Drag Forces and Terminal Velocity
8 replies · 2K views · last reply
rosedog09
3. Describe how the mass of an object changes the terminal velocity of that object when falling.
5. A 79 kg Skydiver opens up her parachute and instantly decelerates at 8 m/s^2. Determine the Force of Air Resistance for this situation!
F = ma
Teacher says Im wrong on both these questions. I have consulted with other teachers and they say im correct. What do you guys think?
3. As mass increases, so does terminal velocity.
5. Fnet = FDrag - Fg
ma = FDrag - mg
FDrag = 79(8) + 79(10)
FDrag = 632 + 790 = 1422 N
Handwritten physics work: mu_k = 1 at top; item 5 gives F = mu, F = 79(8), F = 632 N, and Fg = 79(10) = 790 N; a vertical free-body diagram shows an upward F_D arrow and a downward F_g arrow; below, F_Drag - F_g = 632 N, F_Drag - 790 N = 632 N, and F_Drag = 1422 N.
Teacher Comments
5 and 3 are incorrect
Screenshot of forum text with teacher feedback: 'incorrect', 'Drag Force = m(g-a)' and 'Fnet (ma) = -drag force + mg', followed by a reply on terminal velocity and an upward and downward force derivation for Fdrag = m(-a + g).
Teacher Clarification (Email)
Handwritten free-body diagram and derivation: F_D up, F_g down, m = 79 kg, a = +8 m/s^2, F_D = ?; steps show ma - mg = F_D, 79(8) - 79(10) = F_D, 632 N - 790 N = F_D, 158 N = F_D, with a note that it is positive because she is pulled up immediately when the parachute opens.
My Response :
Handwritten student work with two free-body diagrams: left labelled My Answer shows F_D = 1422 N up and F_g = 790 N down, right labelled Your Answer shows F_D = 158 N up and F_g = 790 N down; red teacher notes say the problem requires acceleration to be positive 8 m/s^2, which my answer satisfies.
Teacher Further Response
Typed text on a white background: question 3 asks what happens to an object during the time it is reaching terminal velocity; question 5 works through drag and weight forces, ending with Fdrag = m(-a + g).
You are correct. Your teacher seems to be confused about how Newton's second law works. From the diagram in the email and using the convention that "up" is positive, the net force is
##F_{net}=F_D-mg=F_D-79~(\text{kg})\times 9.8~(\text{m/s})^2.##
Mass times acceleration is positive (up)
##ma=79~(\text{kg})\times 8~(\text{m/s})^2.##
Newton's second law is
##F_{net}=ma##
Substitute
##F_D-79~(\text{kg})\times 9.8~(\text{m/s})^2=79~(\text{kg})\times 8~(\text{m/s})^2\implies F_D=79~(\text{kg})\times (8+9.8)~(\text{m/s})^2.##
On 3 you are incorrect correct. The terminal velocity ( asymptotically approached velocity for which ##\dot v =0## from Newtons Second) is inversely proportional to the mass or square root of it ##( F_D \propto v^2)##
erobz said:
On 3 you are incorrect. The terminal velocity ( asymptotically approached velocity for which ##\dot v =0## from Newtons Second) is inversely proportional to the mass or square root of it ##( F_D \propto v^2)##
NASA Glenn Research Center slide titled Terminal Velocity showing the equations a = (W - D)/m, W = D = Cd r V^2 A / 2, and V = sqrt(2W / Cd r A), with a falling sphere labelled Drag upward and Weight downward.
erobz said:
My bad, you’re right. (Lesson for me) Don’t do mental manipulations on low sleep! Sorry.
All good. I can relate atm. All my AP exams are coming up and that doesn't stop my teachers from assigning lots of homework, so lots of late nights.
I wish my sleepless nights were by choice. Good luck on the exams.
To put @kuruman's explanation in a form that might be closer to the teacher's thinking…
##ma=F_{net}=F_D+F_g##
is correct provided all forces and accelerations will be filled in using the same sign convention .
##F_g=mg ## implies the sign convention is positive down (since g is always taken as a magnitude, so positive).
With that convention, ##a=-8ms^{-2}##.
##F_D=-mg+ma=m(-10-8)ms^{-2}##.
But again, that is positive down, so the upward drag force is
##m(10+8)ms^{-2}##.
Moral: always state your sign conventions and check you have adhered to them.
I think that adherence to the sign convention is not the teacher's problem here but unrecognized self-contradiction is.
Teacher says
"There is an upward Force and a downward Force."
Furthermore, the diagram in the teacher's email shows the drag and weight forces in opposite directions. This is all true and correct.
Then in the next sentence the teacher says
"Drag Force and Force Weight act opposite the Force caused by the upward acceleration."
Whatever the direction of this so called force caused by the upward acceleration, the second statement implicitly contradicts the first by asserting that drag and weight act opposite to this force, i.e. drag and weight act in the same direction.
The sign convention whether "up" is positive or negative never enters the picture.
