Double Integral over a triangular region
6 replies · 4K views · last reply
mman014
Let f(x,y) = sin(∏*y^2). Let R be the triangular region on the x-y plane with the vertices at (0,0) (0,1) (.5,1). Consider the solid that is under z = f(x,y) and over the region R. Calculate the volume over that region using double integrals.
∫[itex]^{1}_{0}[/itex]∫[itex]^{1}_{.5}[/itex]sin(∏*y^2) dxdy
Integrating with respect to x first gives
.5∫[itex]^{1}_{0}[/itex]sin(∏*y^2)dy.
After this I'm stuck because I know there is no simple anti-derivative for that function.
If you reverse the order of integration then, sin(∏*y^2) would have to be integrated at first as well, so not sure what to do.
Hello mman014. Welcome to PF !
You are integrating over a rectangular region.
Write an equation for each line that is on the boundary of region R.
Thanks.
Anyways so I figured out that I had the limits wrong, and when I change it I am getting
∫[itex]^{1}_{0}[/itex]∫[itex]^{sin(∏*y^2)}_{0}[/itex]sin(∏*y^2)dxdy
So from there I get
∫[itex]^{1}_{0}[/itex]sin(∏*y^2)[x][itex]^{sin(∏*y^2)}_{0}[/itex]
= ∫[itex]^{1}_{0}[/itex] sin[itex]^{2}[/itex](∏*y^2) dy
At this point I am stuck again, unless I am doing something wrong or I found the wrong limits again. From here the only way I can think of continuing is using trig substitution and then I would have
the integral of 1/2 - (cos2(∏*y^2))/2. Which doesn't really help because I would still have to integrate the cos(2∏2y^2) which is the same problem as before.
mman014 said:
Thanks.
So from there I get
You continue to have them wrong.
As I suggested:
"Write an equation for each line that is on the boundary of region R."​
Wow so I just realized the mistake I made, wasn't thinking properly., equation of the line is just y = 2x so x = .5y, and I got it from there just using u sub and the rest is easy.
Excellent !
Anyways thanks for making me realize my mistake haha. I was staring at the problem for too long, fresh eyes always help.
