Solving Du/dt=A*d^2u/dx^2 w/ Boundary Conditions
  • Context: Graduate
  • Thread starter Thread starter timsea81
The discussion centers on solving the partial differential equation du/dt = A*d^2u/dx^2 with specific boundary conditions: u=f(x) when t=0, u=0 when x=0, and u=V when x=L. The original poster initially attempted a separation of variables approach but concluded that the problem was not separable due to the non-zero boundary condition at x=L. A proposed transformation, u=u(x,t) - (V/L)*x, simplifies the problem, allowing the use of established methods for solving the heat equation. The modified function w(x,t) satisfies the same differential equation, leading to a viable solution for u(x,t).
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary value problems
  • Knowledge of separation of variables technique
  • Basic concepts of heat equations and Fourier series
  • Study the method of separation of variables in detail
  • Learn about boundary value problems in the context of PDEs
  • Explore the heat equation and its solutions using Fourier series
  • Investigate transformations in PDEs to simplify boundary conditions
Mathematicians, physicists, and engineers dealing with heat transfer problems, as well as students studying partial differential equations and boundary value problems.
timsea81
du/dt = A*d^2u/dx^2
Where u=u(x,t) and A is a constant.
The boundary conditions are:
u=f(x) when t=0
u=0 when x=0, independent of t
u=V when x=L, independent of t, where V and L are both non-zero constants.
Is there a general solution to this, or do I need to solve it numerically?
I tried solving it by separation of variables similar to what was done here:
http://en.wikipedia.org/wiki/Heat_equation#Solving_the_heat_equation_using_Fourier_series
But in the link the last boundary condition is u=0 when x=L, which allows us to conclude something about lambda that I can't with a non-zero boundary condition.
If it is separable, we have u(x,t)=X(x)T(t)=V when x=L independent of t. Following the method used in the link, to the point where we apply the different boundary conditions and my problem becomes different than what is in the link:
u(x,t) = [B sin(rootlambda x)] * [A e^-(lambda alpha t)]
Since u(L,t) is a non-zero constant independent of t, I think that I need to conclude A=0 leading to a trivial solution. I got this far with it before and concluded that the solution was not separable and therefore can only be evaluated numerically. Do you agree, or am I missing something?
Here is a link to another forum where I am looking for the same answer:
http://www.reddit.com/r/cheatatmathhomework/comments/17i341/dudt_ad2udy2/
The transformation ##u \to u-\frac{V}{L}x## will not influence your differential equation, but give u(L)=0. Solve the equation for the modified u, and add that linear part afterwards?
Interesting. Let's develop that a little:
u=u(x,t)
du/dt = A*(d^2u/dx^2)
u(x,0) = f(x)
u(0,t) = 0
u(L,t) = V
Let w(x,t) = u(x,t) - (V/L)*x
Now,
w(x,0) = u(x,t) - (V/L)*x = f(x)-[(V/L)*x]
We can just call this g(x) so that's fine
w(0,t) = u(0,t) - (V/L)*0 = 0-0 = 0
w(L,t) = u(L,t) - (V/L)*L = V-V = 0
dw/dt = du/dt - 0 = du/dt
dw/dx = du/dx - (V/L)
d^2w/dt^2 = d^2u/dt^2 - 0 = d^2u/dt^2
du/dt = A*(d^2u/dx^2) is given in the problem, and from above, this means that
dw/dt = A*(d^2w/dx^2)
So I solve dw/dt = A*(d^2w/dx^2) the same way they do for the heat equation on wikipedia, then use the relation
u(x,t) = w(x/t) + (V/L)*x
To find u(x,t)
I think that will work! Thanks!
