Tarski is that when doing geometry, you should restrict yourself to measurable sets. This issue rarely comes up in practice, because we already make a habit of working with nice sets -- but it's good to understand the range of applicability of the tools you want to use. (and it is also good to know that you can render non-measurable sets non-existent with an appropriate denial of the axiom of choice)
(There's an adage I like -- you can't claim to understand what something is unless you also understand what it is not)
The quest for an ontological 'one-ness'; the question of whether a physical thing actually possesses the quality of one-ness, or is an example of one-ness, seems to me as a completely useless exercise.
The important thing in the situation you brought up is that we 'see' one apple on the table. It is irrelevant for us if there actually is two (one being invisible or hidden). We still only count 1 apple, and behave accordingly. What matters to us is our picture of the situation, and how we think of it. This is where 1 enters reality, through counting the apple. The only ontology of the natural numbers you will find lies in the way we operate with them, so I claim that all numbers exclusively exist formally. It is only through formal use (arithmetic, labeling, enumerating, counting) natural numbers makes sense at all.
I don't understand your insistence on that 0 is local absence; it is a formal character used in various ways. When measuring temperature 0 is just another temperature on the scale, it is not the 'absence of degrees'. It might be an arbitrary lottery number. It can mean 'false'. 0 does not represent some fundamental feature of reality, it is a tool (in non-mathematical usage).
But why do you say we "treat them as a nothing" in set theory? And how can you refer to what they "really are"? In themselves they are not more than symbols on paper, on a screen, or mentally before your eyes.
Hurkyl said:
Right.
My issue came when, it seemed to me, limits could be defined as Lebesgue measurable without specific reference to the class it was measurable wrt, as if is was either an absolute property or not. In that case I didn't see a specific violation in Banach-Tarski. So even though this justifies my view that it inappropriately mixed equivalence classes, this wasn't new, and I was being over-judgmental in thinking Banach-Tarski represented a valid result in the standard formulism. That I can accept.
Jarle said:
The only ontology of the natural numbers you will find lies in the way we operate with them, so I claim that all numbers exclusively exist formally. It is only through formal use (arithmetic, labeling, enumerating) natural numbers makes sense at all.
I agree that numbers exist only as part of a formal model. But then the argument becomes whether formal models only exist to model reality. A scientist kind of thinks so, therefore sees modelling as a relation with reality (which is where the prediction and measurement must come in). A mathematician may take the different view that once you have invented the realm of the formal model, you can just explore its interior space forever.
Jarle said:
I don't understand your insistence on that 0 is local absence; it is a formal character used in various ways. For example, when measuring temperature 0 is just another temperature on the scale, it is not the 'absence of degrees'. It might be an arbitrary lottery number. It can mean 'false'. 0 does not represent some fundamental feature of reality, it is a tool (in non-mathematical usage). I will say the same of {}.
I was responding to the issue of representing non-existence, nothingness, with a symbol that has a place on the numberline. As a limit on "thingness", clearly zero is not just another number (like 2 or 5). We can see this form the ill behaviour of 0 when we try to divide other numbers by it. 0 was only masquerading as merely another digit.
Counter-examples like temperature seem poorly chosen. The zero is normally set at some significant place. In centigrade, it marks the freezing point of water (the limit of liquid). Then as science really got to know the world, they re-set the zero to absolute kelvin - the limit on motion.
I'm not really understanding your point now. If you are saying that symbols seem highly arbitrary in relation to what they represent, then yes, this is a standard point in semiosis and other theories of symbol-grounding. It is only if a symbol is as detached as possible from what it is meant to represent that it can freely function as a symbol.
I think the real problem here is that you are taking the naive Saussurian view of symbols and not a Peircean one. In one, the meaning of symbols is just convention. In the other, the meaning has a process of development.
http://www.aber.ac.uk/media/Documents/S4B/sem02.html
What I meant was that on the temperature scale 0 functioned as a demarcation, not the absence of anything. My point is that it seems useless, or pointless, to try to "pin down" the meaning of 0. It is often used where it is useful in relation to its properties in e.g. arithmetic, but it is not always so.
I am speaking of mathematics here, and the article did not seem to concern itself with it. It is not my intension to extrapolate my arguments to all of symbolism, so I don't think I am taking the Saussurian view (mainly because I have not heard of it before).
Mathematics is a language - a system of words and grammar, symbols related by logic. Or as category theory puts it, objects and morphisms.
As such, it is appropriate when asking "what's it all about" - as you have been doing - to step back to general theories of such activities.
Both Saussure and Peirce agree that symbols must be essentially free in the way you describe to function as logic-related symbols in a formal system. But then they differred in how symbol systems are then related back to the realities they model - which is the live issue in this thread. Saussure saw a simple associative relationship - by convention - whereas Peirce saw a deeper developmental relationship - by pragmatic useage.
Science went with Peirce's pragmatism. Perhaps it is a cultural thing, but mathematicians seem to want to resist the idea that maths has a practical relationship to reality.
Of course, this behaviour is also functional in that it justifies pursuing patterns "for their own sake". Maths can go off into the wilderness of ideas without having to have some immediate purpose. (But, say the mathematicians, look how often this activity turns out to create the patterns that in fact are useful to science's next generation of models.)
