Don't Miss the Boat: Get Onboard in 10cm or Less
  • Thread starter Thread starter iwonde
    Boat
The discussion revolves around calculating the time intervals during which a boat, executing simple harmonic motion with a 20 cm amplitude, is within 10 cm of the dock level. The boat completes a cycle in 3.5 seconds, and the individual is only willing to board when the deck is within 10 cm of the dock. The approach involves using the cosine function to determine the time when the boat's height is at the required level. The calculations reveal that the correct time to board is 1.17 seconds, which is derived from using the negative value in the cosine function. Understanding the graph of simple harmonic motion and the correct application of the cosine function is essential for solving this problem.
iwonde
While on a visit to Minnesota, you sign up to take an excursion around one of the larger lakes. When you go to the dock where the 1500-kg boat is tied, you find that the boat is bobbing up and down in the waves, executing simple harmonic motion with amplitude 20cm. The boat takes 3.5 s to make one complete up-and-down cycle. When the boat is at its highest point, its deck is at the same height as the stationary dock. As you watch the boat bob up and down, you (mass 60 kg) begin to feel a bit woozy, due in part to the previous night's dinner. As a result, you refuse to board the boat unless the level of the boat's deck is within 10 cm of the dock level. How much time do you have to board the boat comfortably during each cycle of up-and-down motion?
I don't really understand the problem. So am I finding the time intervals in which the level of the deck is within 10cm of the dock level? How should I approach this problem?
A graph of simple harmonic motion looks like what function?
The motion has amplitude 20cm, you will only board if the boat is within 10cm of the dock, i.e. within 10 cm of its highest point in its motion. Draw a graph of the motion the boat executes and the answer should be easier to get.
I'm bringing back a really old question but it just happens that I have the same HW question...
I understand that the graph of simple harmonic motion is sin/cos, and the highest point corresponds to the 20 cm and then half of that will be 10 cm. But how do i figure out the time from that alone?
Sorry to bump this thread, but how do I solve this problem? The amplitude is given as 0.2 m. The boat can only be boarded when it's within 0.1 m of the dock, so x = 0. T=2*Pi*sqrt(m/k), which means k must equal 4834 N/m, implying that omega is 1.795.
x = A*cos(omega*t)
0.1 = 0.2*cos(1.795*t)
How do I solve for t?
edit:
arccos(0.1/0.2)/1.795, but it gives 0.583 seconds. The answer is 1.17 seconds, or arccos(-0.1/0.2)/1.795. Why is it -0.1 (or -0.2, whichever it is)?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
