sophiecentaur
Homework Helper
- 30,509
- 7,510
So why choose air? Cheaper and less trouble, of course but a 'heat exchanger' of some kind at the top would help get better results.druidhr said:No, earth tubing with air is less effective.
I was browsing through Amazon to get some background knowledge about greenhouse heaters. They start at about 60W and go up to around 200W so that's the equivalent of power you'd be needing (I assume). I also assume that the greenhouse is draught proof. The roof looks as though it's insulated
I re-read your posts and you mention 'raised beds'. If you used a water system, you could run hoses in the soil in the beds. Warm (not freezing) soil is always good for starting off plants and your heat would be going where it's needed most. But that could complicate things because you would be better by getting the heat not from the beds so your control system would need electric valves (fairly cheap in plumbing stores.) to bring your heat absorbing CH radiators into play.
At this point people tend to start suggesting Raspberry Pie processors for controlling the system. But you may not be into that stuff.
Possible experiment would be to use a small fan, blowing down your pipe and see the temperature difference between input air and exit air. ( very low power laptop cooling fan)