So a lot of what I am hearing in your responses sounds like boundary maintenance - attempting to maintain the ingroup/outgroup line. You are one of us if you agree maths is apart from reality, one of them if you think maths is bound to reality.
And in fact, I am one of the other in thinking both things at the same time. Like all languages, maths gains its power by being apart from what it describes (0 can be made to mean anything I like), but exercises this power by then actually describing things (ooh, look, this is what I mean by 0).
Our discussion is not about the motivation for pursuing mathematics, it is the status of mathematics itself. I can easily understand one motivation being to "model reality", but just as easily I can understand any other motivation. Whatever the reasons might be, and whatever is being studied, mathematicians are always 'doing mathematics' and it is quite important to be clear about what that is. If this is 'boundary maintenance', then it's important.
For example; as seen in this thread, it must be clear that there is a fundamental difference between criticizing the banach-tarski paradox for how it breaks with intuition, and, say, criticizing a logical error in the proof. If mathematics somehow ought to relate to reality, the former might be conceived as a relevant critique. It is, as Hurkyl said, an aesthetic or practical appeal. It must be clear that only the latter is relevant to mathematics. That is important boundary maintenance.
Consider the mathematical study of chess, or, say, rubik's cube. Is this modeling reality, or is it pursuing patterns for their own sake? I can hardly see the difference. Is this (or ought it be) somehow "less mathematics" than calculating the trajectory of a bullet?
EDIT: I will read the article, it seems interesting.
Hmm, but epistemology is trickier than this. For something to have a status detached from our purposes? - that is exactly the kind of classical presumption that I was challenging here. While at the same time agreeing that maths does strive as its purpose for a maximum degree of such detatchment. However, then, the reason for pursuing a formal detachment is only, ultimately, to do a better job of modelling reality.
You can claim that other motivations are possible - such as aesthetics, a commonly cited purpose. But who can even define what aesthetics is really about (and so know that they are successfully pursuing it)? I am arguing that there is only one true purpose for developing any language, and that is to develop a modelling relation between a modeller and the modeled. It does not seem hard to show that is a widely accepted purpose of maths. And while "any purpose" comes as a possibility due to the great detachment of maths from reality (the creative freedom which makes it in the end so powerful as a reality-describing language), in practice, no other purpose really holds up. A putative purpose like aesthetics is rather unintelligible - except as a roundabout way of making a modelling connection back to reality (saying "beauty is truth" therefore beauty is what is most deeply real...if you cared to go out and measure that fact).
The paradox shows a particular method has limits. It models reality quite reasonably across a large domain, but trips up at the final step. And there seems two proper responses to this kind of break-down in a model. First, we should recognise it as a paradox of the model and not of reality (as Hurkyl argued). And second it might suggest that a better model is still possible (and the way to find such a model could lie in going back and re-examining the axioms used, seeing if a better set of assumptions might lead us somewhere different). Getting back in touch with our intuitions about reality, I would argue.
And vagueness is an example of an ancient intuition which (along with dichotomies and hierarchies - the ways a vagueness can develop) has never really been mathematised. It is a path not yet properly explored, even though we have a whole bunch of first steps in that direction, such as Peircean semiotics, chaos theory, hierararchy theory, generative neural networks, etc.
Are you claiming that each (or most) individual developer of a language has this purpose as his motivation, or are you saying that this is how, regardless of individual motivation, language seems to strive towards? In either case (though the former is arguably wrong), I can't see how it is relevant to the status of the language itself. Actually; I would reserve myself to talk about the 'true purpose' of anything.
Mathematics is, without regard to extra-mathematical usage and motivations of individual mathematicians, a purely formal, syntactical discipline. The reason for this is not because we want it to be so in order to 'model reality better', it lies in the very nature of mathematics. We see that it is necessarily so when we see how mathematics is done. In the end, it seems that mathematics generally is pretty indiscriminate when it comes to the degree of applicability to physical modeling.
Besides: it is most likely that an individual cannot give a sufficiently complete account of his 'inner motivation' for doing what he does. Maybe this 'inner motivation' is not all that important either, or maybe it doesn't even exist. I would actually suspect that such reasons largely are created to compensate for the apparent lack of definite motivation. I personally can't honestly point to a more definite motivation than "it's interesting".
Perhaps this is what one would want. But such paradoxes are not due to a flaw in the mathematical process itself, the objections always comes from outside the discipline. In fact, I think most would agree that such a paradox is a positive thing, it shows us where to be careful. Now we know to restrict ourself to measurable sets if we want to preserve volume in rigid transformations. By using these sets we can again enjoy our intuitive feel.
OK, to me this a collection of impressions and feelings rather than a reasoned response. It may be your accurate impression of how the mathematicians you know operate (and it is my impression in general too). But I am trying to talk about what is fundamental in a reasoned fashion.
I have argued that the reason why a language like maths would enjoy any cultural capital is because it achieves a certain valued result. Its formalisms prove themselves to be good at the job of modelling reality. Now individual mathematicians may do maths for other personal purposes, but the general cultural purpose is pretty clear.
The second point is that this connection to reality may be denied within mathematical circles for a reason. Symbol systems have to be detached from what they describe so as to be free to describe them.
Howard Pattee is one of my favourite authors on this.
http://www.google.co.nz/url?sa=t&so...PcsZxT&usg=AFQjCNHouF69kz02eV_eL1CR38AtOqSZ7g
