What should I consider when sketching a vector field?
The discussion revolves around sketching a specific vector field defined by the equation $$V2(r) = \frac{C}{\sqrt{x^2+y^2+z^2})^3} * (x,y,z)$$. Participants are exploring the implications of divergence in vector fields and how to represent them visually, particularly in the context of a three-dimensional space.
  • Participants discuss the divergence of the vector field, with some suggesting it might be zero while others question this assumption. There is a focus on how to visualize the field, especially when considering the simplification to a plane (z=0). Some participants express confusion about the implications of divergence and the behavior of the field at specific points, particularly at the origin.
The conversation is ongoing, with various interpretations of the vector field being explored. Some participants have offered insights into the nature of divergence and its implications, while others are questioning the assumptions made about the field's behavior at certain points. There is no explicit consensus yet, but productive discussions are taking place regarding the characteristics of the vector field.
Participants note that the vector field is not defined at the origin (0,0,0), which raises questions about the application of divergence in this context. The discussion includes references to mathematical concepts such as the Dirac delta function and the behavior of vector fields in relation to divergence.
arhzz
Draw the vector field
Hello! I am suspossed to write (sketch) this particular vector field.
$$V2(r) = \frac{C}{\sqrt{x^2+y^2+z^2})^3} * (x,y,z) $$ Note that the x y z is suspossed to be a vector so they would be written vertically (one over the other) but I don't know how to write vectors and matrices in LaTeX,so if anyone has a good tutorial or a site where I could learn that please let me know. Now for this vector field I first need to determine if it diverges and I got 0,since we don't have r anywhere so doing the partial differentiation will give us all 0.Now I am not really sure how to draw it since if the divergence of a vector field says to which extent the vector field flux behaves like a source at a given point.Our professor said we can imagine it like "outgoingness".If I had to simply draw it of this what I know I'd say there is nothing to be drawn,simply leave it blank if you will. We are also given a tip; "Consider z to be a constant".Now this tip confused me since I'd go with the answer nothing to be drawn but I pressume I'm wrong. What should I consider here,I must be missing something.
Thank you!
Let's simplify a bit. Can you draw some vectors in a plane (z=0)?
arhzz said:
Homework Statement:: Draw the vector field
Relevant Equations:: -
The divergence of this vector field might be zero but the proof might not be so easy. r exists in the denominator it is $$r=\sqrt{x^2+y^2+z^2}$$
Oh worth pointing out,no proof is needed (in the form of mathematicly proving that it diverges). I think I can draw vectors in a plane.When you say z = 0 do you mean that it does not have a length in the z direction? so only x and y are the ones that remain?
Drawing a 3D field on paper is quite difficult. That's why I suggested a simplified version drawn at z=0.
I am not sure I understand what exactly is the vector field btw. Is it the one where each cartesian component of it is equal to$$V_x=V_y=V_z=\frac{C}{\sqrt{x^2+y^2+z^2}^3}$$
If yes then its divergence is not zero, it is $$\nabla\cdot\vec{V}=\frac{-3C(x+y+z)}{(x^2+y^2+z^2)^{\frac{5}{2}}}$$
I see a mistake. The field is:
$$V_{x}=\frac{Cx}{(x^2+y^2+z^2)^{3/2}}, V_{y}=\frac{Cy}{(x^2+y^2+z^2)^{3/2}}, V_{z}=\frac{Cz}{(x^2+y^2+z^2)^{3/2}}$$
Ah I see well according to wolfram calculator this field has divergence zero.
I think the field in spherical coordinates is $$V(r)=\frac{C}{r^2}\hat r$$.
Well I don't really want to try to demand anything blantaly because I do not have the necesarriy knowledge to back it up,but in the solutions the divergence of the field is 0.Also I have googled a bit about what the field looks like when the divergence is equal to 0 and it is simply that the lines of the field go like this
Yes I am sorry I took the wrong field formula (thx @Gordianus for the correction), the field indeed has divergence zero. However the field that you depict is one possible field that has divergence zero, there are other fields that don't look like it but still have divergence zero.
Moreover I believe in spherical coordinates the field's formula is that in post #9. What do you think that are the field lines then?
I bring bad news. This field doesn't have divergence equal to zero everywhere. What happens at x=y=z=0?
E hehe yes you are right, when we say everywhere we mean everywhere except (0,0,0).
Strictly speaking the field isn't defined for (0,0,0) so we don't care about this point.
The field isn't defined at (0,0,0) but we still face the curious fact the flow through any closed surface that surrounds the origin is a certain number. Of course, we're approaching the niceties of Dirac's delta function.
You mean we are facing some sort of mini paradox, because the flux of any surface that surrounds the origin would be zero (if divergence was everywhere zero) yet the field seems to go to infinity at the origin. Either divergence theorem doesn't apply here or we have to say that ##\nabla\cdot\vec{V}=C\delta(\vec{r})## that is the divergence is zero everywhere except at the origin where it jumps to infinity.
Shhh...Don't say ##\delta(r)## jumps to infinity when ##r=0##. Mathematicians may be hearing us!
  • Haha
I am a mathematician, I know that the dirac delta function is in fact a sequence of functions.. We don't care if the limit of this sequence exist, we care if the limit in the sequence of the corresponding integrals exist.
  • · Replies 17 ·
