Domain of a Differential Equation
The discussion centers on finding the particular solution to the differential equation dy/dx=(1+y)/x with the initial condition f(-1)=1. The solution is identified as y(x)=2|x|-1 for x<0 and y(x)=3x-1 for x>0. The domain is restricted to x<0 due to the discontinuity at x=0, which affects the uniqueness of the solution. A unique solution across all real numbers except 0 would require two initial conditions, one for each disconnected part of the domain.
  • Understanding of differential equations and their solutions
  • Knowledge of initial value problems and uniqueness of solutions
  • Familiarity with concepts of continuity and discontinuity in functions
  • Basic calculus, particularly differentiation and integration techniques
  • Study the uniqueness theorem for ordinary differential equations
  • Explore the concept of discontinuities in differential equations
  • Learn about initial value problems and their implications on solution domains
  • Investigate the role of multiple initial conditions in defining solution domains
Mathematics students, educators, and professionals working with differential equations, particularly those focusing on initial value problems and solution uniqueness.
altcmdesc
Find the particular solution y=f(x) to dy/dx=(1+y)/x given that f(-1)=1 and state its domain.
My answer was: 2|x|-1, x ∈ ℝ/{0}
Apparently, the domain should be x<0
Solving the differential equation was not an issue at all, but I have no idea why the domain is restricted to x<0. I understand that zero cannot be included because dy/dx fails to exist at x=0, but why are positive real numbers not included?
In general, as well, how is the domain of a particular differential equation found that is not obvious (e.g. found by simply looking at dy/dx)
With the domain of a "particular" solution for a diff.eq, we mean those x's for which the given intial conditions yield a UNIQUE solution.
In your case, an equally good solution is:
y(x)=2|x|-1, x less than 0, and y(x)=3x-1 for x greater than 0.
The discontinuity at x=0 wreaks havoc on the uniqueness of the solution that normally is guaranteed by specifying a SINGLE initial condition.
Notice that if you were given exactly the same differential equation with the condition f(1)= 1, the domain would be the set of all positive numbers.
Ah, I see now. For an initial condition problem, the domain of the solution curve is the set of all x that satisfies the differential equation and contains the initial point. So, since there's a singularity at x=0, only the left half of the curve is the solution. Is my reasoning correct?
Indeed.
If you were to have a unique solution covering all of R except 0, you'd need TWO initial conditions, one in each of the two disconnected parts of the domain.
  • · Replies 52 ·
