How Does Acceleration Affect the Doppler Effect in Moving Sound Emitters?
The discussion centers on the effects of acceleration on the Doppler effect as experienced by a sound emitter and receiver mounted on a moving vehicle. Participants explore the implications of relative motion, sound propagation, and airflow dynamics in this context, considering both theoretical and practical aspects.
  • One participant suggests that during acceleration, the receiver hears sound waves emitted at a previous time, potentially creating a Doppler effect as the car accelerates.
  • Another participant argues that since the emitter and receiver are fixed relative to the car, there should be no Doppler effect between them, regardless of the car's motion.
  • A participant raises concerns about practical issues, such as airflow affecting sound propagation, complicating a straightforward Doppler analysis.
  • Some participants discuss the implications of the car traveling at the speed of sound, questioning the validity of the initial assumptions about sound reaching the receiver.
  • There is a mention of the analogy of sound propagation in a moving train, suggesting that there is no Doppler effect between individuals inside the train, as they share the same frame of reference.
  • One participant highlights the distinction between the device being mounted inside or outside the car, which affects its interaction with the surrounding air.
  • Another participant proposes that the airflow could affect the speed of sound relative to the receiver, suggesting that sound might not be heard if the airspeed reaches Mach 1 or higher.
  • There is a discussion about the relationship between wavelength, frequency, and the Doppler effect, with some participants acknowledging the complexity of airflow dynamics in this scenario.
Participants express differing views on whether a Doppler effect occurs in this scenario, with some asserting that there is no effect due to the shared frame of reference, while others argue that the dynamics of sound propagation and airflow introduce complexities that could lead to a Doppler effect. The discussion remains unresolved with multiple competing perspectives.
The discussion highlights limitations in the assumptions made about airflow and sound propagation, as well as the need for a more nuanced understanding of the physical setup and its implications for sound measurement.
shawn9521
Let's say you have a sound emitter and receiver a fixed distance apart on a moving object but open to the air, such as on the hood of a car. The emitter is near where the windshield wipers are, and the receiver is closer to the grill. They are in aligned along middle of the car, longitudinally. I understand that if the emitter outputs a constant frequency signal, the receiver will hear that same frequency no matter what fixed speed the car is traveling at.
My question is, what about during acceleration? At any point in time, the receiver is hearing the output from the emitter x time in the past because the sound has to travel the distance they are apart. So if you are at rest and you slam on the accelerator, the receiver will still be seeing the waves from the "stationary" emitter for x time while moving at a higher speed, therefore creating a Doppler effect. Is this thinking correct? Thanks in advance!
the emitter and receiver are the same distance apart regardless of if the car is moving or standing still
and they are both moving together at the same speed/velocity/acceleration ( take your pick) with reference to the car
therefore there will be no Doppler effect between themDave
There are significant practical problems with such a setup. The airflow over the car is going to mess with the propagation of the sound, and that's going to make the problem more complex than a naive Doppler analysis that assumes that the air is largely undisturbed. There's a featured thread recently on a related topic, that might be of interest.
A naive Doppler analysis would suggest that you can use this device as an airspeed meter. When traveling at constant speed the emitted and detected frequencies and wavelengths must be the same, but these will multiply together to give a speed that depends on the speed you are doing relative to the air.
I'm not sure what happens in the case where you take airflow over the car into account. I suspect you can still use this as an airspeed meter, but you'll need to know about the airflow over the car, and you'll need to talk to an engineer about that... Overall, I think it would be easier to stick with a pitot tube.
Assuming you can use the device as an airspeed meter, you can use it as an accelerometer.
I'm not sure this is correct. Imagine the car traveling at the speed of sound (and somehow not messing up the airflow around it. The pulses would never reach the receiver - the wavelength would be zero and the frequency infinite.
Obviously that's a silly example, but I think it illustrates a general point that I need pen and paper to figure out formally...
it is only traveling at the speed of sound relative to a fixed object not connected to the car !
Since the sound source and receiver are attached to the car, they and the car are motionless in their reference frame
if you are standing in a train carriage talking to some one at the other end of the carriage
there is no Doppler effect between you and the other person regardless of how fast the train is moving
as you are all moving in the same frame of reference
Yes, but inside the train carriage you are pulling the air along with you. My understanding of the device he's proposing is that it is mounted on the outside of the car, so moving with respect to the air. If I've misunderstood and it's mounted on the inside, then I agree with you.
Yes, I was, in those comments, initially working on a static air situation.
OK so as in the OP, the air is flowing from the receiver towards the source.
NOTE we are NOT dealing with a Doppler situation that is a whole different ball game., as that deals with a moving source relative to a stationary source.
here we are just dealing with the effect of the airflow over the bonnet of the car in the region between the source and receiver.
Wouldn't any air velocity towards the source just be subtracted from the speed of sound in air ?
if that is the case then I think the only time sound wouldn't be heard at the receiver may be if the airspeed is mach1 or higher ?
I'm open to corrections :smile::biggrin:
Dave
I agree with your analysis. The received frequency is always the same (at least while the car travels at constant speed), but the wavelength and speed of sound vary as a function of the airspeed as you say.
I'd argue that the changed wavelength means that the Doppler effect is involved, but I'm nitpicking terminology, not physics.
I think it bears repeating that this analysis is assuming that the car is moving through the air without disturbing it. I don't think that's a valid approximation in this application, and I'm not sure what a real version of this device would do. Airflow over a vehicle is a complicated topic and the details of it will be critical to what (if anything) this device measures.
  • · Replies 16 ·
