bbq2014
- 20
- 0
So, I am having trouble trying to understand my results. The experiment was marble (1.5cm & 5gram) was dropped on the surface of water, in a 40 cm cylindrical tube roughly 4cm diameter. The graph is negative, since the I used a program to analyse the velocity.
I don't understand why the velocity decreased after it hit max velocity.
http://tinypic.com/view.php?pic=2n9cjue&s=8#.U_2AmLySyed
The graph is a velocity of marble vs. time graph
It makes sense that the marble accelerates therefore had increase in velocity after it was released. But why would it the velocity be parabolic?
It should be a square root looking graph since the marble would continue to accelerate until the weight is equal to the force of buoyancy and drag, therefore terminal veloicity. But if the graph is correct, the stationary point is the maximum velocity, is that the be the terminal velocity? If it is, it doesn't sound realistic, it reaches terminal velocity in 0.3sec.
I calculated the Weight of the marble = 0.05317 N
The buoyant force = 0.0173 N
The drag force at the maximum velocity of the marble from the graph (0.564m/s) = 0.0797 N
Therefore 0.05317 = 0.09703, the mass should be floating? which sort of makes sense since the marble's velocity is decreasing? But why did the marble reach max velocity so fast?
But it might be due to experimental error.
Thank you in advance!
