Doing 3 second order differential equations numerically
The discussion revolves around solving a system of three second-order differential equations numerically using C or C++. Participants explore various methods for numerical integration and express uncertainty about the best approach to handle the interdependencies of the equations.
  • One participant seeks advice on solving three second-order differential equations and is uncertain about which numerical method to use, mentioning familiarity with Euler's method and Runge-Kutta.
  • Another participant suggests that using software designed for mathematical analysis, like Matlab, could provide useful tools for solving ordinary differential equations (ODEs) and proposes reducing the system to six first-order ODEs.
  • A method is proposed to define a six-component state variable and a vector field to reformulate the equations into a first-order system, which can then be solved using known numerical methods.
  • A different participant offers a Maple code snippet that claims to solve the system exactly, although this introduces a contrasting approach to the numerical methods discussed.
  • A later reply indicates that the proposed method worked well for the original poster, who was able to replicate results in Mathematica and found a good fit with their C implementation.
Participants express differing views on the best approach to solve the differential equations, with some favoring numerical methods and others suggesting exact solutions. The discussion remains unresolved regarding the optimal method, as multiple approaches are presented without consensus.
The discussion includes various assumptions about the methods and their applicability, as well as potential limitations in the numerical approaches due to the interdependencies of the equations.
WraithM
I want to write a program in C that's going to solve 3 second order differential equations, and I have little to no experience in solving differential equations in C (however, I know C well enough). I'm having a bit of trouble.
First of all, I don't really know what method I'm going to use to solve these differential equations. I know how to do Euler's method, and Runge-Kutta and those things, but perhaps there's a math library out there for C that works magic with differential equations. I don't really care how these equations get solved. I just care that they get solved, but I'm more than willing to write some code myself to solve them. If anybody has any suggestions, that'd be extremely appreciated.
Also, I don't really know how I'm going to solve 3 equations at once. If I write my own differential equation solver, I'm going to substitute and make them first order, then solve again, but I don't really know how to deal with equations that depend on each other. :/
These are the equations:
[tex]\ddot{t} = \frac{-2M \dot{r} \dot{t}}{r(r-2M)}[/tex]
[tex]\ddot{\phi} = \frac{-2\dot{r}\dot{\phi}}{r}[/tex]
[tex]\ddot{r} = \frac{M\dot{r}^2}{r(r-2M)} - \frac{M(r-2M)}{r^3}\dot{t}^2 + (r - 2M) \dot{\phi}^2[/tex]
Dots mean differentiation with respect to [tex]\tau[/tex].
How do you solve 3 differential equations that all depend upon each other at once (numerically)?
Any help would be greatly appreciated.
Actually, this could be in C++ too. C or C++ works.
I don't know about C++ but software which was design for mathematic analysis (especially Matlab) surely will have a lot of ODE/PDE tools.
In regards to the algorithm itself, it's not much different from one ODE.
And firstly it will be more simple to bring it down to a set of six first order ODE rather than three second-order.
What you do is define six component state variable
[tex]\vec{x}=(x_{i}), i=1,2,3,4,5,6[/tex],
and define a six-component vector-field
[tex]\vec{F}=(F_{i}(\vec{x})), i=1,2,3,4,5,6[/tex]
So your equations looks like this:
[tex]\frac{d}{d\tau}\vec{x}=\vec{F}(\vec{x})[/tex]
The components of the state variable will be:
[tex]x_{1}=t; x_{2}=\phi; x_{3}=r; x_{4}=\dot{t}; x_{5}=\dot{\phi}; x_{6}=\dot{r};[/tex]
The first components of F will contain the information that the derivative of the first three variables, are actually the last three variables. The last three component of F will relate the derivatives of x4,5,6 to the equations themselves:
[tex]F_{1}=x_{4}[/tex]
[tex]F_{2}=x_{5}[/tex]
[tex]F_{3}=x_{6}[/tex]
[tex]F_{4}=\frac{-2M x_{6} x_{4}}{x_{3} (x_{3}-2M)}[/tex]
[tex]F_{5}=\frac{-2x_{6} x_{5}}{x_{3}}[/tex]
[tex]F_{6}=\frac{M x^{2}_{6}}{x_{3} (x_{3}-2M)}-\frac{M ( x_{3}-2M)}{x^{3}_{3}} x^{2}_{4} + (x_{3}-2M)x^{2}_{5}[/tex]
So we've reduced the equations to the forms of:
[tex]\dot{\vec{x}}=\vec{F}(\vec{x})[/tex]
Now forget the vector signs, and just treat it like a first order ODE, which you know how to solve using Euler's method or Runge-Kutta.
For example in C\++, define a struct\class that will represent a six-component vector, with some basic arithmetic operations.
Your ODE system can be solved exactly. Please use the following Maple code
ode1:=diff(t(tau),tau,tau)=-(2*M*diff(r(tau),tau)*diff(t(tau),tau))/(r(tau)*(r(tau)-2*M));
ode2:=diff(phi(tau),tau,tau)=-(2*diff(r(tau),tau)*diff(phi(tau),tau))/(r(tau));
ode3:=diff(r(tau),tau,tau)=(M*diff(r(tau),tau)^2)/(r(tau)*(r(tau)-2*M))-(M*(r(tau)-2*M))/r(tau)^3*diff(t(tau),tau)^2+(r(tau)-2*M)*diff(phi(tau),tau)^2;
ans:=[dsolve({ode1,ode2,ode3})];
The answer is lengthy enough to be displayed here.
Thank you elibj123! Your method worked perfectly. I replicated my results in Mathematica, and my results in C almost perfectly fit the Mathematica curve.
